Need a 5th Wheel Hitch for a Short Bed - Slider or Fixed - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 04-02-2007, 04:21 PM Thread Starter
We are buying a new 5th wheel camper and I need to buy and install a 5th wheel hithc in my 2000 CC short bed F-250. Do I need the slider or will a standard fixed hitch be just fine? I have towed a travel trailer before but never a 5th wheel. Thanks.
2000 F-250 Lariat, CC, SRW, Auto, Short Bed
AFE Stage 2, 4" Magnaflow Exhaust (3.5" DP), DP Chip (40T, 80E, 120R), Autometer Z-Series gauges (EGT, Boost, Trans. Temp), AIH Delete, 305/70-16 Pro Comp All Terrains, Reese 15K slider 5th wheel
Extremesolo is offline
post #2 of 18 (permalink) Old 04-02-2007, 04:48 PM
SteveHeywood's Avatar
Re: Need a 5th Wheel Hitch for a Short Bed - Slider or Fixed
The answer is: It depends!
Are you comfortable with the knowledge that without an automatic slider you have the possibility of hitting the cab of the truck with the trailer? Sort of like what happens if you back up too tight with a travel trailer except with a fiver you can look out your side/rear window and see it happen.
Steve Heywood
2005 F250 Crewcab Shortbed 2WD 6.0L
Phoenix, AZ
SteveHeywood is offline
post #3 of 18 (permalink) Old 04-02-2007, 05:05 PM
Depends on the 5th wheel - a few are built with cut corners so that you can turn a bit sharper with a short-box but you really want to at least get a manual slider for those tight situations. A fully automatic one is quite expensive but a lot of people swear by them. A manual one will give you that extra bit in case you ever need it (but remember to slide it back BEFORE you get into a tight situation).
Regards
George Marchewa
2003 F250 4X4 Lariat FX4 Supercab SB 6.0/Auto
2006 Keystone Cougar 276EFS 5th Wheel
2012 Mustang 3.7 Premium Pony Package
Penhall is offline
post #4 of 18 (permalink) Old 04-02-2007, 06:00 PM
Note what Penhall said. My Montana 5'ver has rounded corners on the front and I pulled it with a non-slider hitch (I threw the slider away because I could not get it to work easily)for 5 years with a short-bed F-250. I never had any problems, but I watched closely when turning and backing.
My bro-in-law has a Cardinal 5'ver, same length as mine, but it has square corners in the front. He left a rear window in Salinas, Kansas, when he turned too tightly into a fuel pump.
I don't have a lot good to say about the sliders. I had two.... made the dealer change out my first Reese for one with the rollers... but it didn't help. I threw the slider mechanism away and bought a couple of bows from a U-Haul hitch place and went slider-less.
There's some new, very expensive models on the market, but seems a waste of money. Just my 2 cents.
Florida Ed
2011 Suzuki Burgman 650cc Rice Rocket Scooter 49 MPG, 120+ MPH, & 2009 Honda Shadow 750cc 51 MPG, 100+ MPH
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 198K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
SOLD 2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 98K miles headed to 150K stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
post #5 of 18 (permalink) Old 04-02-2007, 06:47 PM
I have towed with a superglide auto sliding hitch for a while. i had an 04 cc s/b and pulled a 32 ft carriage cameo lxi, 12.5 K. The slider paid for itself several times over and never having to worry about hitting the window was great. I had the under the bed mount, remove hitch, 4 pins and the box was completely empty, just had 4 1 1/2 inch holes for where the pins went through. I have one for sale, pm me if interested.
Navy Mustang, (E1-E7/01-O5) Still kickin.
2004 F-250,CC,SB,FX4,LARIAT,FIRESTONE AIR SUSPENSION AFT, TRIPLE PILAR MOUNT GAGES, LOW PROFILE COMBINED TOOL/FUEL BOX, SUPERGLIDE UNDER BODY MOUNT AUTO SLIDE 16k HITCH
Truck GONE, red oak used it as a bed!!!
IF IT WAS EASY...ANYONE COULD DO IT!
CV67Cheng is offline
post #6 of 18 (permalink) Old 04-02-2007, 09:25 PM
I don't trust sliders either. Had one slide on me at low speed once. Threw away the slider (as well as the shorts I was wearing [img]/ubbthreads/images/graemlins/blush.gif[/img] ) I believe reese redesigned their slider a couple of years ago, maybe they are more reliable now. I know others will disagree. Just my .02
2005 f250PSD,lariat,fx4,cc,lb,60gal titan fuel tank
2005 Jayco 27.5bhs 5'er
thomhack is offline
post #7 of 18 (permalink) Old 04-03-2007, 12:19 AM
If you have a tight spot at home, or ever need to turn really sharp you will need a slider. I put a reese 16 K 4 way pivot slider in mine. Big bucks, but slider function is a piece of junk. Wish I'de forked over the 2,400 bucks for the superglide that automatically slides (because of gears within that force it back).
If I turn really sharp with my 250 short bed, the fifth wheel will hit my cab. I have to first get out and slide this hitch back. Sometimes it takes four or five attempts to get it to lock in place.
However, after three camp trips, I've never had to fool with it out at the campsites, I just have a real tight place to park at my house.
Also, if you need to mount a plug, may I suggest placing the receptacle on the FRONT of the wheel well where it's easier to access without reaching between the bed and fifth wheel. Another lesson learned.
06 F250 6.0 PSD 4x4 Crew Cab SB Lar
kena48 is offline
post #8 of 18 (permalink) Old 04-03-2007, 01:20 AM
Get the slider, If you ever get into a tight spot or hook up to another 5th wheel you might need it. It is a great backup to have and a real pain if you don't. Do a search on google and figure out how much the rear window and cab repair costs.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
post #9 of 18 (permalink) Old 04-03-2007, 12:33 PM
Lots of good replies here. Do a test run backing up your trailer and watch how close to your window the corners of the trailer come (some factors like pin box length and roundness of corners will affect this). Trust me, somewhere in the time you pull your fiver, a situation will come up where you will have to have your truck almost at a 90 degree angle to the trailer. A manual slider will allow you to do this. Also varying terrain will close that gap between the window and trailer way too quickly. My brother has a manual slide and he has used it a ferw times. I bought a used Superglide that was just like new but havent installed it yet.
2008 F-250 Lariat SRW 4x4 CC SWB...
KEM tuned Minimaxx
... S&B CAI / MBRP Cool Duals
Dark Stone Metallic / Pueblo gold
Readylift 3.5" levelling kit
... Toyo MT 315/70/18(bigger than 35-12.50-18)
--- BIG$HOW -------<տլ
Bigshow is offline
post #10 of 18 (permalink) Old 04-03-2007, 06:54 PM
I decided to go ahead and pony up for the super glide. I am new to pulling a 5th wheel, and most of the time I arrive at the campsite after dark. Trying to get into a tight spot in the dark is stressful enough without adding the additional concern of knocking out my rear window. I think that factor alone made the hitch worth the money. BTW I have been in several campsites where I needed to get the truck and trailer 80 degrees or more to get it into the spot. Dam Texas state parks have very small drives and usually a culvert on each side. DOH!!!
I did have my trailer impact the bed when I got into a particularly bad situation.
2006 F250 CC 4x4 6.0 Harley Davidson Dark Shadow Grey.
bbuchanan2 is offline
post #11 of 18 (permalink) Old 04-04-2007, 07:57 PM
DIESELDUTTON's Avatar
I have a 16k Reese with the slider unit and I use it(slider feature) all the time when I go to state parks or up hunting in the mountains, come to think of it I have only been to a real campground once. It is about five years old and I have never had a problem with it and all I do is cover it up when I'm not using it and before each season I spray the rollers with a little chain lube, its the same stuff I use on our dirtbike chains and no it does not make a mess. Good Luck
Frank
2004 Pitbull Motorsports rigid chopper...Traded on 2010 F-250 5/30/14
121 TP 130rwh 250 avon
04 CRF250 mine....Gone
02 CR80 sons...Gone
03 XR100 daughters..Gone
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyone
2011 Cougar 325 SRX Toyhauler
2010 F-250 4 door 6.4 with all the fixins
DIESELDUTTON is offline
post #12 of 18 (permalink) Old 04-05-2007, 01:57 AM
Frank
With the Reese do you have to take the load off the hitch with the landing gear before you slide it back?
- 2011 F350 Lariat Crew Cab, 6.7, 4x4, Forest Green
- (Traded) 2005 F250 XLT Ext. cab, 6.0/Torqshift, 4x4, Dark Stone Metallic, Built week of Aug 16/04
Saskford is offline
post #13 of 18 (permalink) Old 04-06-2007, 10:08 PM
JimmyDee's Avatar
My Photos: (24)
No, you just lock your trailer brakes after releasing the locking mechanism on the hitch and move the truck the direction you want the hitch to move. Mine works great.
However, I seldom need to use it.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod;
, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in
AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
post #14 of 18 (permalink) Old 04-10-2007, 05:43 PM
Jim
Jim,
You must have a newer version as I have that same hitch and I have to drop the trailer legs and take some weight off before my hitch will move. Dunno but maybe pin weight makes a difference... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mike
Puyallup, WA
You can have my 6 speed when you pry my cold dead fingers from it! or if I get an 08!
Picked up on 2/18 - "04" F350, Crew Cab, 4X4 SRW Lariat PSD 6.0 w/ 6 spd w/ Momo shift knob, BD Power short shifter, Prodigy brake controller, Wedgewood Blue/Arizona Beige w/ all the factory goodies. TRUCK IS FOR SALE.
navyldo is offline
post #15 of 18 (permalink) Old 04-11-2007, 02:21 AM
Bill1013's Avatar
Measure from the front of the trailer to the back of the truck cab when hooked up, it must measure 54" or you will crash your cab and trailer on short turns. Some 5th wheelers have an extended tongue on them for short beds. Also have at least 5" clearance from your bed rails to the bottom of trailer. You can bend the box rails turning into some service stations, restaurants and the like. If you don't have that clearance an automatic slider that will slide while towing and turning is the thing, awfully expensive around $2500. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
