need other air bag, donot like RideRite inside of frame.
i have an 05 f-350 SRW and need some air bags. i had a set on my 97 and loved them. the only name brand i can find are the Ride Rite that take the place of my factory bump stops. i would like to find a set that mount outside of the frame like i had on my 97. i think this placment would provide better roll or anti-sway control than the kind that mount "inside" of the frame.
links to other brands would be great.
Thank You.
2005 f-350 4x4 ex-cab long bed power stroke, torq. shift 3.73 axle gears. pull 36ft goosneck race trailer with liveing qtr. and a rock crawler in the back.
no mods ....yet.
first new truck and smilling every day.
Re: need other air bag, donot like RideRite inside of frame.
Ride Rite has two versions, one for a Fifthwheel application (2330), and one without (2071). The model 2330 is inside the frame, similar to what you have, and model 2071 is outside of the frame. Since they did not list numbers for 2006 models for my F350, I emailed tech support and they said the 2004 model year part numbers would work. I hope that helps. I looked for other brands as well, but did not find anything I liked as much as the Ride Rite, at least on paper. When I get them installed, I'll see how it goes.
__________________ Dave 11 #3
FOREVER THE MAN
LEGENDS NEVER DIE
1997 F350 CC DRW 4X4, Black. Centaurus2 conversion. Banks IC & powdercoated tubes. Stage 2's by Full Force Performance,BDP Dom 66, BDP Fuel system , TS 6 pos chip with Bills & T Wildmans burns, AFE intake, 4" exhaust. Gear Vendor Overdrive. E4OD with Suncoast Pro-Loc TC, 4.10 gears. Sky's RSK, Kelderman air ride, Bilsteins, 40 gal Transfer Flow. Alcoa's. Pioneer stereo, full floor and overhead console.
I know you are looking for air bags but you need to check out Timbrens. The stability under load is phenomenal! Easy installation. one bolt on each and remove stops one bolt each. Put them on and forget them! No maintenance, no adjustments, no hassles! [img]/ubbthreads/images/graemlins/cool.gif[/img]
__________________ 2008 F450 DRW CC LWB 4x4 Off Road, Lariat, Oxford White, 4.30 LS rear end, Navigation, audiophile stereo, Memory package seats, heated seats, heated mirrors, warmup heat option power back window, traction control system, backup alarm, rear DVD with wireless headphones.
I have a set of Air Lift Super Duty air bags in the rear of my truck, Love them!! I pull a heavy fifthwheel.
Take care,
Eddie
(Ordered Jan 13th, Picked up Feb 21)
Black (XL with options) 2005 F-350 Super Duty,PSD,DRW,Super cab,8ft bed,Tow Boss,Tow Command,Snow Plow Prep,upfitter switches, 15K built Ford tough hitch, Line-X, Highway Products toolbox
RV - 2005 Excel Limited 36RDE
(Full time RV'er, where ever I leave my hat is my home.)
