Old 07-01-2007, 08:48 PM   #1 (permalink)
New ground required for Prodigy?
Just installed a Prodigy controller but have not pulled my trailer to tune it yet. I plugged in my trailer to the truck and set up the Prodigy to tow when I have more time. All of the readings are OK according to the manual. On the Tekonsha website there is a note that says for F-250 and 350 a new ground needs to be run if the factory ground is terminated on the fire wall. How would one know where the termination point is under the dash and is this necessary? My last Tekonsha controller (not a Prodigy) worked fine for 5 years. I got the Ford harness from Tekonsha that plugs into the factory connector. I have been told by other Ford owners they have had no problems with just using the factory harness. Any input would be appreciated. I have a 2001 F-250.
01 lariat 250 psd true blue with gold bottom,sup. cab, 4wd, innovation cab high wrap over. Autometer Lunar guages.AIS filter system.
jbrodie is offline
Old 07-01-2007, 09:43 PM   #2 (permalink)
Fever's Avatar
My Photos: (9)
Send a message via ICQ to Fever
Re: New ground required for Prodigy?
plug and play on my '02...
2002 F-250 Super Duty Super Cab Short Box 4x4
7.3L PSD, 4R100 Automatic, 3.73 LSD Gears,
BTS Valve Body Kit, Tymar Intake, Muffler Delete,
DP Tuner F-5 (60T/80E/120R/Hi-Idle),
ISSPro A-Pilar Guages (Pyro/Boost/Trans Temp),
Powerslot Cryo Rotors/Hawk LTS pads,
285/75-16 Yokohama GeoLander A/T II Tires,
Tekonsha Prodigy Brake Controller
2006 Sunset Creek 269BH Travel Trailer
Fever is offline
Old 07-02-2007, 11:54 AM   #3 (permalink)
KF6ZVT's Avatar
I just connect mine to the Ford harness, plugged it in, and have been doing great for 2+ years.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
Old 07-02-2007, 04:48 PM   #4 (permalink)
Should be just plug and play. Never seen any problems.
Darrick S - TDS Sponsor
Southwest Wheel - Serving the wheel, trailer, and towing industry since 1919.
darricks is offline
