Old 07-01-2007, 11:50 PM   #1 (permalink)
dennis11's Avatar
New Shocks
I am putting firestone ride rite air shocks on the rear of my 97 PS. I am pulling a 34ft fifth wheel around 12,500lbs loaded. My regular shocks have about had it. Would it be a waste of money to put both on the rear of my truck? Thanks
1997 F250 PS 4 wheel drive John Wood towmaster tranny with Tru-cool tranny cooler and second Summitt tranny cooler with pusher fan on at 175 degrees, tranny temp gauge 4:10 gears aluminum diff cover with royal purple supercab regular bed, factory aluminum rims Firestone ride rite airbags rear 275,000 miles also have 1995 F250 PS 4 wheel drive 5 speed manual transmission standard pickup 199,000 miles
dennis11 is offline
Old 07-05-2007, 10:36 AM   #2 (permalink)
Re: New Shocks
What do you mean by "both"? Air shocks with bags?
I am Fordless, SOLD>>> 1999 F350 XLT 7.3 SD SC DRW 4:10 LS Auto Trans 4x4 Auto Hubs APC Telescoppic Heated Power Tow Mirrors K&N Filter Banks 3 1/2 down pipe ATS 4" exhaust 3 gauge (ET, trans temp, turbo boost) pillar mount WD Chip WD Turbo Brake
Steve F. is offline
Old 07-06-2007, 10:26 PM   #3 (permalink)
dennis11's Avatar
Re: New Shocks
Hey Steve F I made a mistake in typing my question and your question make me realize what I did. I meant firestone air bags. Now my question is: If I put on firestone ride right air bags do I need to upgrade the regular shocks on the rear of my PS at the same time? Thanks for catching that, now what do you think?
dennis11 is offline
Old 07-06-2007, 11:04 PM   #4 (permalink)
Re: New Shocks
I have a fear of air bags that mount on the side of the frame. We have seen here too many OBS's that have had the frame crack where the bag mounts. I will try and do a search for you and see if I can find them old threads.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 07-06-2007, 11:18 PM   #5 (permalink)
96STROKE's Avatar
My Photos: (6)
Re: New Shocks
firewood,
I highly recomend the firestone air bags!!!! If your stock shocks are more than a couple years old/30k miles, YES they need to be changed also. I recomend the bilstien shocks. the bilstiens are self adjusting vs the other good towing shock (rancho 9000) which you must adjust for empty vs towing.
With the new bilstiens truck rides nicer, (much better vs stock shocks) and with the air bags I now can adjust level of truck along with being able to customize the ride to my liking.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 07-07-2007, 12:05 AM   #6 (permalink)
Re: New Shocks
Ok with that said, no do not use both and to be honest I would stay away from air shocks, way to much pressure on the mounting bolts and that pressure dose NOT belong on shock studs... Sit back and think about it, would want all that load sitting on 2 bolts to the frame?
Easy and simple, if you need a boost in loading (to make you level), bags are the way to go. I had bags on my 99 F-350 and I "never" used more then 70lbs loaded. Here is a trick I did, if I left 20lbs (always best to keep some air in them) in the bags unloaded then when I put my 1,300lb hitch weight 5er on, that would set me at about 60lbs at the bags and sitting nice and level. My point? Well never had to take out or add air, BUT I did have an on board compressor for the bags that was also setup to fill tires if needed.
Go bags, forget air shocks.
Now with all that said, lol if I misunderstood and you are just asking should you add new shocks. That is up to you. Me? I didn't with my 99 and I think I had around 30,000 miles on it at the time of bag install and sold the truck at around 85,000 miles with the same shocks, I never felt a reason to replace them even at that mileage.
Steve F. is offline
