New Travel Trailor...suggestions/tips for proper set-up - Diesel Forum - TheDieselStop.com
Old 04-06-2006, 04:03 PM   #1 (permalink)
My Photos: (27)
Will pick up the 33' Cougar on Monday. I just wanted some suggestions about equipment and rigging for towing safely. The trailer weighs 7k dry and has a 9k gross weight. My X weighs 8k and has the factory Ford class V hitch. The sticker says 5k/500lbs or 12,500/1250 WD. I'm having an Equalizer 4 point hitch installed that day as well. I've towed heavy stuff in the past w/ PSD pick-ups, but know the Excursion's can be a little squirrelly. Anything else I should consider?
Thanks,
Lane
2008 F-350 Lariat, 6.4 PSD, 4x4 Dually
Tow Boss, 4:30 gears, 450 wide track, 6" Pro Comp radius arm lift, MX6 reservoir shocks, 22" American Force dually whls, 37" Toyo MT's, Buckstop bumper w/Warn 16.5, APM Ram air hood.
North Texas Power Stroke Association & Wyoming Power Stroke Association
BadSuperduty is offline
Old 04-06-2006, 07:50 PM   #2 (permalink)
Re: New Travel Trailor...suggestions/tips for proper set-up
If you notice that the rear up of the excrusion is dipping down you could possible addd some air bags to keep it up.
2008 Dodge 1500 Quad Cab SLT
http://community.webshots.com/user/mbro598814
2006 F-350 4x4 Crew Cab SB 6.0L Diesel Lariat (trade)
1996 F-250 CC SWB 7.3L XLT traded
2004 US Cargo 14x 7 enclosed trailer
Markford14 is offline
Old 04-06-2006, 09:47 PM   #3 (permalink)
Just make sure your tires on the X are inflated to max recomended pressue. Start out slow until you get accustomed to the new combo.
Godd luck and be safe, Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 04-06-2006, 10:09 PM   #4 (permalink)
BK
I agree with you about the Excursions being a litle squirrelly. I used to pull my 34 ft trailer with a F350 dually and it always felt as solid as a rock. When I started using the Excusion as my TV, I made the mods in my signature below but never felt really safe until I bought the Hensley hitch.
2003 6.0 PowerStroke Excursion 4x2, Helwig Rear Stabilizer, Rear Airbags, Bilstein Shocks, pulling a 34 ft Holiday Rambler TT with a Hensley Arrow
BK is offline
Old 04-06-2006, 10:44 PM   #5 (permalink)
FaC
I have a Cougar 304 and one thing that I learned was that it tows twitchy if the tongue is level or high. I found that my setup tows best if the tongue is about an inch low when it is loaded and ready to roll. You have to look hard to see it and I was able to adjust just by moving the head down 1 hole.
FWIW - Frank
2002 F-250 4x4 XLT CC PSD 6sp
ISSPro Gauges, pre-pump, MBRP 4" Turbo Back, Fumoto
PopUp GN Hitch
Cougar 304BHS TT
FaC is offline
Old 04-07-2006, 09:19 AM   #6 (permalink)
My Photos: (27)
Thanks guys....
Got the airbags but will check trailer stance Monday.
Take care,
Lane
