New to the world of goosenecks..... hitch setup, advice, etc. needed... - Diesel Forum - TheDieselStop.com
Old 03-01-2005, 01:51 PM   #1 (permalink)
I've pulled an enclosed tag car trailer for quite some time, but have finally stepped up to a gooseneck enclosed. I have purchased a 53' Haulmark Edge that I will be picking up on Thursday. I bought a 25k Putnam hitch, that will be here tomorrow. Any general advice on installing the hitch, etc? Is there only one "place" to install it or is positioning left to the installer?
Any ins and outs you guys have learned would be great... just looking to save myself time and headaches. Any input whether it be on the trailer, towing, hitching, or installation are welcome. BTW, I will be pulling with a 2000 2wd CC dually PSD. Thanks in advance.
2000 Ford F350 CC Dually PSD 2wd Lariat -- DJM 3/5" Lowering Kit, 2005 grille/bumper/headlights, TS 6-position Chip, MAC Intake, Pyro/Trans Temps/Boost gauge, Monsterbox Tranny w/ external filter, TruCool Tranny Cooler ...... all pulling a 53' HaulMark Edge Gooseneck.
Jason P. Zaluski
JasonZ is offline
Old 03-01-2005, 05:49 PM   #2 (permalink)
Re: New to the world of goosenecks..... hitch setup, advice, etc. needed...
I think if you take it to a reputable shop then I don't think you need to worry about it being installed properly, them guys can probably install it in there sleep.
2000 model Red GMC 3500,DRW,2WD,Reg cab,5.7 V8,auto 8'5" J&I flatbed. 1982 white Ford F-100, reg cab, shortbed, 3.8 V6, 3 speed on the tree.
StuMas is offline
Old 03-01-2005, 08:30 PM   #3 (permalink)
The hitch might come with directions. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My GN ball is 2" in front of the centerline of the axle. I've read where some peoples were installed 4" in front of the centerline.
I'm sure Grumpy Ole Man will be along with a little more info. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Remember, this is the internet, where everyone's a diesel mechanic and has 500+hp/1000+lb/ft under the hood! Read up, form your own opinions, then do your own real-world testing!
'01 PSD F-250 XLT SC LB 2WD 6SPD 3.73LS, Alliant AC's,ARP Studs, Stealth Dual HPOPs, GTP38R, Forged Rods balanced, Fluidampr, South Bend CON OFE, 6.0L Intercooler, Volant Intake, 4" SS MBRP Exhaust, A-Pillar mounted Lunar Series Boost/Pyro Gauges,4 pos. Chip with Stealth burns from Twildman, playing with Minotaur Tuning software too, heated Racor 900FH 2 micron, Hutch mods, harpoon mod, DIY Regulated Return, 203 T-stat, coolant filter, AIH gone, CCV Mod, boost pressure relief valve, 100 gallon tank/toolbox combo...AutoEnginuity diagnostics for all Domestics
roosterdiesel is offline
Old 03-02-2005, 11:52 AM   #4 (permalink)
most of those hitches come with good directions, i've never installed a Putnam, but i'm sure it'll be pretty straight forward. i'm assuming you got the Lock & Load hitch, the rep. at Putnam told me you need a 4" hole in the bed. if you don't have a 4" hole saw, you may won't to go ahead and start looking for one, when i bought mine it took awhile to find one. if you can follow directions(i know some of us aren't good at that [img]/ubbthreads/images/graemlins/blush.gif[/img]) you can do it. i would recommend getting a buddy to help hold it in place while putting in the bolts. i found this out the hard way the first time.
i'd mount a 7 way recept. in the bed somewhere ( i mounted mine behind the wheel well on drivers side) i just tapped the wires behind the factory recept. on the bumper. you can buy a fancy adapter that hooks up under the bed somewhere.
thomas
<font color="orange"> __________________________________________________ _____________________________</font>
aka Power-Strokin' (234 posts)
<font color="orange">'02 F250 XLT CC PSD 4WD</font> <font color="navy">3.73ls VDH2 oxford white/silver metallic, DP-Tuner 4 pos.(40, 70, 100, 125), FTVB, AIS, WD Turbo Brake III, 4" Magna-Flow turbo-back exhaust, wicked wheel, 3 guage A-pillar pod w/ Di-pricol white-face guages, ITP fuel system, after market leather seats (two tone), Super-Liner, "chromed" emblems, CCV mod., BFG AT 295/75-16 on 16 x 10 Ultra Type 50/51 wheels, Rancho RSX, Amsoil bumper-to-bumper, PopUp GN hitch, GOS harness & SilverStars </font>
'04 F250CC Lariat PSD FX4 white/silver, Putco stainless toolbox, stock!!!
<font color="red"> Immokalee Regional Raceway </font> <font color="green"> '57 Cushman Eagle </font>
AllStarPSD is offline
Old 03-02-2005, 12:02 PM   #5 (permalink)
My Photos: (27)
One thing you might do is cut a clean hole and save the piece you cut out. I have a Buyers Hide-a-Ball, had it before they've come out with all these fancy new ones, and it required cutting out about a 10" square of bed floor. When I sold my old truck I did a clean job of gas welding the piece back in, spray can painted the area and you had to look twice to tell there was ever a gooseneck hitch in the bed. Helps with your resale value and you don't have to sell your gooseneck hitch with the truck.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 03-04-2005, 02:07 AM   #6 (permalink)
One good advice is don't run the trailer into the truck, or the truck into the trailer. I can't tell you how many times this has happened.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 03-04-2005, 08:07 AM   #7 (permalink)
Also, don't forget to let the tailgate down [img]/ubbthreads/images/graemlins/blush.gif[/img]. This has happened to a few of us [img]/ubbthreads/images/graemlins/shrug.gif[/img]. New tailgates are very expensive!!
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2009 Chevrolet Traverse(wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
2010 Kawasaki TransMule Diesel
firefighter9208 is offline
Old 03-04-2005, 10:27 AM   #8 (permalink)
Send a message via ICQ to MudHog
You should be able to mount the hitch yourself. They come with very detailed instructions (plus you can always ask questions here if needed). If your truck is a long bed, then you'll be able to jacknife the trailer when driving for ease of moving around, they also typically mount the ball further toward the front on a long bed. short beds are a different story and you will have to always watch out of the trailer kissing the cab when jacknife the trialer.
Plug: surely mount you one in your bed. prevents from having to hang the wire over your tailgate.
Tailgate: If you do alot of hooking and unhooking, then you may want to consider a louvered V tailgate. These tailgates can be left up when hooking and unhooking, no need to get out, drop tailgate, back up, lift tailgate, then finish hooking up.
Goosenecks back up differently than a bumper pull too, but they are much better pulling than a bumper pull. Trial and error will teach you the tricks to backing up.
Extra Note: 53' seems awfully long, have you checked your state regulations on total length of rig? LA has a law that the vehicle and trailer can be no longer than roughly 65' (information only, contact your local state police to verify).
'03 F150 Supercrew FX4. Little 1/2ton that gets 15 MPG on 23 gallons.
'06 F250 FX4 CC SWB
MudHog is offline
