No power to 12V constant pin - Diesel Forum - TheDieselStop.com
Old 10-29-2006, 03:25 PM   #1 (permalink)
Hi All,
I thought I'd post here to see if I'm missing something simple before I start digging further into my truck wiring.
I've got a 2001 F250 PSD with the factor towing package. I've been using the 7 pin plug for a while to tow my trailer, but with that trailer I primarily use the lights and trailer brakes.
Yesterday I was towing a box trailer for my kids' marching band. That trailer makes use of the 12V constant pin to run lights on the inside of the trailer. When we went to load the trailer last night, we realized those lights did not work.
I've checked the pin that should be the 12V power with a test light and it appears to be dead. Testing the wire (heavy orange wire) upstream, it appears to be dead as far as I can reach at the back of the truck.
This morning I checked the fuses that appear to be related to the trailer battery charge circuit (what I assume is the 12V line). Both the 30A fuse under the hood and the 10A fuse in the cab are fine.
Looking at a wiring diagram in my Haynes manual, it looks like there's a relay for the battery charge circuit. If that's the case, what activates that relay? Am I incorrect in assuming that line should be hot at all times?
Any info anyone can provice would be appreciated. Worst case, I'm going to run a direct line with a switch, but I figured I'd check here and see if anyone has any tips before I start crawling under and tracing wires.
Thanks,
Jeff
2004 F-250
Lariat, 6.0L, Auto, 4x4
Club Cab, Short Bed
khokhonutt is offline
Old 10-29-2006, 04:14 PM   #2 (permalink)
Re: No power to 12V constant pin
Did you test the pin with the key in the on position?
2006 F-350 extended cab 4X4 SRW 6 speed 3.73
enginebill is offline
Old 10-29-2006, 04:28 PM   #3 (permalink)
Yes. Last night when we were trying to get the lights to work I tried with the key in the on position, with the truck running and with the running lights turned on. None of them seemed to provide power to that pin.
Old 10-29-2006, 04:56 PM   #4 (permalink)
overfly's Avatar
My Photos: (16)
When I had my '03, I had the same problem. Turned out even though it had the towing package there was no relay (just an empty plug). Put in a relay and it worked just fine.
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
Old 10-29-2006, 05:00 PM   #5 (permalink)
it is only hot when the key is on.
tobi is offline
Old 10-29-2006, 05:13 PM   #6 (permalink)
Hi All,
Thanks,
Jeff
I believe you need the relay and the fuse for the pin to work properly. That way a camper with a large battery cannot back feed into the truck.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 10-29-2006, 05:24 PM   #7 (permalink)
Ok, cool. Thanks for that input. The relay sounds like a good bet. Can anyone tell me where that relay is located? I can't seem to find it in the Haynes manual and my owners manual doesn't seem to help either.
Jeff
Old 10-29-2006, 06:53 PM   #8 (permalink)
I don't know about the newer trucks, but in my truck the relay is in the power distribution box under the hood. Same place the larger fuses are. Should tell you in the manual where the fuse belongs.
NickKent is offline
Old 10-29-2006, 06:54 PM   #9 (permalink)
D_Dunn's Avatar
My Photos: (28)
Jeff,
I replaced the relay with a jumper to get a constant 12 volt feed to the "+" terminal of the 7 pin plug. I made the jumper from a piece of heavy guage wire with spade terminals on each end. I used a test light to determine where to plug it in. I'd have to check to see which two terminals I plugged into. On my 2000, the trailer charge relay and trailer backup light relay are in a small box with a lid, right next to the main power distribution box under the hood. It's the relay toward the front of the truck. I would think your '01 would be the same but don't know for sure [img]/ubbthreads/images/graemlins/shrug.gif[/img]. This is a pretty simple mod to get a constant 12V to the rear of the truck.
Hope this helps...
Dan
My Truck Pics
2000 F-350 Lariat 4x4 Crewcab longbed dually PSD 6 speed with: DP Tuner F5 16-pos. chip; Ford AIS air intake with fender sleeve & Zoodad mod; ITP boost regulator; fumoto valve; DPPI MBRP 4" turbo-back "cool duals" exhaust and 5x18 ITP stainless tips; Triple gauge A-pillar with Isspro EV gauges; "wicked wheel"; AIH delete plug with code eliminator and boost hookup; intercooler foil wrap removed; LED taillight mod, clear headlights, corner lights, cab lights, & dually fender lights; front-mounted 2" receiver, Putco Bossboards; Pace Edwards rolltop tonneau; acetoned badges; rear vision camera & reverse sensors; KC backup lights; C-Betr mirrors; cab lights & fender lights wired as turn signals; LED ID bar; Jordan 2020 Ultima trailer brake; harpoon mod; and more
D_Dunn is offline
Old 10-29-2006, 09:17 PM   #10 (permalink)
Jeff,
Hope this helps...
Dan
If you could check which terminals you jumped, I'd really appreciate it. I checked and the 'relay' is in the same place as where you describe (only the relay is not there). I'd like to get a relay at some point, but for now, jumping the terminals would work for what I need this coming weekend.
Thanks again,
Jeff
Old 10-30-2006, 10:16 AM   #11 (permalink)
The relay is not expensive and any good parts store should have it.
Trailer Tow Package Relay
There should be two relays in the box beside the under hood fuse panel.
'00 F250 CC SWB 4x2 XLT V-10 Auto 3.73LS Silver/Graphite
Sport is offline
Old 10-30-2006, 11:37 AM   #12 (permalink)
D_Dunn's Avatar
My Photos: (28)
Jeff,
Hope this helps...
Dan
Thanks again,
Jeff
Jeff,
I have the info you requested. The jumper is between where terminals 87 and 30 of the relay would plug in. One is closest to the brake master cylinder and the other is closest to the Power Distribution Box. Does that make sense? Let me know if you need any more help...
Dan
My Truck Pics
D_Dunn is offline
Old 10-30-2006, 03:10 PM   #13 (permalink)
Excellent, thanks.
Dan, thanks for checking on the jumper. If I can get the relay for cheap, I'm gonna go that route. Otherwise, I'll be trying out the jumper solution.
Thanks again guys!
Old 10-30-2006, 05:38 PM   #14 (permalink)
Thanks everyone. I used the number from the link Sport provided. Napa was able to cross reference the relay to one they had in stock. I installed the relay and with the key on I've got power to the 12v pin.
The kids in the band will thank you all this weekend!
Jeff
Old 10-30-2006, 10:22 PM   #15 (permalink)
D_Dunn's Avatar
My Photos: (28)
Jeff,
Just remember that the reason that I replaced the relay with the jumper was to get 12V to the pin when the key is off. As Tobi mentioned above, the pin will be hot only with the key on if you install the relay. I pull a trailer for our local high school marching band too and it's nice to be able to use the lights without having to have the key on. Just so you know...
Dan
My Truck Pics
D_Dunn is offline
