No power to 12V constant pin - Page 2 - Diesel Forum - TheDieselStop.com
Old 10-30-2006, 10:48 PM   #16 (permalink)
Re: No power to 12V constant pin
Jeff,
Just remember that the reason that I replaced the relay with the jumper was to get 12V to the pin when the key is off. As Tobi mentioned above, the pin will be hot only with the key on if you install the relay. I pull a trailer for our local high school marching band too and it's nice to be able to use the lights without having to have the key on. Just so you know...
Dan
Thanks, Dan.
Yeah, I've got this thread saved, for future use. I wanted to go ahead and get the relay because I've been looking at a breakaway setup that will charge off that lead. I figure it makes sense to have the relay if it keeps power from feeding back to the truck and causing issues. We're also looking into travel trailer, so I may want the relay for that, too.
What I'm thinking I'm going to play with, given the info you provided, is an override switch that will feed power to the relay when the key is off. That way I get the best of both worlds.
We've got our last contest this weekend, so I'll live with having the key on this time. I've got the winter and spring to figure out the rest.
Thanks again,
Jeff
khokhonutt is offline
Old 10-31-2006, 11:26 AM   #17 (permalink)
D_Dunn's Avatar
My Photos: (28)
No problem, Jeff. I'm glad I could help.
Dan
My Truck Pics
2000 F-350 Lariat 4x4 Crewcab longbed dually PSD 6 speed with: DP Tuner F5 16-pos. chip; Ford AIS air intake with fender sleeve & Zoodad mod; ITP boost regulator; fumoto valve; DPPI MBRP 4" turbo-back "cool duals" exhaust and 5x18 ITP stainless tips; Triple gauge A-pillar with Isspro EV gauges; "wicked wheel"; AIH delete plug with code eliminator and boost hookup; intercooler foil wrap removed; LED taillight mod, clear headlights, corner lights, cab lights, & dually fender lights; front-mounted 2" receiver, Putco Bossboards; Pace Edwards rolltop tonneau; acetoned badges; rear vision camera & reverse sensors; KC backup lights; C-Betr mirrors; cab lights & fender lights wired as turn signals; LED ID bar; Jordan 2020 Ultima trailer brake; harpoon mod; and more
D_Dunn is offline
Old 11-03-2006, 12:22 PM   #18 (permalink)
Jeff,
I replaced the relay with a jumper to get a constant 12 volt feed to the "+" terminal of the 7 pin plug. I made the jumper from a piece of heavy guage wire with spade terminals on each end. I used a test light to determine where to plug it in. This is a pretty simple mod to get a constant 12V to the rear of the truck.
Hope this helps...
Dan
The reason Ford uses the relay is to keep someone from leaving something on in the trailer/camper and draining your batteries. If you hard wire it, you can end up with dead battries [img]/ubbthreads/images/graemlins/blush.gif[/img] if you are not real careful. If the band trailer is the only aplication you have that pulls current from that pin you are probably ok but if you have other trailers/campers with a 12 charge/acc connection you may get yourself in trouble with always hot.
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
rubystargoats is offline
Old 11-06-2006, 08:50 PM   #19 (permalink)
D_Dunn's Avatar
My Photos: (28)
Jeff,
Hope this helps...
Dan
Rubystargoats,
I am aware of that, but I appreciate your concern. I have three different trailers I pull, and none have a charging system. I used to have a 5th wheel which did, but we sold it last year [img]/ubbthreads/images/graemlins/frown.gif[/img].
Dan
My Truck Pics
D_Dunn is offline
Old 11-06-2006, 09:13 PM   #20 (permalink)
Dick Cutting's Avatar
My Photos: (27)
Did you check fuse #115 to see if it's OK?? I believe that is the correct fuse number. Maybe it's 112. I had one blown in my '02 and the lights in my trailer did not work just like you found on your trailer.
It's one of those special square fuses. Blue in color. 15 amp I think. They are a whole lot more expensive than the regular blade fuses. I converted that fuse on my truck to the blade type just because of that expense.
Dick
TheDieselStop.Com Moderator & Photo Editor
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, Currently 2/2012 - 266K+ miles
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD, Currently 2/2012 - >183K+ miles
Dick Cutting is offline
Old 10-21-2009, 10:19 PM   #21 (permalink)
Just wanted to say thanks a million for this post! I couldn't figure out why my 12v+ wouldn't work even with the fuse in. 1 $11 relay later it works!
-kb
-2000 F250 x-cab sb 4wd; dp tuner f5, magnaflow exhaust, ais intake, john woods valve body; 18k original miles!
-1997 F250 PSD, 4L10, E4OD, 10k mod, Cali shim to 80 lbs, Tymar HPX crossover, K&N air filter, Sonnax Valve & Tricumulator, Banks Transcommand /// SOLD 2004
-1973 Bronco Kenne Bell Supercharged/Fuel Injected 5.0, 700R4, AtlasII, Detroit/ARB w/ 5.13's, Full-Width Axles, 35" MTR's, AGR close-ratio box/pump, Tom Woods l/t driveshafts /// SOLD 2005
Kincade is offline
Old 10-26-2009, 02:32 PM   #22 (permalink)
can someone provide the part #? i can't get yo it from Sports link..
Thx
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-27-2009, 11:55 PM   #23 (permalink)
Anyone????
TXANGLER is offline
Old 07-24-2010, 12:52 AM   #24 (permalink)
12 volt power relay
I'm having similar problems with my truck. I've located the relay and it is working because I can hear it clicking off and on. I thought maybe it was burned out so I used a jumper and I still have no power at the plug. Are there any other connections or areas that could be causing problems?
Please help. I'm about to pull my hair out. This is really aggravating.
cfed is offline
