The pin that charges the trailer battery in my 7 pin plug does not have any power to it. the wire goes into the plug and the fuse is not blown.
I am going to start tracing the wire, does anyone know the typical area were the wire may be cut or not connected?
Thanks Kevin
Kevin, Central New York,2001 F-250 7.3L PSD Auto 4X4 CC,SB,LARIAT,All the bell & whistles.
170,563 mi. and counting
ZooDad,_Walker BTM__
285/75R16 BFG All Terrian TA KO's
Now Running on MY home brew B80
While the weather was warm I'll was running all "B" and no "P"
Could sound simple, but did you have the key to the run position (truck running) when you checked?
EDIT... Also you have a relay for charging.
I am Fordless, SOLD>>> 1999 F350 XLT 7.3 SD SC DRW 4:10 LS Auto Trans 4x4 Auto Hubs APC Telescoppic Heated Power Tow Mirrors K&N Filter Banks 3 1/2 down pipe ATS 4" exhaust 3 gauge (ET, trans temp, turbo boost) pillar mount WD Chip WD Turbo Brake
That was going to be my suggestion. Sometimes it will only charge when the tow rig is running.
I always change mine so it will charge all the time.
I bought the truck used, It hasn't worked since I have owned it.
Check the fuses under hood on drivers side
He said in his 1st post "the fuse is not blown".
In addition to a Trailer fuse, there is also a trailer relay, I believe it plugs in next to the under hood fuse box in a separate receptacle attached to the fuse box.
I had a chance to look at the truck tonight, and here is the what I found. Next to the power dist. box on the driver's side under the hood. there are two smaller boxes, I found one closest to the fire wall to be empty
it should have two relays in it, they power the trailer battery charge pin and the other I believe is for trailer b/u lights.
Thank you all for the help
Kevin [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
