No Trailer Brakes?!?! - Diesel Forum - TheDieselStop.com
Old 11-12-2009, 01:23 AM   #1 (permalink)
Ipolute's Avatar
Hi
i have the built in trailer brakes on my truck... i hooked up a 30ft flatbed trailer loaded with four wheelers and headed down the road to find out that the brakes on the trailer werent working... My buddy towed it before me and says they worked fine on his truck... so that leads me to believe its something with my truck...the question i have is how can i fix this... and quick ... we are leaving friday... i believe i checked the right fuses and they seem to be fine... HELP!!! thanks
2005 F350 Lariat 4x4 6.0 Crew Cab
BFGoodrich Mud-Terrain KM2 35 x 12.5
Leveling kit
8k HIDs w/fog lights
Recon Side Markers(Smoked)
Recon Roof Lights(Smoked)
Harley Davidson Headlights
White L.E.D lights (Parking and Roof lights)
DieselSite Coolant Filter
3.5 Inch straight Exhuast.
Bully Dog Triple Dog w/outlook monitor
Cobra XRS R9G Radar Detector
Sinister EGR Cooler "fix"
.....At the Track..... http://www.youtube.com/watch?v=vMiWo6i5ZVA
Ipolute is offline
Old 11-12-2009, 04:10 AM   #2 (permalink)
Does your TBC have the green trailer icon -meaning properly connected or the red icon?
What is the gain set at?
Did you test the trailer brakes manually (using the TBC)?
slowflyer is offline
Old 11-19-2009, 09:40 AM   #3 (permalink)
There are some pretty good troubleshooters. Hope this helps
Dexter Axle - Trailer Axles and Running Gear Components - RESOURCE LIBRARY
dorlia2 is offline
Old 11-26-2009, 04:02 PM   #4 (permalink)
Check the connection from truck to trailer, I just scraped a bunch of corrosion out of mine (on the truck side) for my trailer brakes to work. Good luck
SOLD: 2007 F250 XL, 6 SPEED, 6.0 L Diesel, 107K.
SOLD: 1999 F250 XLT, 6 Speed, 7.3 L Diesel, 66K.
justinmelin is offline
Old 11-26-2009, 04:10 PM   #5 (permalink)
I had to run larger brake wires on my trailer. I could put the controller on 10 and one wheel would barely work. Since I rewired it works great. Had someone tell me they ran larger wires on their truck. The longer and heavier trailers pull too many amps through the small wires.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 11-26-2009, 04:18 PM   #6 (permalink)
RatherBNtheWoods's Avatar
I believe the wires on the truck are sufficient. I pull a tandem axle utility trailer behind my 5er and all 5 axles work well.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 12-10-2009, 01:10 PM   #7 (permalink)
Ipolute's Avatar
it turns out it was the brakes on the trailer.... we all thought they were good but we actually looked at em and they were gone... thanks for all the input
Leveling kit
Ipolute is offline
