Old 10-30-2007, 10:16 AM   #1 (permalink)
Not even a "hiccup" towing 21,500lbs
I just got back from towing a 43 foot long Teton Homes fifth wheel to Casper, WY from Maryland and back. Ran the rig across the CAT scales, GCWR was 30,450. Fuel mileage while towing was from 6.8 in the mountains to 8.5-9.4 on the flats of Nebraska. Did not burn a drop of oil, no coolant loss, not one issue with the truck. The truck handled the big trailer great. Tow/haul worked as advertised, never overspeeded coming down 7% grades. Transmission shifted smoothly, never hunted for the right gear. Only issue I had was with the Continental tires trying to follow the worn roadway grooves on the worst roads. Seats were very comfortable, Audiophile/Sirius well worth the money. Truck road great even with over 6,000lbs on the pin. Reese Signature Series hitch worked very well, positive latch-up and no "chucking" issues. When I got home, I crawled under the truck, no wet bellhousing, no nothing, just a wonderful truck. Thanks Ford!
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 10-30-2007, 10:24 AM   #2 (permalink)
Re: Not even a "hiccup" towing 21,500lbs
Right on, great news finally from a big tow on a F450. Lets hope for many more.
2008 F-250 Lariat 4x4, 6.4L, 4 tires, brakes, windshield, windshield wipers, tailgate, bumpers, blinkers, headlights, spare tire, rear bumper, hood, antenna, driver AND passenger seats, speedometer, radio, steering wheel, & spare set of keys!
Hydro is offline
Old 10-30-2007, 12:21 PM   #3 (permalink)
Where the heck did you find 7% grades on that trip?
Larryfb is offline
Old 10-30-2007, 12:54 PM   #4 (permalink)
Dieselgem's Avatar
My Photos: (14)
Hey Capt did not see this post and just sent you a PM. Glad to hear everything went well for you.
2008 F450- Truck Pictures
2008-41'CKS KZ Escalade Toyhauler
Toy Hauler Pictures
Dieselgem is offline
Old 10-30-2007, 01:37 PM   #5 (permalink)
The only problem I have to say is, it is pretty bad when Ford has made a reputation for itself that when someone actually works one of their trucks that they are happy that after one long trip they can say no leaks under the truck. That is pretty sad for ford sake. I would hope after spending $50,000+ you can take that truck and pull one time with it and not have any leaks. I guess that is better than some people with the 6.0s that will go though a list of problems and then say that they still love their truck and that it is normal for all the things to go wrong within the first 50,000 miles or so.
BIGBEN2004 is offline
Old 10-30-2007, 02:19 PM   #6 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BIGBEN2004</div><div class="ubbcode-body">The only problem I have to say is, it is pretty bad when Ford has made a reputation for itself that when someone actually works one of their trucks that they are happy that after one long trip they can say no leaks under the truck. That is pretty sad for ford sake. I would hope after spending $50,000+ you can take that truck and pull one time with it and not have any leaks. I guess that is better than some people with the 6.0s that will go though a list of problems and then say that they still love their truck and that it is normal for all the things to go wrong within the first 50,000 miles or so. </div></div>
Sad but true, and the reality of it. I am not going to brag about my '06 Dodge not skipping a beat. It's 15 months old and 21,000 miles. It SHOULDN'T have problems (and it doesn't just to clarify).
UApilot
2008 Dodge QuadCab 2500 Big Horn, CTD, 4x4, auto, tube steps, clearance lights, on-board air, air horns, air-ride coming
2006 KTM 950 Adventure S
http://community.webshots.com/user/cumminspower
UApilot is offline
Old 10-30-2007, 02:46 PM   #7 (permalink)
Capt,
How many miles are on your truck right now?
Also, tires cause a vehicle to veer differently on different surfaces? I figured that sort of thing would be left to alignment?
Nate
NatesDiesel is offline
Old 10-30-2007, 03:56 PM   #8 (permalink)
MDarrough's Avatar
My Photos: (18)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: NatesDiesel</div><div class="ubbcode-body">tires cause a vehicle to veer differently on different surfaces? Nate </div></div>
Absolutely. My wife used to have an Expedition that came with Conti tires and they were horrible. Any kind of crack in the road, or even just grooves would "steer" the vehicle.
Mark
'08 F-350 CC 4X4 Lariat, SRW, Dark Blue Pearl w/Silver trim, every option but Nav and moonroof.
Ordered 10/16 - Born 11/14 - delivered 11/26
pic
Pulling a 2008 Jayco Eagle 5er - pic
SOLD - '01 F-350 - pic
MDarrough is offline
Old 10-30-2007, 04:10 PM   #9 (permalink)
KINGTUT's Avatar
My Photos: (19)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: UApilot</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BIGBEN2004</div><div class="ubbcode-body">The only problem I have to say is, it is pretty bad when Ford has made a reputation for itself that when someone actually works one of their trucks that they are happy that after one long trip they can say no leaks under the truck. That is pretty sad for ford sake. I would hope after spending $50,000+ you can take that truck and pull one time with it and not have any leaks. I guess that is better than some people with the 6.0s that will go though a list of problems and then say that they still love their truck and that it is normal for all the things to go wrong within the first 50,000 miles or so. </div></div>
Sad but true, and the reality of it. I am not going to brag about my '06 Dodge not skipping a beat. It's 15 months old and 21,000 miles. It SHOULDN'T have problems (and it doesn't just to clarify). </div></div>
I will only add that folks should be as receptive to problem posts by owners just as they are to "feel good" posts like this one. Both are ok by me and helpful.
KINGTUT is offline
Old 10-30-2007, 04:14 PM   #10 (permalink)
guardrail22's Avatar
Continentals on the truck of the trailer?
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
New Truck
http://www.f150online.com/galleries/....cfm?num=15052
Traded In Nov 07: 2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
http://www.f150online.com/galleries/...w.cfm?num=3016
guardrail22 is offline
Old 10-30-2007, 05:02 PM   #11 (permalink)
If you had on 08 Dodge/Cummins you might think twice about your last post...
Capt, great to hear the trip went smoothly!
Sold 7/02/01 2000 F350 XLT CC, 4x4 3.73 LS, Off Road Camper. graphite int, 6 spd. Ox.White, J&J Grill & lighted boards, 10k FEY Drop bumper,(Centurion conversion) 12k Reese receiver. 285's. Duke's Springsteen. (DAC3)
Need me a 7.3 is offline
Old 10-30-2007, 09:13 PM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MDarrough</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: NatesDiesel</div><div class="ubbcode-body">tires cause a vehicle to veer differently on different surfaces? Nate </div></div>
Mark </div></div>
Interesting. Would this be from a rubber that is too soft? Perhaps tread that is too "high" or "deep" if you will?
I have always been a "Michelin Man" (but thankfully, I am not rotund like the "real" Michelin Man).
Are Continental Cheaper or something? Made in China? Etc Etc.
Nate
Old 10-30-2007, 09:23 PM   #13 (permalink)
Mark </div></div>
I would agree, when I bought my truck it had some cheap tires and it caught the cracks, got new Michelins and was noticeably better and still is with 25k on the tires.
2000 F-250 Ex-Cab Shorty - 4x4 - 7.3l - Auto - CAT ELC - 203* - Dieselsite Coolant Filter - AIH Delete - ITP HPX - Bilsteins - Walker BTM - Ford Severe AIS - CCV Canister - SCMT 1700 - Harpooned Tank w/ ITP Pre-Pump Kit - 312k
My truck pics
Check out my 1964 Toyota FJ40 Build
tjsulli790 is online now
Old 10-30-2007, 09:23 PM   #14 (permalink)
So I should go ahead and sell my new Ford truck before it starts leaking all over the asphalt?
'08 F-450 Lariat Hybrid towing a 32 ft. Vintage Outlaw trailer with a '69 Chevelle drag car inside
White Trash with Money
Zullo is offline
Old 10-30-2007, 10:50 PM   #15 (permalink)
Hey Capt....are you using the integrated brake controller with your electric/hydraulic/disc brakes....& if so, what do you think? thanx dan
2001 F-350 CC 4x4 7.3L 4R100 SRW
3/13/2001 build date
2005 F-350 CC 4x4 Lariot 6.0 DRW Tow Boss
5/3/2005 Build Date
DQDanny is offline
