Can I use a 08 F250 diesel as an hot shot truck in the oil field. I have an oppurtunity to do so but Iam wondering if this truck is to small to haul a 40ft gooseneck with around 13000 pounds?
i think thats pushing the weights it would need to be a light hitch weight with a tri axle trailer and brakes on all axles (youll be over but many fvers are too)
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
Thanks!
Marc
Well, not for long. And as stated, "gn with 13k lbs", meaing 9-10 tons?
Thanks!
Marc
Is the trailer total 13k or the load only 13k? You would be better off with a dually, but the 250 will do it. for how long, who knows.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
I live in the middle of the Permian Basin oil patch. There are several "hot shot" trucking companies around here. The successful oil-field trucking industry companies will have several sizes of trucks, but all of them use as a minimum a "one ton dually" as the tow vehicle. And the trailers towed by the pickups are almost always BigTex 40' dual tandam gooseneck trailers with two 10k axles.
The only time an SRW pickup is used is when the last available dually broke down and they have an emergency call to get a lightweight gizmo to the drilling rig in a jiffy. In that case, they might use the bosses' wife's personal King Ranch F-250. But when they buy a "company" truck, it's a dually.
