Oil Temp while towing - Diesel Forum - TheDieselStop.com
Old 04-16-2006, 03:11 PM   #1 (permalink)
I have an oil temp gauge that is ran to the back of the block coming off of a port. I've noticed that even while not towing that hit seems to get real close to around 210. While towing my traveltrailer this wekend it hit upwatds of around 230. That seems a little warm to me. Don't these trucks come with oil coolers on them?? I haven't gotten under to look for one yet. I just assummed it was there. I'm If I do need to add one what would be a good one that would work good while towing. My trailer is around 9000lbs when loaded down. Thanks.
2008 F-350 King Ranch CC LWB 4x4
Neal_P is offline
Old 04-21-2006, 02:43 PM   #2 (permalink)
My Photos: (23)
Re: Oil Temp while towing
Doesn't sound like a problem to me [img]/ubbthreads/images/graemlins/shrug.gif[/img]
The engine runs about the same temp, so there should be no problem at all.
The only issue I could see is the mods you did are making the EGT's higher, in turn making the motor run hotter..thus making the oil warmer.
My '00 F350 DRW CC PSD pulled 14K for two years and never a glitch, it was all stock.
THE ORIGINAL "FREIGHTRAIN"
1959 B61 Mack...15 gears of twin stick, black smoke huffin' fun
1967 F100 LB....352 ci/4 spd, nice daily runner
1969 F100 SB.....428 cubic inches of dual quad, 4 speed terror.
1964 Galaxie......390 cubic inches of blown big block...with a 4 speed
1964 Galaxie Country Sedan Wagon.....428 ci and 5 speeds of wheelstanding race car
40ft Haulmark trailer..for the car, quad, AND kitchen sink
FOKISD MEMBER
ATHS MEMBER
....old trucks RULE!
Freightrain is offline
Old 04-21-2006, 10:24 PM   #3 (permalink)
SoB
SoB's Avatar
Mine has always been 210 around town and 240 towing a trailer of about 7000 lbs.
Black '96 F250 XLT 4x4 SC,LB,7.3L PSD,Suncoast E4OD,3:55 Gears,Tymar Intake,4"exhaust,Hypermax intercooler,H2E,CPR Fuel,DIY StageII's, Wildman 4 position chip,Tymar HX mod,Adrenaline HPOP,Ranch Hand Bumpers F&R, Warn 12000LB Winch,305 70R16 MTR's,Oil,Tranny&Pyro pillar mounted, 328K
SoB is offline
Old 04-22-2006, 01:46 PM   #4 (permalink)
I have had an oil temp sensor on mine for sometime. I pull a 12.5K 5er. My GCW is 19.5K. The sensor is in the port beside the OEM oil filter. At cruise it sits at 190*. When working hard, it will go up to 210* I have never seen it higher. The coolant temp seems to be in lockstep about 10* cooler FWIW
jgr
2000 F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Scan gauge II, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, 40 gal. aux tank, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
pristine is offline
Old 04-22-2006, 06:25 PM   #5 (permalink)
The oil cooler is internal.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Stewey is offline
