older utility trailer bouncing - Diesel Forum - TheDieselStop.com
Old 09-27-2009, 11:38 PM   #1 (permalink)
I bought a seemingly well built utility trailer that I found parked in the backyard of an elderly couple. It has a mobile home axle and leaf spring set up on it. The tires are worn out pretty fierce. One tire had been flat for about a year when I found my yard treasure. We aired it up and brought it home, but every time I use it, it is ok after about 15 mph and then at about 40 mph, it gets stupidly bouncy. After about 50mph it smooths back out. The trailer sits very high. So high infact that when attached to the pulling vehicle, it's tongue is lower than it's back. Someone told me this is why it bounces so badly. I feel that the reasons behind the bounce are 1) mobile home tires are shot and 2) the leaf spring is too "heavy" of a spring for the unloaded trailer. Does the angle of the trailer during pull effect the amount of bounce? MH tires are like $125 apiece...should I look into a non MH 3500lbs axle and 15" rims?
cphines is offline
Old 09-27-2009, 11:50 PM   #2 (permalink)
Your right about the "mono trailer leaf spring" being too stiff for your empty trailer. You can retro fit RV springs to the mobile home axle and mounts.
Depending on age of the mobile home axle, you may be ahead getting a normal axle and springs. If the axles are over 20 years old (with the five on five and a half bolt pattern), you should have replaceable/serviceable wheel bearings. Newer axles don't. You can also use some Ford/IH wheels on it.
Good luck
05 F350 Lariet SC 4x4 6.0/auto lgbox Toyo AT's, bilsteins, on board air with airbags & air horns
gmoore is offline
Old 09-28-2009, 08:30 AM   #3 (permalink)
88beast's Avatar
id replace it with an 8 lug axle and run the same rims/tires as the truck and then mount a spare to the frame and then you have spares
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 09-29-2009, 03:12 PM   #4 (permalink)
You might also try balancing the tires too.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
