opinions on electric/hydraulic disc trailer brakes
I'm looking at an older flatbed tandem dual gn. Newer 12k axles were retrofitted and they have hydraulic disc brakes. The electric over hydraulic system was retrofitted.
Anyone have experience with this braking system? Anything I should look out for? Do the DOT inspectors have issues with these retrofits?
Re: opinions on electric/hydraulic disc trailer brakes
I would call this an upgrade instead of a refit, especially the discs as they are so much better than drums. The hydraulic unit was needed for the discs and is an upgrade over electric brakes.
I wish that I could afford to upgrade my fifth wheel like this but it's not cheap. DOT never has a problem with upgrading the brakes to a better system.
I do not haul commercial so I have not had to deal with DOT, but my horse trailer has a GVWR of 23,000# and I had the 8K Dexter axles with their disc brake system installed. With the BrakeSmart controller, the hydraulic pump has a very short lag before you feel actuation and the trailer brakes alone will put you through the windshield. Definite improvement over any electric brakes I have driven. Maximum load in this trailer has been about 18K # and braking was very secure. I had no qualms driving down some pretty steep grades (I75 Northbound from KY into Cincinnati, OH and the like).
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
I have electric over hydraulic disc brakes(three axles) on our new Teton. They are the best option you can get. That trailer weighs over 22,000lbs, hitched to the truck easily 30,000. The brakes will stop both the trailer and the truck on a dime. I just wish Ford's Tow Command would work with this system. Hoping for in the '07-'08 models.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck http://community.webshots.com/user/C...host=community
I up-graded my 5th wheel to Electric-Hydraulic disk brakes and am very happy. The up-grade was a weekend project. I would spend the money again in a heartbeat. I don’t understand the 2-3 second delay comment. The actuator I got has a 300 milla-second response time. This means that it will go from 0 to 1600 psi in less then 1/3 of a second. In effect it means I can lock up the brake in less than 27 feet at 60 MPH and have done it. I also have a BrakeSmart controller. I think that in its self has a lot to do with better braking as it made a significant improvement with the electric drum brakes.
1989 F250 4X2 Super Cab 7.3 idi Sidewinder Banks Turbo and exhaust system 5 speed 4.10 gears, US Gear Diesel Exhaust Brake, Fuel Transfer Main Tank
the comment about the 2-3 second delay came from my past experience.
now, i am not using a brakesmart, thought i would like to have one in the trucks. it may be that the hydraulic pressure is not as grabby as the electric brakes, so you don't notice the brakes being applied.
it could have been the setting on my controller, because it does allow you do set the delay.
it would be interesting to see if the delay is due to my controllers, or the trailer. the 45' trailer is usually behind the 04 550, but when i picked it up from the mfg, it was behind the 03 3500. it acts the same with both of my trucks.
[/ QUOTE ]That depends on the hydraulic actuator/pump. Some may have a faster response than others.
I have the MasterBrake Elecdraulic actuator (sounds like what you have) with BrakeSmart controller, and the delay is absolutely un-detectable. Not only that, but the proportioning is flawless, and they can be set up for full ABS. I pull at 26k trailer with tripple Dexter 8k torsion axles, and it was the best single mod to my trailer I have ever done.
Pat
2000 F450 Lariat 4x4 tractor, Air Dog, Reg Mod, HX, bypass filter, Banks Power Elbow w/3.5 dp, no intake heat, CCV mod, AIS (w/extra hole), DI stage IIs, GP indicator LED, custom 4" exhaust, 4" USG exhaust brake, USG 0.8555 aux. trans. (shift switch in knob), custom air susp., custom alum. rear diff cover extension (dipstick & temp), Detroit locker, ESPAR D5 aux. heat, custom alum tow deck and fuel tanks, Bushwacker 1 1/2" flares, 9k winch, gin poles, Bi-Xenon in '03 Crystals, Lightforce Striker 170 (still Halogen, but VERY bright), Hella Micro DE HID fogs, KW (Isspro) instruments, more to come & lots of other diesels
I do have a MasterBrake Elecdraulic actuator. I was money well spent. I did the up-grade is two steps. I put the BrakeSmart controller on first. I took one trip with trailer with just electric brakes. There was a significant improvement with just the controller. The braking became very smooth. The old controller required full out put to have effective braking. The BrakeSmart ended up being set at 50% and was better braking. The one thing I did when I installed it was to by pass all the factory wiring. I ran new 10 gauge wiring from the batteries to controller and connector. I don’t know how much the helped.
Phase 2 was to put the MasterBrake Elecdraulic actuator and disk brakes on the trailer. After the install the controller was backed down to about 30%.[img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
I agree with you the delay is absolutely un-detectable, the proportion is flawless and was the best single modification I have ever done on my trailer. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Hate to bring a post back from way back, but is one system any better than another? I just bought a 30' GN with tandem dual 10K Dexter's with discs. It currently has a vacuum/hydraulic system, but figure the upgrade to electric/hydraulic would be worth the money spent. I am in the process of re-habbing the trailer from the ground up and want to do it all right the first time.
On a side note, how do I tell if I have 10K or 12K axles?
'97 F350 Powerstroke Turbo Diesel Dually
4" straight exhaust with 5" echo chamber, shadetree open element intake
'86 CUCV Blazer/Rock Crawler 6.2 diesel/4spd/Locked 5.13's/recentered H-1 Double Beadlocks. Crawling over one rock at a time
<font color="green">If you want the brakes to perform at their best, leave the vacuum-over-hydraulics intact.
The only advantage of electric-over-hydraulics is the fact that any truck with a plain old dime-a-dozen electric brake controller can pull the trailer.
I won't have anything on my trailers, except vacuum-over-hydraulic; they will stop, and stop quick.
What experience I have had with the electrics is a bad "lag time" from pedal application before the signal gets to the trailer brakes.
With vacuums, you will have to have the proper system on the truck; but, it is WELL worth it.
You will not need a breakaway switch, nor will you need a breakaway battery on the trailer.
I love my vacuum-over-hydraulics; the only thing better is full air. </font>
As a general rule, the weight rating that the manufacturer has given the trailer can be divided by the number of axles and this will give you the axle rating.
Look at the plate on the trailer neck and there should be a weight rating.
