Old 12-25-2006, 08:36 PM   #1 (permalink)
Sabre2th's Avatar
Parking lights lock up trailer brakes!
Hauled a load of hay for mother-in-law today (~100miles) parked my 24' gooseneck when I got there, hooked back up a few hours later and started down the road. Switched on the headlights (for safety of course..) and the brakes on both axles locked up. WTH? [img]/ubbthreads/images/graemlins/confused.gif[/img] Left the lights off on the way home and the brakes seemed to work OK. Where's the best place to start troubleshooting this problem? Truck or trailer? Ran the lights on the way there, no problem.
Thanks,
Tom
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
Drain valve repair write-up with pics
Sabre2th is offline
Old 12-25-2006, 09:14 PM   #2 (permalink)
Re: Parking lights lock up trailer brakes!
In theory, your lights should come on when you apply the trailer breaks then.
The trailer wireing should be exposed if it has an open channel frame, so start there. I'd look at both male & female plugs also, a stray strand of wire could be touching another post on the inside where the wire is screwed on. It could happen.
Are you SURE the brakes were working when you shut the lights off? Because the first thig I thought of was that you installed the plug at the wrong index. Yes, I know it has a groove to prevent that, but I have seen my parrents do it upside down and force it in, then drive 180 miles for me to see why nothing was working. DAH!
'93 Ford F250 w/ 7.3 IDI diesel (no turbo) E4od auto. SC/LB 2WD, but hey, got 3 attenas. retired government vehicle.
'26 tall T coupe on '67 scout frame w/400 Ford/C6
'00 Dodge Ram 1500 SC/SB w/318/5spd 4X4 3" SkyJacker lift 33-12.50X15 Perreli Scorpions
'01 Dodge Ram 1500 Quad cab/SB w/360/auto 4X4 NO LIFT!!! Running 33-12.50X15 Hi-Tech-Retreads with Green Diamonds (alternative to studs!) on saw blade chrome wheels.
'62 Caddy 2dr, "slammed" with air bag suspension. I can literaly set it on the ground!!!!
'48 CJ2A w/'61 over head valve engine
'77 Chevy Caprice, rare 2 door! Built 350 4 bolt mains. Weyand high ram intake, Headman Headers, dual glass pack "cop callers", TH350 with high stall converter and B&M "street/strip" kit (churps the tires hitting 3rd @ 90MPH!!!!)
'84 AC 5040 w/ loader
'71 Dodge D200 w/'69 vette 327 & powerglide
'97 Morgan built 20' tilt car hauler
'01 Morgan built 16'cattle trailer
Ford 9N
Ford 8N
JD model 40C crawler
shitface is offline
Old 12-25-2006, 09:21 PM   #3 (permalink)
One more thing. CHECK THE GROUND! It should have a ground wire in each plug and both need to be attached to the frame.
I had a truck once that was doing all kinds of crazy stuff; license plate light was blinking when turn signal was on, all the lights seemed "connected" somehow. I was puzzeled. I took it to a shop and left it, the guy told me the bed was not grounded properly, so all he did was tighten the bolts that mount it to the frame. I had trouble later and added a wire from the frame to a fender brace on the bed and never had trouble again. Now the ground is the first thing I check when I have electrical gremlins.
Ford 9N
Ford 8N
shitface is offline
Old 12-25-2006, 11:43 PM   #4 (permalink)
I second the un-grounded theory.
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 12-26-2006, 10:32 AM   #5 (permalink)
If it is not a ground, 2 chaffed wires are touching, I had this happen when the tail light wire got a hole rubbed through and contacted the brake wire that had also rubbed through.
2004 EB X 6.0 2WD, everything except 2nd row caps and 4WD, 6" Pro Comp, Hellwig rear sway bar, 285-65/20 BFG KO, Air Raid intake in factory box, MBRP cat back 4", 30% tint, color match splash guards, Prodigy, Sirius
popups4rent is offline
Old 12-26-2006, 02:41 PM   #6 (permalink)
I 3rd grounding as an issue. I had a trailer with weird lighting issues last year. Plug it into my buddies truck - worked fine. Plug it into mine all kinds weirdness. replaced my 7 pin recepticle and pig tail - still weirdness. Finally found a bad ground in the rear ramp door.
We came away with the conclusion that my buddies truck was simply providing a better ground from his chassis.
F-350 08 PSD CC Long Bed. Auto, 3.73, Dark Shadow Grey, Line-X, LT275/65R20 BFG Goodyear Wranglers, Leer Canopy. 2 German Shorthaired Pointers riding shotgun.
Stroked & Stoked is offline
Old 12-29-2006, 12:35 AM   #7 (permalink)
Had a loose wire on one of the terminals in the plug once. Lights went out, fuses blew, Oh what fun on a dark night. The trip to the lake was uneventful, this all happened on the way home on the same day.
2007 F350 6.0 CC FX4 Lariat LB DRW 4.10: Dark Stone/Arizona Beige, Camper Package.
Add-ons: Eclipse AM/FM/CD/DVD/NAV, XM SkiFi2, Bed by Cajun Coatings, WeatherTech Bugshield/Deflectors/Mats, Husky Splash Guards, 6 piece Billet Grill, Draw Tite 20k hitch, Ride-Rite bags, Air Compressor, (2) Hadley 29" Air Horns, Inverter, MBRP 4" turbo back w/ 5" angle tip, EDGE Juice/Platinum Attitude
Mods: BCP
2007 Holiday Rambler Next Level 37CK 5th Wheel Toy Hauler
3 dogs & 2 birds (Yes, they all travel with us)
mjarx is offline
Old 12-30-2006, 08:13 PM   #8 (permalink)
My Photos: (10)
Try checkiing your lights might have one shorting over to brake -turn and aplying the brakes threw the truck brake controller. but you should see the light on the controller come on. Do you have a brakeaway switch. if you do try disconecting it they go bad in the rain and fix themselfs after rain stops.
j_apetersen is offline
