Old 05-15-2006, 05:42 PM   #1 (permalink)
pick up bed on f550
does anyone have a regular dually bed on there 450 or 550. i was thinking of doing a pickup bed without extending it. and just putting stacks between the cab and the gap in the bed. any advise would be good. thank you.
97 F350, 4x4, Auto, 410's, RC, Blue,AFE Air intake sytem, Hypermax dp, no cat, 4 inch exhaust, propane, clear cab lights, cowl induction hood, hard shell toneau cover, lund visor, fiberglass steps, fisher minute mount plow,Hideway 4 corner strobes ,Superchips micro tunner off road program, 60k miles, (almost sold)
02 F550xl 4x4, psd, 488 gears, 9ft utility body, 9ft Fisher m/c plow, black, Diablo chip, 4 strobes in grill. Whelen light bar, lund visor the list goes on and on. 17k miles
06 F550, xlt, 6.0, auto, 4x4, super cab, black with a 9' flatbed. and polished alluminum wheels.
97 pwr stroke is offline
Old 05-15-2006, 08:05 PM   #2 (permalink)
Re: pick up bed on f550
also i live in NH where or how do i find someone to extend the bed to fit on my 550. would i need 2 beds to extend1? or does someone make etension pieces. thanx again for any help
Old 05-15-2006, 08:23 PM   #3 (permalink)
FINE69's Avatar
Look at the top post above this one, has pretty much all the answers for ya,
2005 F-350 4x4 Supercab, Lariat, LWB, SRW, FX4, 6.0, Auto. Oxford White/Arizona Beige. MBRP SS Turbo-back Cool Duals-Cat Delete Pipe, DieselSite coolant filter, Mag-Hytec dif cover, Royal Purple Syn. lube in axles, 325-65/R18 Nitto Terra Grapplers on Weld Evo Cheyenne-8 18x8.5 wheels. Fabtech 2" Leveling kit, Bilstein 5100's. Precision Billet grille, Lund Interceptor, Husky liners, Rhino liner, Weatherguard toolbox, 8' Western Ultramount Poly Pro snowplow, 15% tint. Built 12/04
http://community.webshots.com/user/FineFord
FINE69 is offline
Old 05-15-2006, 10:00 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
It's not a job for the faint of heart. A pickup frame and a chassis cab frame are a bunch different. There are a few outfits that will do it all for you, but they're not cheap. Figure around $5,000 if you have it done with all new parts - including paint to match your truck.
It takes a lot of fabrication to do it "right". For a while, one outfit was selling a DIY kit with everything you needed except the Dooley bed. And that kit cost over $2,000. [img]/ubbthreads/images/graemlins/frown.gif[/img]
In the list of upfitters that will add a tow body or pickup bed to a chassis cab (sticky post at the top of this forum), you'll find several upfitters that will do it. Manning is the most popular right now. Centurion has been doing it "forever". And Roll-a-Long has been at it for awhile.
The chassis cab cab-to-axle (CA) length is about 3 or 4 inches more than the CA of a pickup. So if you mount the pickup bed where the rear axle will be in the right place, you will have a 3-or-4" gap between the bed and the cab. Most of the upfitters simply add a filler piece between the cab and bed. Some enterprizing folks, including member weweld, cut the right amount out of the middle of the frame, then welded the frame back together. I've never heard of anyone adding a section to the bed to make the bed longer. But I have heard of several upfitters that design and fabricate their own pickup bed instead of using the Ford stock bed. The most famous is Fontaine Classic Traveler. http://www.fontainemod.com/ClassicTraveler.asp
The frame of a chassis cab also sticks out farther behind the rear axle than a pickup frame does. But that's no big problem - simply chop off the excess frame length at the rear of the frame.
SmokeyWren is offline
Old 05-16-2006, 12:22 AM   #5 (permalink)
My Photos: (21)
I have done it by taking 3.5" out of the frame
http://www.socaps.com/photopost/show.../500/ppuser/24
Then putting it back together
Then make the bed mounts and weld them on the frame , cut the excess off the back of the frame and few other things and it ends up like this
GENE
Gene
99 F450 CC, AT, XLT LB Shortened Frame 3.5” , John Wood Tranny & TC , Turbonetics BB , DP Tuner (live tuned), AC Injectors , Custom Intake , Idle Speed Control, Turbo Temp Monitor , 4” Down Pipe, 5” Exhaust , Isspro Gauges , Power Pedal Mod. Fuel Regulator System , Dual Fuel Tanks. White Ext , Grey Int , Alcoa 19.5 Rims Factory Center Caps , Cowl Induction Hood , Dual Highway Products Tool Boxes.
Builder and Driver of Stroked Lightning 11.519 @ 119.26 mph
Co builder of DeRanged
weweld is offline
Old 05-17-2006, 11:45 AM   #6 (permalink)
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
If I were in your position I would go for one of those really trick utility bodies that have cabinets built into the sides and are already totally set up for towing.
There's a sticky post at the top of the forum where Smokey keeps track of all the vendors. Once in a while I check the websites and drool... [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
'02 F350 Lariat CC Dually Longbed PSD 4x4 6spd
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
Foglights on with High Beams '02-'08 Superdutys
SteveRacer is offline
Old 05-17-2006, 01:04 PM   #7 (permalink)
wil
I had an F550 Crew Cab Lariat done for a guy last year by Centurion. They put a spacer between the bed and cab, and a dually pickup box. Total cost for the bed plus a bunch of extra chrome and other stuff was around $11,000.
wil is offline
Old 05-17-2006, 01:22 PM   #8 (permalink)
Centurian conversion, I bought it like this
http://members.dca.net/wally/f550/7380160-R1-049-23.jpg
But, I really wanted an aluminum flatbed...
The spacer they used isn't all that thick (3 inches?) I would think
you could contact centurion for just that part.
Or maybe put some kind of roll bar or headache rack in there.
I like the stacks idea!
Wally
As of May 1, 2006, this is what I have:
94' F250, ext cab, 4x4, Factory IDI turbo, TRANS command, K&N Air filter, straight pipe, rebuilt E40D, 179k miles (E40D died again..)
2000 F550, PSD, 4.88 rear, 4x4, auto, crew cab, centurian bed. 146k miles,
Update on 17 Nov, 2005, added Edge Evolution,
Put muffler delete pipe on in April, 2006, need to
install my gauges next.
Some F550 pics:
http://www.members.dca.net/wally/f550/
I pull a 40' 1994 Hart gooseneck horsetrailer, still have both trucks. Use the 94' IDI as
my daily driver.
one_horseman is offline
Old 05-18-2006, 01:26 AM   #9 (permalink)
My Photos: (21)
That spacer sells for $500 it is 2 side pieces of fiberglass and an aluminum top piece. A little pricey in my book [img]/ubbthreads/images/graemlins/shrug.gif[/img]
GENE
Gene
weweld is offline
