Old 08-26-2008, 11:32 PM   #1 (permalink)
Plans for Hydraulic ramps?
Does anyone have any plans or diagrams or pics to fabricate hydraulic ramps, for a 36 ft tandem trailer? The trailer has a dovetail or slope although I dont know the degree on the back. I am also interested in adding hydraulic jackstands and would appreciate any pics ,diagrams, etc. I have noticed that the larger dropdeck trailers that haul large heavy equipment usually have the shape of 1/2 of an enlongated diamond and the hydraulic cylinders appear to be the only thing that keeps the ramps from flexing while loading and unloading. I have also seen conventional ramps rigged with hydraulic cylinders also. Any thoughts,pics,info appreciated.
1989 F-250 4x4 C-6 7.3
1991 F-250 4x4 E-4OD 7.3
1989 F-350 4x4 5 speed manuel 7.3 (present project truck)
1989 F-350 4x4 E-4OD 7.3 (4 door) (future project)
John deere 450C Crawler
Ford 6610 4x4 Tractor
Diamond Rio Dump Truck
Chevy Dump Truck
International Semi
remote is offline
Old 08-27-2008, 03:14 PM   #2 (permalink)
88beast's Avatar
well it depends on the loads if its all light then id fab somin easy up if heavy id go all out
if its the thihgs in your sig id do 1/2 inch 4x4 angle with I beams and bracing but i have access to auto cadd so if you will want bluebrints or something pm me with dimmentions
ill need deck height at mounting point
slope of dovetail (should be same as ramps) but also if different slope of ramps when on level ground
helght of deck
length of cylinder youll be using
distance from mounting point of cylinder at frame to cylinder at ramp
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 08-27-2008, 09:25 PM   #3 (permalink)
My Photos: (27)
.....shape of 1/2 of an enlongated diamond and the hydraulic cylinders appear to be the only thing that keeps the ramps from flexing while loading and unloading.
Duh, took me a minute, but I know of the type you're talking about. An easier design to fab up might be the type that's a "non-jointed" ramp and the hyd cyl just raises the ramp straight upright during travel, and when loading, lowers the ramp to the ground. I drove a lo-bed semi for a number of years and it had that type. Seems like the unextended cylinders were maybe 2 1/2' long. What powered the two rams was a DynaMite (brand name) unit which is a self contained small hydraulic unit powered electrically by what looks like a starter motor which is mounted to the end it's small hyd tank. They're the type used for raising/reversing snow plows on trucks that don't have a PTO driven hyd pump setup. It worked real well on the real heavy ramps. The tricky part would be figuring out your correct ram mounting points so they went up and down smoothly. To bad you can't find one around to copy the exact design and measurements.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
