Old 03-22-2006, 10:49 AM   #1 (permalink)
Posted roads
I just heard of a guy who was nailed $50.00 for being over weight in an empty pick up on a posted road.
7000 pounds on two axles.
Never heard of such a thing.
I had too sell my F-350 PSD 6.0 [img]/ubbthreads/images/graemlins/frown.gif[/img]
I still miss it...
2000 XJ 6.5" 35s etc.
NAXJA Midwest president
www.NAXJA.org
seanR is offline
Old 03-22-2006, 11:17 AM   #2 (permalink)
My Photos: (20)
Re: Posted roads
There was a big stink about that a few years ago in LA. There are a lot of older roads up there especially in the hills that are posted and delivery trucks ignore the signs. After someone busy body complained the police cracked down and many of the ruch busy bodies that were complaining about the delivery trucks found out their SUVs were also over the limit.
I thought it was quite funny. [img]/ubbthreads/images/graemlins/grin.gif[/img]
I'm out. This place SUCKS!
thetonka is offline
Old 03-22-2006, 11:20 AM   #3 (permalink)
Re: Posted roads
Similar rules on lakeshore drive in Chicago.
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 03-22-2006, 01:37 PM   #4 (permalink)
Re: Posted roads
I suppose these rich folks are going to complain about delivery vehicles until they realize one day that they want something delivered. Too bad a US Mail truck probably doesn't exceed the limits.
Brian Elfert
belfert is offline
Old 03-22-2006, 07:52 PM   #5 (permalink)
My Photos: (5)
Re: Posted roads
I drive a fuel oil truck daily usually delivering diesel. There are roads around here that are posted with 4 ton limits. I ignore these signs and go down the road anyway. Just today I went down one that had a 4 ton limit and in an adjacent parking lot there were two LEO's parked driver sde to driver side BS'ing.
It just so happens that on this road was the place I was delivering to. Even still if it was not I would have gone down it anyway.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 03-22-2006, 10:05 PM   #6 (permalink)
My Photos: (27)
Re: Posted roads
Amazing story!
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 03-22-2006, 11:37 PM   #7 (permalink)
Re: Posted roads
I also enjoyed the story. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
ryaneverk2 is offline
Old 03-23-2006, 07:38 AM   #8 (permalink)
Re: Posted roads
I am a bridge engineer and depending on how your local government posts bridges you could be taking a BIG chance. For instance, here in Maryland the state roads are posted at what is called the operating limit. This is the maximum load that calculations indicate the bridge can handle with the least amount of a safety factor. This is done to ensure as many trucks can cross the bridges as possible. So, it is NOT a good idea to go over posted bridges. If you are a delivery truck that needs to go over a particular bridge regularly you could ask the local government to check if your particular vehicle with its maximum axle weights and spacing can safely cross the bridge.
It can be a VERY bad assumption that the postings are for no good reason.
Beast is online now
Old 03-23-2006, 07:47 AM   #9 (permalink)
Re: Posted roads
They are talking about roads posted because the frost is coming out of the ground.
01 250 PSD SC 6sp camper pkg -5.6k to 25k pot- AIS- Reese Titan - SC max tuner- Rhino lined-
73 Pinzgauer
78 toylet (chevota) cruiser 12 years of mods
05 disco (wifes car)
Overload is offline
Old 03-23-2006, 09:54 AM   #10 (permalink)
Re: Posted roads
Posted roads here in the north mean the weight limit has been reduced because the ground is soft from the melting snow and frost.
Most local roads have the weight limit down to...
7000 pounds for 2 axles with SRW
18,000 pounds for 2axles DRW
30,000 pounds for 3+ axles DRW
the only exenptions are fire engines and mikl pick up for dairy farms.
So yes, mothers new Excursion will be over loaded on a posted road.
I have since heard of two more tickets being issued to SRW pickups!
I still miss it...
www.NAXJA.org
seanR is offline
Old 03-23-2006, 01:04 PM   #11 (permalink)
Re: Posted roads
It is actually not all that uncommon. Letter-of-the-law officers will pull over 3/4 ton and larger trucks and ticket them because the empty truck weighs more than the weight limits allowed on the road. It has happened over here to some people, they were doing the same thing, complaining about delivery trucks going to their neighbors house to deliver propane. SO, they cops patrolled the area for a couple days to humor the complaintants, then ticketed the wife of the head whiner because her Hummer was over the weight limit of the road. Now the head whiner is trying to get the weight restricted lifted and/or raised so that she can drive her Hummer home. Sort of funny. I hate whiners.
A similar thing happened on my FIL's private road. The whiners decided people were driving too fast, so they installed speed bumps, against the protests of many of the residents because the road is a steep hill, and we can all imagine the results of a speed bump, on a slick road on a steep hill. Anyway, it backfired on them because now the fire department will only respond at 5 miles per hour up the road, so any emergencies will result in a fire truck going 5 MPH for about 2 miles to get to them.
Did I mention I hate whiners?
Hoss350 is offline
Old 03-23-2006, 03:44 PM   #12 (permalink)
Re: Posted roads
Hoss, stories like that really make me hate whiners even more. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Ryan Arthur
My Truck Pics
NorCal Powerstrokes
Old 03-27-2006, 11:45 PM   #13 (permalink)
Re: Posted roads
In manhattan the weight limit for a few roads like the east side drive is #5500lbs. (i think its 5500) and for a while they were ticketing suburbans and SUV's until the press got a hold of Rudy G. in his suburban motorcades. I havent heard of them enforcing this lately.
But alot of the NY parkways still have weight limits and in my local town I know we have 2-ton "no thru traffic" rules to prevent some local delivery/commercial guys from using the local streets for short cuts.
early 1999-6/98, crew cab, F250, short box, 7.3, 6 speed, 4WD, 3.73, bilsteins, AIS
12pack is offline
Old 04-16-2006, 08:50 AM   #14 (permalink)
Re: Posted roads
The best way to spot a "shortcut." Look for a "No thru trucks" sign!!!
SuperCharged is offline
Old 06-01-2006, 04:29 PM   #15 (permalink)
Re: Posted roads
Are you saying the ground under the pavement becomes soft? Or are you all talking about dirt/gravel roads?? [img]/ubbthreads/images/graemlins/shrug.gif[/img] I am from WV and have never heard of such problems.
2000 F-350 CC LB DRW Lariat
Kwik 6637, TS Performance 6 Way, Autometer Boost / Pyro, Banks Exhaust Brake w/exhaust routed to exit inside the cab
33' Puma 311QBSS 5`er
Wild and Wonderful West Virginia - Go Mounties!!!
"racing in a rice burner is like racing in the special olympics...even if you win, you're still retarded!" ~Borrowed Quote
crzybowhntr is offline
