Old 07-05-2007, 12:24 AM   #1 (permalink)
Power to trailer?
Gents,
I just bought a cargo trailer with interior lights. I am using the 7 pin plug that came with my 04 F250SD. If the truck iginition is "on" I get interior lights in the cargo van. If the truck is "off" I get no lights. Does anyone know how I can configure my truck to deliver power to the 7 pin plug even if the ignition is off?
Thanks in advance.
steve
04, F250, FX4, 6.0, crew cab, LB
4.5 edge lift;315 75 17 BFG AT;snugtop shell
stevebo55 is offline
Old 07-05-2007, 02:40 AM   #2 (permalink)
Re: Power to trailer?
Does the trailer have a battery? If your trailer has electric brakes, it should already have a battery. Perhaps you have surge brakes.
It might be easier to add a battery to the trailer that is charged by the truck when under way. This is better as it prevents you running down the truck batteries and leaving you unable to start.
John
99 F350 PSD CC DRW, BD Tranny, Fan driven tranny cooler, exhaust brake, tranny temp gauge
Titanium 29/34 Fifthwheel
HiJack 21k 4way hitch
hiljoball is offline
Old 07-05-2007, 11:27 AM   #3 (permalink)
You might check the truck side of the plug with a voltmeter to see if you have an unswitched 12v lead. If so you could bridge the switched and unswitched leads on the trailer side.
02 F350 7.3SD Crew/LB/SRW DP-F5 (stock, 60t, 80e), Fumoto valve, gauges on A-pillar, XM Radio, Happijac tiedowns
99 Jeep TJ / lockers / 37s
KVOM is offline
Old 07-05-2007, 12:12 PM   #4 (permalink)
I wouldn't think Ford would leave 12 volt active at the plug with the key off. If that was the case and you had the trailer plugged in it would/could drain the batteries on the truck... As far as I know all Makes shut that (charging power for RV batteries) 12 volt down after the key is off and also I would have to assume the 12 volt power is activated by a relay, so even to power that relay "all the time" would kill the batteries as well over time if the truck was not running.
I am Fordless, SOLD>>> 1999 F350 XLT 7.3 SD SC DRW 4:10 LS Auto Trans 4x4 Auto Hubs APC Telescoppic Heated Power Tow Mirrors K&N Filter Banks 3 1/2 down pipe ATS 4" exhaust 3 gauge (ET, trans temp, turbo boost) pillar mount WD Chip WD Turbo Brake
Steve F. is offline
