What would cause a back brake light on the truck go out? I towed my fathers enclosed trailer today and as soon as i pluged in the harness, i checked the lights my driver side light did not work. as soon as i disconected the harness the brake light works again. i think that the trailer might have a bad ground, any other thoughts?
thanks
__________________ 2000 F-250 Crew Cab Short Bed 4x4 7.3 Auto
Ballbuster Turbo, 4" Hog Exhaust, SCMT, Volant Cold Air Intake, Zoodad, Leveling Kit, 315/75/R16 Nitto Terra Grapplers, Tekonsha Brake Controller, AIH Delete, CCV, Rattler Remote Start, 600 Watt Kenwood Amp with 2-10" Rockford Fosgates, 6.0 TC & Cooler, Trans-Go Shift Kit, Autometer A- Pillar Ultra Lite Gauges: Trans/Pyro/Boost, Shaeffer's Supreme Blend Oil, Shaeffer's Soy Shield, CAT Coolant.
02 F-250 Ext. Cab Long Bed 4x4 Auto. Stock,
285/75/R16 Bridgestone AT Revos,Tekonsha Brake Controller
Sounds like you have a short to ground on the left stop/turn circuit on the trailer. Check the wiring for any spots worn and grounding to the frame, or I have also seen the wiring turn green and cause problems right inside the trailer plug.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip. My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
