Old 11-26-2005, 10:35 PM   #1 (permalink)
cgroveusa's Avatar
PRODIGY Code 5H
Anyone familiar with PRODIGY Break Controler Code 5H ?? - "Prodigy detects brake wire short during idle condition (flashing)"
27K towing with this controler with no problems till this. Brakes work on both 5'ver and Sno-Pro trailers with NO change in braking effectiveness. It flashes the code whenever plugged in...hooked up or solo...idling or driving.
I have an e-mail into Tekonsha's tech support...but until then...Any ideas where to start looking for the "break wire short"?? All thoughts welcomed.
Joe
02' F-350 XLT SRW 4x4 RC L/B PSD - DPT F5 60t/80e/120 - BTS Trans - 6.0 trans cooler - 4" turbo-back - AIS w/fender mod - AIC - Turbo-Saver - Stancor GPR - Bilsteins - Autometer Z-series - LL#8 delete - In-tank mod/pooned/pre-pump delete - Dahl 100H - Helwig Rear Sway - Reese 15k Pro - Prodigy Br Ctrl - Mag-Hytec r/d/c - Marinco Plug-In - Rhino Liner - Centramatics - Cobra 18WXSTII - Towing 04' 38' CITATION f/w 375SBS 19,600# GCW
http://community.webshots.com/user/cgroveusa
06' Mustang GT conv
SUPPORT OUR TROOPS...THANK A VET!!!
Assist Our Wounded Military:
www.injuredmarinesfund.org
cgroveusa is offline
Old 12-10-2005, 03:24 PM   #2 (permalink)
Re: PRODIGY Code 5H
I'm having the same problem with my Prodigy. I thought I'd reply to get this back up to the top. I'm looking for suggestions on what to check first. I know it's a short somewhere. It's intermittent when I hit bumps. It doesn't do it sitting in the driveway where I can check it.
99.5 F-250 4X4 CC Lariat, Edge EZ, Superior adjustable transmission pressure riser, AFE drop-in air filter.
dkwaldo is offline
Old 12-10-2005, 04:19 PM   #3 (permalink)
cgroveusa's Avatar
Re: PRODIGY Code 5H
I contacted Tekonsha's tech support and they're sending me a new one...The Prodigy has a lifetime warranty. TEKONSHA
Your symptoms sound different. Same code SH? Does it show code when NOT connected to trailer? Mine did...which told me it wasn't trailer related anyway.
If I had your symptoms I'd check out the pigtail to OEM under-dash connection...and then proceed checking all wires to rear plug.
Good luck...
Joe
06' Mustang GT conv
Old 12-10-2005, 06:00 PM   #4 (permalink)
Re: PRODIGY Code 5H
Only when plugged in and only intermittent. I'm planning on working from the tuck connection back and checking all of the connections and the grounds. I was having problems with an old controller. I replaced it with the Prodigy. The Prodigy confirms that I have a wiring or ground problem somewhere, I just can't find it. The cost of the Prodigy vs. paying for a diagnostic at a trailer shop paid for itself. I just need to find exactly where the problem is now.
dkwaldo is offline
Old 12-10-2005, 06:11 PM   #5 (permalink)
Re: PRODIGY Code 5H
I had the same code, turned out to be a short in the magnets . Replaced all four for $93.00 and all is well , great brakes and no codes. I worked on this problem for 36 hours. all magnets tested good when cold 3.2_3.6 OHMS. I pulled the trailer apart to trace blue wire, I my took my truck to the dealer to test for shorts. Try the Magnets
2002 F-250 7.3 XLT 4x4 SRW/LB/CC 3.73 LS, offroad,tow,camper package, tinted windows, white/gray int.4-speed,home-made tymar,line-x sprayed on bed liner s/r window ,pillar gages, 4" turbo back exhaust,DP-60tow/80E,BTS valve Body,6.0 trans cooler,coolant filter, Bypass oil filter,external trans filter with gauge.B&W turnover ball with companion hitch, firestone air bags.
gt984us is offline
Old 12-10-2005, 06:37 PM   #6 (permalink)
Re: PRODIGY Code 5H
Check the wires where the manufacturer hooks up the brakes. They use those quick connects and will sometimes leave a short piece of wire hang out after making the connection. This wire will sometimes be turned up and make contact with the frame and then it will show a short. It's a longshot, but it has happened to me!
Rich
rich99 is offline
Old 12-11-2005, 12:45 PM   #7 (permalink)
Re: PRODIGY Code 5H
Mine had the same thing, and it was a problem in the wire going into the axle tube. It'd short over bumps.
it's not 5H, it's SH, for SHort.
I really doubt it's the controller, you have a brake problem.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 12-22-2005, 12:47 PM   #8 (permalink)
Re: PRODIGY Code 5H
Thanks for all of the suggestions. I was finally able to get under my truck after shoulder surgery two weeks ago. The genius that wired the original brake controller for the previous owner left some exposed wires under the dash. They were touching a metal bracket. Made a trip to Seattle yesterday - no problems. Thanks again.
dkwaldo is offline
» Sponsor Links
»Garage Storage and Cabinets
