Old 06-15-2007, 09:40 AM   #1 (permalink)
PSDStu's Avatar
Prodigy Controller Question
Getting ready to install a Prodigy controller to use with my 18' equipment trailer and wanted to ask a question. I understand the process for doing the inital setup and fine tuning....but wondered if you need to do this twice.... one setup for when the trailer is empty...and then one when it's loaded.... how do y'all handle the 2 different setups?
Thanks!
97 F-250 XLT, Super Duty, PSD, Super Cab, 4x4, Long Bed, Wildman Tow Chip, Tymar Intake and 3" Downpipe, Autometer C2 Boost, Tranny, and EGT gages, towing my 23' Goose Neck Deckover trailer.
PSDStu is offline
Old 06-15-2007, 09:52 AM   #2 (permalink)
Re: Prodigy Controller Question
Thanks!
I did it on an empty trailer and when I put my IH 1066 on the trailer I just hooked up and left. Did not re-adjust anything and it seemed to stop just fine. Probably wouldn't hurt to do it with the load though, especially if you are pulling a camper or something.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline
Old 06-15-2007, 12:01 PM   #3 (permalink)
I just made the one initial setup with the trailer empty. Then I set the controller to either boost1 or boost2 depending on the load.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 06-15-2007, 12:39 PM   #4 (permalink)
jarheadatunm's Avatar
I have screwed with it a few times and found the above the way to go. I set it with my toyhauler empty and then just adjust the boost according to how much junk I am dragging (obviously this is just a guess). But also, I have yet to even go over like 5.0-5.5 when braking and that was a pretty hard one in traffic. Gotta love the Prodigy!!!
2000 F250 PSD, 4x4, Red
Banks 4" Exhaust, Big-head Wastegate, DP tuner Chip (80econ, 60 tow, 100 race...), AFE Stage II, TN .84, Spearco 6.0 retro-IC, EBPV removed, Ram-air Mod, BWD bellowed up-pipes, Trans rebuild with upgraded steels, low-stall TC and Tugger shift-kit
Mag-Hytec trans and diff covers, full gauges
jarheadatunm is offline
Old 06-15-2007, 01:58 PM   #5 (permalink)
I have a question, is the readout really showing voltage or more likely amps. It seems most everyone refers to it as voltage, but I would suspect amps would the variable factor in controlling the strength of the braking action.
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
Rick M is offline
Old 06-15-2007, 02:18 PM   #6 (permalink)
Fever's Avatar
My Photos: (9)
Send a message via ICQ to Fever
i think it is voltage...afaik the brakes don't ever see battery voltage...
2002 F-250 Super Duty Super Cab Short Box 4x4
7.3L PSD, 4R100 Automatic, 3.73 LSD Gears,
BTS Valve Body Kit, Tymar Intake, Muffler Delete,
DP Tuner F-5 (60T/80E/120R/Hi-Idle),
ISSPro A-Pilar Guages (Pyro/Boost/Trans Temp),
Powerslot Cryo Rotors/Hawk LTS pads,
285/75-16 Yokohama GeoLander A/T II Tires,
Tekonsha Prodigy Brake Controller
2006 Sunset Creek 269BH Travel Trailer
Fever is offline
Old 06-15-2007, 03:19 PM   #7 (permalink)
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
It's voltage. You're right, amperage would be a bit more useful than voltage, but it's much simpler to control the amperage by varying the voltage, than keep the voltage constant and vary the amperage. It's the number of electrons flowing through the magnet coil, or amperage, that determines the magnetic field strength and the resulting force that throws out the brake shoes against the drum liner. Voltage hints at amperage, because the magnet coil has a certain fixed resistance, and if you can maintain a higher voltage across that resistance, you know for certain the amperage that must be flowing.
The best controllers out there (like BrakeSmart or whatever it's called now) display both voltage, amperage, and a few other things ... like a Christian "motivational message of the day" if I recall. This information is really only useful for detecting problems. The actual numbers are pretty meaningless if the controller is stopping your rig well.
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
'02 F350 Lariat CC Dually Longbed PSD 4x4 6spd
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
Foglights on with High Beams '02-'08 Superdutys
SteveRacer is offline
