That prodigy controller is amazing. Last night I got her hooked up to my 13,000# fiver and and I thought for sure it wasnt working so I slammed on the brakes at 30mph and I actually heard the wheels slide!!!!
I currently have a cheaper unit that i picked up at the local auto parts store. What is the big difference?
Whiskyb
2001 F350 4X4 drw
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
300k and still given her
DP Tuner and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
IMO it is much smoother than the cheaper units I have used in the past. I had a voyager and during braking I could feel the brakes release after my truck pedal was to the top. And it seemed I was always adjusting. The prodigy is progressive so if your sitting still and hit the brakes no power goes till the guts of the unit feel you braking. I like it.
You all think your braking systems are nice. You haven't tried the Brake Smart yet. I got one of them before they had all their problems. WOW! You talk about smooth. My 5er. weighs 14K give or take a few lbs. Never a problem in over 24K towing.
Member: CO PowerStroke Club/Good Sam/Camping World-
2004 F250 Lariat 6.0 SD LB SC Wedgewood Blue Build date May 2003 with latest flash 05/26/05, 4" cat back with afe proguard 7 air filter, 50 gal. transferflo with tool box & Trax Command, LineX, "Brite Box", Pyro,Boost, &Tranny Gages "piller mount", C'Betr Mirror's, Cab Fresh Cabin Filter, Fumoto Drain Valve. Superchip Programmer, Timbrens, BrakeSmart, Garmin NUVI GPS.. Other: 2005 35ft. Gulf Stream Prairie Schooner
Just took out my old Tekonsha Voyager and put in a new Tekonsha Prodigy P3. WOW what a differnce! Smooth as silk, and I really like the boost options. Also can be switched for electric/hydraulic brakes, digital display, and troubleshooting. Best one I've ever used...
Tom
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
I am surprised at the Prodigy lovers based on my experience with heavy trailers (16-18K). I couldn't get high level braking with these trailer loads unless I went to boost 3 and adjusted the gain and then I had brake overapply the instant brake lights come on when going slow.
Dealer replaced the unit and it was the same.
I loved it with my 10-11K livestock trailer.
I wish I had gotten one that worked like so many of you say they work.
I am using the old fashioned hydraulic one tied into master cylinder and it is great. Brake pedal pressure DIRECTLY controls current to brakes at any speed or load.
Brakesmart sounds to be a good unit but I didn't want to spend that much when I had a good controller sitting on the shelf.
I did several full on test on gravel roads with sliding trucks tires and full level ABS activation and there were NO ill effects.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.88 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 feet on the floor Elite/Outlaw LQ horse trailer. Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
Hey Sabre,
Does your P3 light up every time you get in the truck? Just put mine in Monday, it's kinda' annoying having it light up w/o a trailer. I assume it's wired correctly since I used their pigtail.
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
S.S. HX(removed for now)
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges
'99 E350 Snake Oil Wagon, 200+K, doesn't burn oil, lives on the bump stops & has a hard life. Runs like new.
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
