Old 10-31-2007, 02:53 PM   #1 (permalink)
pull rateing on F350
What is the maximum weight my 2000 F350 will pull? We just bought a dozer that weighs about 27,000lbs. I think 25,000 is the rateing on my B&W hitch, but I was woundering what the truck will safely pull?
00'F350,6-speed,CC,LWB,4X4, SouthBend Con-O,AFE2,4"straightpipe,RanchHandCowCatcher,B&W-TO,Rinolined,MoreToCome
steelestrokin is offline
Old 10-31-2007, 03:49 PM   #2 (permalink)
Re: pull rateing on F350
we have an ongoing discussion on this in the towing and hauling category of this forum,Which is where this thread will end up shortly
2000 F350 dually 4x4 auto All stock for now
farmerbob is offline
Old 10-31-2007, 04:24 PM   #3 (permalink)
My Photos: (6)
remember something about max weight of a non-commercial vehicle is either 24000 or 26000?
So, if your truck weighs 9000 and the trailer weighs 5000 you only have 10000 or 12000 lbs of cargo left before you exceed the legal limit.
That said, I have heard of plenty of people pulling 25000 plus lbs, but don't get caught.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 10-31-2007, 04:51 PM   #4 (permalink)
If the dozer weighs 27,000 a good trailer to pull it will weigh at least 8000 and the truck weighs in at around 9000 that equals 44,000 pounds. Way to much for the truck.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
Old 10-31-2007, 04:57 PM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mflores</div><div class="ubbcode-body">If the dozer weighs 27,000 a good trailer to pull it will weigh at least 8000 and the truck weighs in at around 9000 that equals 44,000 pounds. Way to much for the truck. </div></div> 44,000 is too much for a 550!
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. TN .84 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,Sonnax,FT T/C,PML pan,6.0 cooler,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,untrue Truspeed,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods.
ELLIOT02 is offline
Old 10-31-2007, 08:02 PM   #6 (permalink)
Hi SS, BTW welcome to the Forums,
I agree with mflores 100%
If you want to know why, look at the last ten topics on the subject.
[img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
Old 10-31-2007, 09:46 PM   #7 (permalink)
You've got to be high dude. That is way too much for any type of light duty vehicle.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 10-31-2007, 10:26 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SteeleStrokin</div><div class="ubbcode-body">What is the maximum weight my 2000 F350 will pull? </div></div>
The truck weighs about 8,500 pounds when wet and loaded for the road. The GCWR of your pickup is 20,000 pounds. So Ford says you can safely tow a trailer that grosses about 11,500 pounds.
Your dozer is about 3 times too heavy for a one ton dually to tow. That's why most dozers that size are towed by class 8 tractors with semi trailers.
SmokeyWren is offline
Old 11-01-2007, 04:20 AM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SteeleStrokin</div><div class="ubbcode-body">What is the maximum weight my 2000 F350 will pull? </div></div>
Your dozer is about 3 times too heavy for a one ton dually to tow. That's why most dozers that size are towed by class 8 tractors with semi trailers. </div></div>So using the Ford Ranger to pull the Cat excavator is out of the ? too? [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
ELLIOT02 is offline
Old 11-01-2007, 12:22 PM   #10 (permalink)
ok, thanks for the info, just to clear things up I was not talking about heading across country, just moving between farms, ive seen D-4s moved around with heavy trailers, with ton trucks. We just got a D41P LGP Komatsu. Guess will get someone to move it for us.
I just wanted to know what the truck would pull without breaking something in the truck.
Old 11-01-2007, 06:21 PM   #11 (permalink)
You will break something in the truck!
ELLIOT02 is offline
Old 11-01-2007, 06:51 PM   #12 (permalink)
88beast's Avatar
actualy around the farm ur own stupid fault if it breaks
but if you had in theroy a 4 axle doolie trailer
and you manage a 3k hitch weight
then you could do it but idk if you will even get it moving in any mud or lose soil
if its hard packed dirt then that setup would work
but again the tranny may be in trouble so use it as last resort
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
