pulling a 5th wheel with a diesel van or diesel Excursion
Here is a neat solution that enables van and SUV owners to pull a 5th wheel or gooseneck trailer without buying a pickup. Pickup owners can also tow 5th wheels and gooseneck trailers without having a hitch use up the bed of their pickup! Pretty Neat! There are pics and info at www.tiny1.net/hitchbuddy.jpg and the manufacturer's website is www.hitch-buddy.com I've pulled a 40' 5th wheel across the U.S. with a motorcycle in the bed of the pickup and it performed GREAT! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Re: pulling a 5th wheel with a diesel van or diesel Excursion
Is thinly-veiled advertising permitted here?
Douglas Campbell [drcampbell ot engineer dat kahm]
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
Yea, this product was talked about on here about 6 months ago. Generally speaking about 95 percent of the people on here thought it was stupid and the other 5 percent thought it was fine.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
If you do use this please call and let me know where you`ll be so I can keep my family clear of the road you`ll be traveling. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2000 F-350 CC LB DRW Lariat
Kwik 6637, TS Performance 6 Way, Autometer Boost / Pyro, Banks Exhaust Brake w/exhaust routed to exit inside the cab
33' Puma 311QBSS 5`er
Wild and Wonderful West Virginia - Go Mounties!!!
"racing in a rice burner is like racing in the special olympics...even if you win, you're still retarded!" ~Borrowed Quote
I am not interested in using one of these, but I don't really see a problem with it. It seems to me that this thing is very similar (if not the same) concept of the dolly for a semi trailer. If the tow vehicle is rated properly, like a 250 / 350, I think that this wold be fine towing. I think it does look strange though.
2004 Expedition
2003 F250 C/C V10, Banks Power Pack, Transcommand, 4.30LS, MagHytec Diff Cover, B&M Deep Trans Pan, 16K Super Glide Hitch
2006 Thor Vortex 36' 5er Toy Hauler
It will get you that much more at the tolls too.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
4500 pin weight, of that what gets loaded as pin/tongue weight on the tow rigs bumper? Looks like a worst case scenario to me...9K of vehicle towing twice its weight with no load on rear axle and a seperate articulation point in the mix. Hope it works great. I wouldn't take it for free let alone 5k.
I think if you look at it, it is a rigid beam between the dolly and the tow vehicle. No added articulation point. Also, I would bet that there must be some sort of weight distribution setup that transfers weight to the rear of the tow vehicle.
2004 Expedition
I wonder what would happen when you SLAM on the brakes.
awww you dont need to stop.. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] I would pay to see that avalanche slam on the brakes with that fiver [img]/ubbthreads/images/graemlins/cool.gif[/img]
Ive seen one a few times going down I-65 I travel on daily on my daily runs. Seems to me it works pretty well. Theres no yaw sway or fish tailing, nothing. I run along side it with my rig and the tow vehicle tows pretty straight. I followed one into a truck stop. It looks to me it works pretty well. It was being towed by one of those pick up trucks that delivers new campers to dealers....Seems to me like it works well......I would not mind trying one out just to see how well it works [img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
