Old 03-28-2008, 06:55 PM   #1 (permalink)
Question Pulling a bumper pull travel trailer
See truck in sig. Question is, will I have any trouble pulling a bumper pull travel trailer (24 ft) with a lifted truck? Will stabilizer bars work, or do I pull without them?
2005 F-250 6.0L,FX4,CC,SB,Dark Shadow Grey,2" lift, 35x12.5R17 TOYO M/T's on stock wheels,Cab steps,TOFF Bedliner,Sirius,60w Infinity Reference Speakers,40w x 4 Alpine Amp,Access Rollup bedcover,ID SCT Extreme Street tune,RanchHand Legend replacement bumper,WetOkole seat covers
joerendon is offline
Old 03-29-2008, 12:11 AM   #2 (permalink)
You'll be fine with just 2' of lift. If it's a low slung trailer you might need a sizeable drop for the hitch head (I think most people call them Hi-Lo shanks). Stabilizers will work as long as you get the head low enough so the trailer is towed level. Then just the normal set up procedure for a WD system.
'05 F-250 XLT 6.0 auto CC/SB 4x4 ESOF riding on BFG Rugged Trail's. Bone stock 'cept for the Sirius radio and tonneau cover 82k miles. Turbo replaced during previous ownership. HPOP fitting let loose, recall at 75k.
joshb159 is offline
Old 04-01-2008, 08:17 PM   #3 (permalink)
Thanks for the response. So, I don't really need the stabilizer bars to tow the trailer?
Old 04-01-2008, 09:13 PM   #4 (permalink)
I guess there needs to be some clarification here... Equalizers are the spring bars that transfer weight off the hitch. Stabilizers are meant to keep sway from happening (friction type). Most new designs (reese dual cam, etc) are one in the same (equalizing while stabilizing without the added friction piece). Do you need equalizers/stabilizers? How heavy is the trailer? How much stuff are you going to pack into it? How much misc. junk is going to be in the bed of the truck? What is the Load Rating on your tires? Or you could give it a test drive and see what happens. I'd be inclined to throw some sort of equalizing at least. Makes for a smoother less bouncy ride.
joshb159 is offline
Old 04-05-2008, 05:01 PM   #5 (permalink)
Gotcha. Truck will not be loaded, and I have plenty of carrying capacity on the tires. Not sure what is weight of trailer, but it will be empty. I am just hauling it about 175 miles from San Antonio to a deer camp near Bracketville. As long as I take it easy, I think I shouldn't have any problems.
Thanks for the comments.
Old 04-05-2008, 06:45 PM   #6 (permalink)
24 feet should be a light trailer - no need of weight distribution on the hitch, you probably won't even know it's back there.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 04-06-2008, 10:15 PM   #7 (permalink)
MDarrough's Avatar
My Photos: (18)
I agree 100%.
I used to tow a 28ft TT with my '01 that had an 8" lift. No equalizer. No problemo.
Mark
'08 F-350 CC 4X4 Lariat, SRW, Dark Blue Pearl w/Silver trim, every option but Nav and moonroof.
Ordered 10/16 - Born 11/14 - delivered 11/26
pic
Pulling a 2008 Jayco Eagle 5er - pic
SOLD - '01 F-350 - pic
MDarrough is offline
Old 04-07-2008, 05:31 PM   #8 (permalink)
I always use weight distribution bars and a stabilizer bar if I am gonna tow a large bumper pull trailer any distance over a few miles. Are they needed? Maybe, maybe not, but the truck drives soo much better with them.
2001 F250, extended cab, short bed, 7.3, 6 speed,
adjustable 2-18K mod
4" turbo back exhaust
Ford Severe Duty AIS intake with fender sleve
AFE Torque Booster tube
modified IDM
ITP overboost eliminator
Beans Stage 2 split shots
AIH delete
Firestone 5,000lb air bags in the rear
leveling kit up front custom built from OEM Ford springs instead of buying aftermarket stuff
FORD ball joints modified to be greasable instead of using aftermarket stuff
clear turn signals and brake lights
IF YOU ARE GONNA MOD. IT BEFORE 100K DON'T CRY WHEN A REP. FROM FORD OR INTERNATIONAL VOIDS YOUR WARRANTY
marksuttonjr is offline
Old 04-08-2008, 07:43 AM   #9 (permalink)
DirtFarmer's Avatar
I have a 24 ft TT and I just hook it up and plug in the lights/brakes. Never used any equalizer, etc and no problems with sway, etc. I think you'll be fine.
2001 Cab and Chassis F350 SuperCab DRW 4x4. 7.3L. 6spd & manual xfer. snow plow pkg.
Home built flatbed featured on thedieselstop.com
DirtFarmer is offline
Old 04-10-2008, 06:09 PM   #10 (permalink)
Thanks to all for your responses.
Old 04-11-2008, 01:07 AM   #11 (permalink)
The "lift" doesn't really make much difference, per se, but the bigger tires gear you up, and the wider sidewalls make for more "squirm", which can amplify sway. If the trailer's light enough you can stay within your tongue weight ratings without an equalizer, you should be in pretty good shape, assuming you're sprung pretty stiff. Lift kits can vary - some are sprung pretty soft for flex, so if you get much sag, you might need the equalizers to level everything out and keep your geometry correct. They also keep your front tires a little more firmly planted (BP's lever the front of the vehicle up a certain amount, so you end up with LESS weight on the front axle than when empty, but probably not much in your case), and that can be important with big tires, also.
Copper is offline
Old 04-11-2008, 10:08 PM   #12 (permalink)
First thing to do is to loose the lift and go back to stock heights. Towing anything is basically unstable and the lift makes the truck less stable due to the higher center of gravity.
Next use a weight distributing hitch with sway control. With your truck (at stock height) and the 24' TT, a friction type will most likely do fine. A Reese Dual Cam would be a better hitch.
Ken
KE5DFR
2002 F-350 PSD CC Dually/ with 4.10 axle, and SCMT
Toting a 1979 Silver Streak, 28.5', Jordan 2020 controller and a Reese Dual Cam HP.
TXiceman is offline
Old 04-12-2008, 10:09 PM   #13 (permalink)
Btravelen's Avatar
You aren't really going to 'bumper pull' a 24ft travel trailer, are you? What you 'can' do and what you 'should' do are obviously at odds. 'Tag' trailers are highly susceptible to sway. If you're not going far or very fast, you can probably get away with it. 12- 15% tongue weight will help maintain stability.
A weight distributing hitch is not too expensive. What is your aversion to using one?
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
Old 04-19-2008, 06:20 PM   #14 (permalink)
There is no aversion to one. I am doing this as a favor. I thought that I would not be able to use the "sway bars" or equalizer or whatever since I am lifted. From what I have seen, the "sway bar" plugs into the hitch receptacle, then the trailer locks onto the ball that is part of the anti sway equalizer assembly. Again, since I am lifted, I didn't think the geometry would let me use the anti-sway bars
Old 04-20-2008, 04:23 PM   #15 (permalink)
I pulled my 30 ft Jayco loaded at about 8300 lbs from Anchorage, Alaska down to Beaumont, Texas......with a 6" lift and 37" tires.(no, I didn't regear! 3.73!!) I used a 12" drop shank to mount my ball platform on and hooked the trailer up like you would on a regular truck.
Ran about 80-90mph the whole way. Truck didn't feel "unstable" or "unsafe" as someone previously said, even on hairpin mountain roads and gravel highways, or in high wind areas of Wyoming. Sorry but I get pissed when people assume that just because you lift your truck that it becomes a useless vehicle.
Early 1999 F350 CC/LB 4x4, 7.3L, 3.73LS
*6" Lift
*315/75/16 BFG AT,
*16x10 Outlaw II's(not my favorite rim),
*Warn Hubs
*203 degree T-Stat
*lotsa lights
*Tymar HX hose
*Dual 5 inch stacks
*Tymar Intake
*Isspro guages and color matched triple pod
*Fresh beefed up 4r100 from Greene @ Quality Trans. in Anchorage Alaska
*TS 6 pos chip-no start, high idle, 50, 75, Fuel 7, 140 xtreme....
*Tymar coolant filter kit
*6.uh oh Intercooler
*Firestone RideRite 5,000lbs bags
Thanks to JIM at NORTHERN DIESEL PERFORMANCE 907-360-3933
http://home.gci.net/~northerndiesel/
Next on the list: Stage 1 or 2 injectors, BIG OIL
dslfumes is offline
