Old 02-17-2007, 10:55 PM   #1 (permalink)
Pulling travel trailer with propane on for fridge
Anyone tow while propane tanks are open to keep fridge cool? I have heard "dont do it in case of an accident" and Ive been told "dont worry about it". Just wanted everyones thoughts on it. My last trailer had a 3-way fridge and even then the 12 volt barely kept the fridge cool enough during a trip if you didnt open it, and now my current trailer only has a 2-way fridge(electric and propane).
2005 F250 6.0 PSD CC torqueshift,XLT,FX4,white, rubber floors, tow command,spray-in bed liner, Weathergaurd rv tool box, Weathergaurd PakRat tool box, Michelen HD floor mats, Rack-it lumber rack, Fumoto valve, XM, Pop-Up G/N hitch, 62,000 miles already!
1994 KDX 250
2001 TTR 225
2003 Honda Recon
1999 PW 50
1988 KD 80X
jwoops69 is offline
Old 02-17-2007, 11:15 PM   #2 (permalink)
Re: Pulling travel trailer with propane on for fridge
Don't know if this helps, but I usually turn on the fridge using electric about 24 hours before we leave to get it cold. The last thing I do before I leave is to unplug the trailer & shut off the fridge. As long as I leave the fridge closed, it stays cold. I have never used propane while driving, but I have friends that do all the time. I guess it just comes down personal preference......
2002 F350 Superduty 7.3 PSD 4X4 Crew Cab Longbed
F350Peter is offline
Old 02-17-2007, 11:34 PM   #3 (permalink)
JimTJr's Avatar
My Photos: (6)
I thought the fridge had to be VERY LEVEL for the pane to work properly? Maybe I was mistaken,,, I PERSONALY wouldnt do it, but as mentioned above, probably personal preferance. (Get it cold before, and leave it shut,,)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 02-17-2007, 11:53 PM   #4 (permalink)
I recently did it. With all power off (not plugged into house) I lit the stove to esure propane was on and piped into camper. Then, I selected propane on the fridge (2006 automatic model). I drove about 6 hours (plenty of bumbs and hills and 100 degrees outside) and the fridge performed well. I stopped en route to check it out.
I asked the service dude too. He said to use the meathod above as sometimes the ref's will get confused if the electricity is on.
06 F250 6.0 PSD 4x4 Crew Cab SB Lar
kena48 is offline
Old 02-18-2007, 12:15 AM   #5 (permalink)
I have done this many times, both ways and agree. Sometimes last minute plans screw up the plugging in and in my experiencies propane colls quicker than elaectric [img]/ubbthreads/images/graemlins/shrug.gif[/img]
It Depends. Some fridges are very anal and other seem to work no matter what.
97 F350 Crew Cab/Auto/White. Skyjacker add-a-leaf / 33 BFG all Terrains / spray-in liner / visor / Leer Cap / Runnin Boards / WARN-Manual Hubs / 4:10's / Lots a extra Lights / 10K Mod / 140K
bbess00 is offline
Old 02-18-2007, 12:28 AM   #6 (permalink)
When I grew up, our fridge only ran on propane, it wasn't fancy at all. We used it for years without any major problems while travelling. I remember it didn't alway keep things as cold as we would like, but otherwise it was fine.
Why would people expect problems? If the flame goes out, the flame sensor will shut the propane off. I don't understand why people are concerned about keeping the propane on.
'94 F250 supercab 4x4, original owner, 4.10LS, shimmed FPR, Tymar air intake, DP Tuners 80 Econo burn, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
nashvillebill is offline
Old 02-18-2007, 03:53 AM   #7 (permalink)
As a plumber, if the flame goes out the gas lines are still full of propane.
1994 KDX 250
2001 TTR 225
2003 Honda Recon
1999 PW 50
1988 KD 80X
jwoops69 is offline
Old 02-18-2007, 04:26 AM   #8 (permalink)
My Photos: (18)
Propane should be shut off at the tank BEFORE you move out.
Here are a couple of reasons:
1. Look under your trailer, most trailers are not enclosed underneath and you can easily see the propane lines underneath. Very vulnerable to road damage. Rock, crack, spark,= no trailer. We learned this the hard way when we had a trailer bearing go out and the tire caught fire, Later we found the propane line nearby partially melted!
2. Pulling into a fuel station is very dangerous with an active propane system on, be it refrig , heater or furnace. Even if you are getting diesel the fumes from a nearby gas fill CAN ignite from your unit.
I know, many of us have gone many years and thousands of mile with out a problem
BUT
Both situations above have happened with disastrous results.
gary T
2002 250SD,4x4,XLT crew,6Spd.,4"ATS exhaust,ATS housing,SP Intake,,Edge Evo, Southbend CLutch CON OFE,BD short shifter, ITP Boost Regulator, Warn Preminm Manual Hubs.
DYNO: 325 hp 728 ft lbs
garyt is offline
Old 02-18-2007, 07:46 AM   #9 (permalink)
I've owned travel trailers since 1982 and I have always towed with the refridgerator on. In cold weather I've also towed with the heater and water heater on as well. The truck is always diesel, so refueling isn't an issue.
Refridgerators need to be close to level when parked, but while moving the refridgerant sloshes around and doesn't create problems. Most owners manuals state that the refridgerators can be used off level while in transit, so the manufacturers must feel that use while travelling is safe.
Aside from driving through a cloud of ether or tailgating an open topped bulk black powder dump truck, I can't imagine a scenario that would cause the small blue flamed appliances to catch fire or explode.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 02-18-2007, 08:40 AM   #10 (permalink)
" 2. Pulling into a fuel station is very dangerous with an active propane system on, be it refrig , heater or furnace. Even if you are getting diesel the fumes from a nearby gas fill CAN ignite from your unit. "
I sure would like to see something to back that up. I don't believe it EVER happened. I do believe some people will believe anything and don't think you should try to scare people with this nonsense.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 02-18-2007, 09:38 AM   #11 (permalink)
96STROKE's Avatar
My Photos: (6)
As others have posted, I tow with fridge on and in cold weather have towed with heater on.
You need to do what makes sence to you! If you are unconfortable about towing with propane turned on, then by all means, don't do it. But for me, I like my food/beer cold when I get to my destination.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 02-18-2007, 10:51 AM   #12 (permalink)
I recently bought a truck camper with a two-way fridge and have done a lot of reading on this very subject. People take both sides of the issue, sometimes with religious fervor. You won't find a consensus.
I was told very firmly 'YES' and also 'NO' by two very nice intelligent employees of the dealership I bought mine from. My owners manual (Bigfoot) says 'no'.
My take is that I will probably do it on longer trips and where the weather is warm, especially if I plan to eat lunch from the fridge. I will try and remember to turn off the fridge before hitting the fueling station.
07 F350 4X4 XL supercab 6.0 Torqshift Lots 'o options, Line X, Isspro EGT, Trans, Voltage in overhead module, airbags, runningboards,mudguards and coolant filter.
My Pictures
DesertDave is offline
Old 02-18-2007, 11:31 AM   #13 (permalink)
If you were to break a line driving down the road there is no way that a flame could sustain itself at 60mph. Those little regulators just don't put out enough gas. More likely you would get a small leak, from a crack. that would be enough gas to make a piloit flame - no way to keep that going in a gust. That gas is at about 1/2 psi it needs a mix of 24 parts air and 1 part gas to make a good flame. 1/2 psi with a 1/2 inch pipe broke off going 60mph it will just blow out.
2000 F-250 supercab off-road 4x4 6-spd Diablo Sport chip, autometer boost & pyro, DIY Tymar, straight pipe dumping before the wheel
jprensink is offline
Old 02-18-2007, 11:50 AM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I grew up in the 1940s and 1950s on a west Texas farm. Our pickups ran on butane (LPG, which in the wintertime is butane mixed with propane). Our tractors ran on butane. Our house was heated with butane. I still have an old Massey-Ferguson farm tractor that runs only on butane. And my home furnace and water heaters and clothes dryer and kitchen range are all fired by butane. I still have a 500-gallon butane tank in the yard to supply the fuel for the house, and from which I refuel the tractor.
LPG is not nearly as dangerous as some folks make out. One day I filled a pint canning jar with liquid butane and took it to school with me to show all the city folks that butane wasn't just a gas. Yes, I was very careful that no one struck a match to light a cigarette near me. [img]/ubbthreads/images/graemlins/eek.gif[/img]
So I never turn off the LPG in my trailer except when I refill the supply bottles. And I bought my first camper with LPG tanks in 1968.
But if you want to turn yours off, be my guest.
SmokeyWren is offline
Old 02-18-2007, 12:03 PM   #15 (permalink)
I don't think going down the highway will be a problem unless the burner malfunctions and the flame grows very large in the burner unit.
The problem will be at rest IF you have a leak.
If the gas - which will pool in a low place or run along a low area - reaches an ignition source, there will be serious consequences.
Many years ago in Glenwood Springs Colorado an empty propane tank truck with a small leak was pulled into a shop with the doors open to repair the leak. Somehow enough propane leaked out and found a flame. The resulting explosion leveled a 50,000 square foot building and killed 9 people IIRC.
The other time a problem can arise is at a gas station.
Just because you are taking on diesel, doesn't mean that gasoline fumes from another nearby source cannot reach your active flame.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
» Site Navigation
» Home
