I had one and was very happy with it. The trailer tracks great and doesn't sway at all.
The downside is that it effectively lengthens your trailer by about four feet. Backing is different than with a standard hitch. It acts like a shorter tow vehicle with a longer trailer. It isn't really harder, but it is different and takes some getting used to.
On some vehicles the spare tire and exhaust need to be moved for clearance.
If you change tow vehicles you may or may not be able to move the Pull_rite to the new one. Sometimes they fit and sometimes they don't.
I had one on my old Ford Van and took it off and fabricated some new brackets for the Excursion. Towing with it is great once you get use to the way the trailer cuts on turns but the way it handles a trailer at speed and in traffic is worth the minor inconveniences. The one thing I don't care for is when you want to move the trailer over a foot or so you have to pull out of where it is parked a lot further than you would with a normal type hitch. I would highly recommend them to any one with a higher profile type trailer. If you get one a electric trailer tong jack almost becomes a necessity due to the stiffness of the weight distributing bars, you have to raise the rear of the tow vehicle and trailer tong to connect them with out dropping a nut. I have some pics of my hitch off the X in my signature.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Pullrites are good. I would go with a Hensley. You don't have to modify your truck or move it to another truck when you get a new one. Also, the hensley attatches totally to the TT, so most any vehicle can pull it.
'03 Eddie Bauer, Excursion 6.0 PSD, 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back, Hensley Arrow.
'04 TT Dutchmen 35ES-DSL, laminate sides, 3 slides, w/ Hensley.
'06 28' Enclosed Car Hauler, Dual Cam HP setup.
