Old 10-19-2007, 01:27 AM   #1 (permalink)
Send a message via ICQ to shuck
Putnam Class V Question
Does the Putnam Class V hitch for the OBS F2/350 bolt into the existing factory holes?
http://cgi.ebay.com/ebaymotors/Putnam-Cl...55353QQtcZphoto
1997 F250 CC SB 7.3 Powerstroke
shuck is offline
Old 10-19-2007, 03:38 AM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: Putnam Class V Question
No.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 10-19-2007, 12:18 PM   #3 (permalink)
Clamp the side brackets to the underside of the frame rails with Vicegrips and drill the holes into the bottom flange of the truck frame. I even made a drill pilot for the slotted holes in the hitch brackets so I could drill starter holes centered in the flange to make drilling the large 1/2" dia. holes easy.
You wouldn't want to use the factory bumper holes for a hitch. Two of the holes with threaded nut inserts only accept a 14 MM bolt, which is about 9/16" but under tremendous shear because it's so close to the other 3/4" bolt holding the bumper on. NOT a good design for carrying lots of weight.
The Putnam XDR hitch spaces the three 1/2" bolts over almost 2 ft of the back portion of the frame and the side plates are 5/16" thk steel if I remember right. I think the instructions say it takes 2 hrs to install....Took Me a bit longer than that all by myself but I'm REAL fussy about stuff. I scraped the undercoating off the frame where the bolts & brackets attached, ground the burrs off the drilled holes, re-undercoated the attachment points, etc. Make sure You get the correct sideplates on the correct sides of the truck.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Dr.Evil is offline
Old 11-26-2007, 01:27 AM   #4 (permalink)
I ended up having a local trailer shop install the hitch. I didn't have time with getting everything packed up with the move. They did a pretty good job. One of the bolts isn't 100% straight, but it's not bad - looks like they might have drilled the hole just a little off.
Anyway, the Putnam hitch worked great. I'm glad to have it on my truck now - don't have to worry about that portion of it anymore.
shuck is offline
