Where did you put your connector inside the bed on your 2008 SuperDuty. I have been thinking about doing that on mine.
Help is always appreciated.
Thanks,
DRDON
2008 F350 Lariat CC PSD 2WD Auto. 172" Dark Blue Pearl Clearcoat Metallic/Pueblo Gold 5"Chrome CabSteps Camper Pkg. HD Alt. Tow Command Upfitter Switches, 25K Air Safe Hitch, Retrax Cover, Timbrens, WOLO 120 db air horn, and more.
2007 Ameri-Camp Summit Ridge Reserve 40' 5th wheel trailer, 3/Slides, chrome wheels, Mor-ryde suspension, dual A/C, theatre system, solid surface counter tops, king bed, power jacks front/rear, 50 AMP service, sealed underside, heated tanks and more. MY PICTURES: http://good-times.webshots.com/album/558384049kmtqSi
DRDON, I mounted one of these receptacles behind the driver's side tail light. There was plenty of room for the wires, the wire from the trailer has plenty of slack and it is somewhat protected under the bed rails.
Best thing I've done so far....
2008 F-350 6.4 Job 1 SRW LWB 4x4 Lariat Crew Cab, Dark Blue Pearl/Pueblo Gold, With all options except the tailgate step and cab clearance lights.
The best place is in front of the rear fender, on the side of the bed. Some put it in a stake pocket, others just in the sidewall of the bed. The advantage of having it in front of the wheelwell is that it's easy to reach when the traailer is tied on. If it's behind the wheelwell, then you have to reach under the 5er overhang to plug and unplug the cord.
Mine is behind the wheelwell, but every time I connect the trailer I wish I had located it in front of the wheel well.
Depends on the 7-pin receptical you buy. First buy the receptical, then look at it closely to see what needs to be done to install it in the side of the bed. Some need one big hole about 1.5" diameter. Others need 3 smaller holes, one for the wiring and two others for the bolts that hold it in.
Reason: speeling
I picked up a reece 20110 to use with this and it hasn't come in yet so just trying to get everything ready for when it does get here. When it gets here I will see.
2005 F-250 Dark Toreador Red, Lariat Lux. package, 6.0 PSD, TNN0 Pcm code, Torqueshift auto trans, 4x4, ESOF, tow command, Fumoto valve, Sirius Satellite radio, Retrax bed cover, Harpoon mod, ccv mod, GOS headlight harness, Fog Light High Beam Mod, Heated mirrors upfitter #1, AIC upfitter #4, Wix Powertrap with no mass airflow sensor, Direct Injection Performance Coolant filter, Oil Guard by-pass, and Schaeffers 5w40.
Smokey is right on about placement. Mine is just inside the tailgate on the drivers side and I have to drop the gate and reach inside and underneath to plug in. Easier if all I had to do was reach over edge and plug in.
Thanks, and OH by the way, you truck looks very familiar -- check out MY PICTURES.
DRDON
Does this plug in the bed make the one under the bumper dead then? At times I use a bumper pull trailer and would not want to make the original plug in usless.
It does not render the bumper plug useless. If you buy the right kit, it is basically a pre-made splitter. The hardest part of the installation of the kit, is drilling the hole for the receptacle.
I agree with you. But here at the dealership I work at we starting mounting them behind the wheel well because alot of the 5er's with extended pins like to pull the cords out in hard turns. Its even worse with some slider hitches. Not saying all brands, but at least the brand we sell.
2008 F350 4x4 V10 C.C. 8' box. Black lariat with chrome pkg.
