Question about towing and GCWR in PA - Diesel Forum - TheDieselStop.com
Old 08-27-2006, 02:51 PM   #1 (permalink)
rdvit94's Avatar
Ok I live in Pennsylvania and my friend and I are considering doing some lite towing for some extra cash, But before we get started I want to make sure we do everything legally. So if anyone is familiar with PA laws I would appreciate some insight on what we can legally tow. I am more concerned about his truck which is 2000 Dodge ram 2500 (360 cu.) with a GCWR of 14,000 lbs. His truck weighs about 6500# empty, if he is pulling a 10k lb trailer he is obviously over the GCWR, but do DOT weigh stations check the GCWR on pickup trucks? If so, how do they know what the GCWR is being that it is not show on the registation or the door sticker? I know it is not safe to tow over the GCWR, but righ not I am just looking at the legal side of this. Also what do they check at DOT weight stations, axle weight, GVWR, GCWR, etc.?
Thanks,
Ryan
2001 F-350 XLT, CC, LWB, 4x4, Auto, Off-Road, DP-Tuner (stock-40-80-120), SP Diesel Air Intake, MBRP 4" Exhaust, Banks BHA, TAG, Dieselsite BRV, AIH Mod, 203 Stat, Sonnax/Tri Kit, Tank Mods, Redhead Steering Gear, DB Electric Starter, Di Pricol Gauges in A-Pillar, 3.5" Custom Lift, 315/75/16 BFG ATs, Delta Toolbox
Truck Pics
rdvit94 is offline
Old 08-27-2006, 09:03 PM   #2 (permalink)
My Photos: (60)
Re: Question about towing and GCWR in PA
Biggest issue will be insurance - check with your insurance company, I was looking at hauling tractors on the weekends, insurance was $500+ a month.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 08-27-2006, 10:14 PM   #3 (permalink)
You would not have to pull into weigh stations with that truck and trailer. In PA you have to pull into weigh stations if you are registered for more than 17,000 lbs.
2006 F-350 extended cab 4X4 SRW 6 speed 3.73
enginebill is offline
Old 08-27-2006, 10:16 PM   #4 (permalink)
Been Hauling In Pa for awhile now... Ive hauled close to 2 million pounds of rubbish this year, Only really been over my Gcwr 3 times this year.. was 40 lbs under Cdl requirements on one load.
But to make the story short. Never been weight Checked. But i rarely haul on the hi-ways.
2003 Svt Mustang Cobra
2003 Millenium Yellow Corvette
9.88 @ 141mph
2001 F-350 Supercab short bed, Ford AIC, Buckstop bumper, 2 80 PRO XT Piaa's, 4- 8in Explorer Pro Comp Lights, M12000 winch, K&n Fipk, Garret Gtp38R Turbo, banks power elbow, banks monster exhaust, 6.0 Litre Intercooler, Dp-Tuner 4 poisition chip 60-80 econo-120-140, Banks Six gun,PSC Ram Assist, Autometer Oil temp, Diff temp, Oil Pressure, Water temp, Intake Air temp, Tranney temp, Voltmeter, Pyrometer, Boost Gauges. 12in lift 8in Spring Packs, 3.5in hanger up front and blocked 5in Out back, Goodyear G-124's 265/70/19.5, Spitzlift crane, Snow performance water/meth injection, Suncoast triple disk converter, Tru-cool tranny cooler, Mag hytec tranny pan, 4.30's and Front and Rear Lockers. Towing the vette is FUNNN
CorvetteGuy is offline
Old 08-28-2006, 11:49 AM   #5 (permalink)
DOT determines your GCVWR by adding your truck GVWR and your trailer GVWR. If your truck is 7000lbs GVWR and you are pulling a trailer that is 10000lbs GVWR, then your GCVWR is 17,000lbs.
Early 99 F250 Reg Cab 4X4 PSD 6-speed...4" ITP DP 4" Straight Piped, ISSPRO Boost & Pyro Gauges, 2.5 inch leveling kit, 315/75 16 Coopers, 16x10 Eagles, Clamp, homemade Tymar type filter, CCV mod, H/X mod, DI BRV, boost tube, EBPV brake mod, Dynoed 236 hp 570 lb-ft at Kuaffmans 08/04, 237 hp 588 lb-ft at Kuaffmans 10/04 SOLD!!! 01/05
01 Dodge 2500 QC LB... ISSPROS, FASS, Comp tapped, 5" mitres Dyno: 339.53hp 718.86lb-ft at Kuaffmans 04/06
BIGERN is offline
Old 08-28-2006, 03:33 PM   #6 (permalink)
rdvit94's Avatar
OK, that's what thought. Thanks for the info guys.
Truck Pics
rdvit94 is offline
Old 08-29-2006, 12:11 AM   #7 (permalink)
And in pa, if you have commercial tags and have a GCWR of 17000 lbs or more, you fall into fed DOT regs. hold onto your hat, pretty soon we'll need log books too!
2007 F350 4Dr Diesel Dually Lariat, auto, 4x4, 4.10 ls., snow plow prep, loaded.
2001 7.3 - gone
1995 7.3 - gone
4drdually is offline
Old 08-29-2006, 06:03 AM   #8 (permalink)
Is that the GVWR as set by the manufacturer or the *Registered* GVWR ?
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 08-29-2006, 11:57 AM   #9 (permalink)
[/ QUOTE ]Gross Vehicle Weight Rating would be the rating as set by the manufacturer.
BIGERN is offline
Old 09-01-2006, 08:24 PM   #10 (permalink)
Yea the manufacturer rating doesnt mean squat in PA Registered Gross Weight is what counts on our roads.
9.88 @ 141mph
Old 09-03-2006, 07:06 AM   #11 (permalink)
You must register you truck as a gcwr it is not just registerd that way .I just had my truck changed to 26000gcwr the licence is like $400 now to be a combination. if your trailer is more than 10,000lbs you must register your truck as a combination in pa. also if you in buisness you will need a D.O.T # and will need a D.O.T physical card if you drive on interstate roads . my fatherinlaw just got stoped with his chevy 1 ton van and got fined for no D.O.T # posted on the truck and not having his physical card.
1999 f350 4x4 drw crew cab auto trans, DI 4 position chip, AFE II air filter,ftvb, 4"down pipe into 2 5" stacks, ww, ccv mode, autometer gauges , 124,000 miles
jdg5147 is offline
Old 09-03-2006, 12:24 PM   #12 (permalink)
i was wondering about whether they were going to need the dot number now too. Guess i need to get one.
2001 7.3 - gone
1995 7.3 - gone
Old 09-06-2006, 08:38 AM   #13 (permalink)
[/ QUOTE ]Actually if your registered in PA, they can use either Manufacturers GVWR,or Reg. GVWR. Most states won't enforce another states Registered GVWR, only Maufacturers GVWR, or if the state uses one, they can also enforce a bridge formula to determine max GVWR.
Say you are reg. and operating in PA. You are reg. in PA for 26,000lbs GCVWR, your truck has a man. GVWR of 11,000lbs. and your trailer has a man. GVWR of 12,000lbs., total of 23,000lbs. You come across the scale weighing 25,000lbs. you are over weight, even though you are registered for 26,000lbs. They may see your registration and let you go, but if they look at your manufacturer GVWR then you will be getting a ticket.
Now say you are reg. in PA. and operating in MD. MD. couldn't care less about what your reg. says, they will go by your manufacturer rating, or bridge formula.
Bridge formulas are a way to determine a vehicles GVWR or GCVWR, based on the number of axles and the wheelbase. States use different formulas so a truck could be allowed 2 different GVWR, in 2 different states, even though the truck is the same.
BIGERN is offline
Old 09-06-2006, 09:08 AM   #14 (permalink)
Whether or not you need a DOT number depends on if you are operating intrastate or interstate. I don't know what PA.'s requirements are for intrastate (operating only in PA.) DOT numbers. If you are operating interstate (in more then one state) and you are over 10,000lbs GVWR, then you must have a Federal DOT number.
BIGERN is offline
