Old 06-13-2005, 01:14 PM   #1 (permalink)
Question on trailer weight distribution?
I am going to be pulling a 27 foot Wells Cargo enclosed trailer soon, and I have some questions or would like to hear some of your experiences with weight distribution. My trailer has the axles located approximately 5/8 of the length toward the rear. I will be pulling with a 2000 F250 PSD, 2 WD. I guess I am trying to find out how much weight to put on the tongue, as it looks like it would be very easy to have excess weight on the front of the trailer, because of the location of the axles. How much is excess weight, and what should I be shooting for? When have you experienced adverse handling? Thanks in advance for advice and comments.
tjc1989 is offline
Old 06-13-2005, 01:49 PM   #2 (permalink)
jstrauss's Avatar
Re: Question on trailer weight distribution?
"Adverse handling" has only happened to me when I have had too much weight on the rear of the trailer. I like to put down as much tongue weight as my truck can stand, never had a problem when doing that.
1991 F150 SC 4.9L ZF5
1991 SAE Bronco 5.0L E4OD
1993 F250 4x4 7.3L IDI NA E4OD
jstrauss is offline
Old 06-13-2005, 02:11 PM   #3 (permalink)
Ford_Forgotton's Avatar
Send a message via ICQ to Ford_Forgotton Send a message via MSN to Ford_Forgotton Send a message via Yahoo to Ford_Forgotton
Ive read between 10 and 20 percent of the total load should be on the tongue. SO between 1,000 and 2,000 lbs if your total load is 10,000lbs.
And yes, if your too TAIL HEAVY, your asking for problems. The trailer will start to sway, and next thin you know, you've either jack-knifed, or ROLLED!
Usually, you roll. I've seen too many roll-overs from loading the rear too heavy.
Also, what is your trailer rated for? twin axles? or triple axles? 3500 or 5000lb axles?
Say you have two 5k axles (such as my 20ft enclosed has). Thats 10k of load, but the trailer weighs 3k, so really, I can only load 7k into the cargo area.
I then try to put about 1500-2000lbs on the tongue (15-20% total load, including trailer), and then use my weight distribution bars to put some of that load onto the front of the truck.
Daryl
Forgotton.net
Northwest Ford Diesel Truck Club
2000 F-350 CC SB 4X4 SRW BONE STOCK!
Ford_Forgotton is offline
Old 06-13-2005, 09:34 PM   #4 (permalink)
Probably trying to carry too many Dr. Peppers or too many buddies to see the Longhorns. [img]/ubbthreads/images/graemlins/smile.gif[/img] (Don't you ever check your e-mail?)
2004 F250 SD FX4 Lariat CC
AgeOfEmpires is offline
Old 06-14-2005, 10:09 AM   #5 (permalink)
jstrauss's Avatar
Uh, yeah, all day about every 10 minutes. You are probably being spam-filtered. Send me a PM.
jstrauss is offline
Old 06-14-2005, 11:03 AM   #6 (permalink)
I tried. It said you weren't accepting PM's.
Old 06-14-2005, 01:32 PM   #7 (permalink)
jstrauss's Avatar
You are not accepting PMs either, so that must be the default because I didn't know that was an option. I can accept PMs now, tho.
jstrauss is offline
Old 06-15-2005, 11:31 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
On a tag trailer, you want at least 10 percent of the gross trailer weight on the hitch. 12 percent is ideal. 14 to 15 percent is okay. I wouldn't go over 15 percent.
Gooseneck or 5th wheel trailer is different. Minimum of 15 percent, ideal is 18 to 20 percent, and max is 25 percent on the hitch.
Ideally, you would get ready for the trip, then weigh the wet and loaded tow vehicle, including driver and passenger(s), but without the trailer. Get the front and rear axle weights, and add them together to get gross vehicle weight (GVW).
Then hook on the trailer and weigh it again - without the weight-distribution bars hooked up. Get weights of front and rear truck axles and trailer axles.
With-trailer GVW of the tow vehicle minus no-trailer GVW of the tow vehicle = hitch weight. Hitch weight plus trailer axle weight = trailer gross weight.
Then use the numbers to be sure you have 10 percent or more hitch weight. When the hitch weight is right, then hook up the weight-distribution bars to transfer some of the weight off the rear truck axle. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is offline
Old 06-16-2005, 12:41 AM   #9 (permalink)
I thought you guys were guys..... Do you really think you should be talking about PMS in this thread? [img]/ubbthreads/images/graemlins/smile.gif[/img]
larry_minn is offline
