Old 08-17-2005, 05:12 PM   #1 (permalink)
My Photos: (28)
Reverse parallel for a generator?
I made up a connector to run my twin Honda 2000s and it works great. I now have what I think is a simple question. This last week I ran into a situation where I needed to plug a single extension cord into the system to run an electric motor. When the two generators are in parallel can I use a single plug on one and still have the power of both generators? Is there an adapter where I can plug into my 30 amp recepticle and then plug a regular 3 prong extension cord into?
'97 F250 XLT, PSD, Ext Cab, E4OD, 4.10, TYMAR 4 position flip CHIP, BD Downpipe, Isspro pyrometer pre-turbo, AutoMeter tranny gauge, info@TymarPerformance.comTymar air, Tymar coolant filter, and Tymar HPX mod, ported wind deflector, 4" Exhaust, 4" kitty, Hayden tranny cooler w/in-line magnetic filter, Sonnex Valve, Tricumulator Springs, BMM tranny pan Summit Racing, Synthetic ATF, DYNAMAT, AC Mod, Bilstein Shocks from Eshock, Joe Servo IDM Mod, rhino bedliner, custom wheels, Lil' Rocker 5er hitch, 26.5 Prowler LE
RALLY
Roger45 is offline
Old 08-18-2005, 02:21 AM   #2 (permalink)
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
Re: Reverse parallel for a generator?
You could make one easily, but the whole point of the 30amp "RV" twist-lock plug is that it's rated for those kinds of loads.
You shouldn't be trying to run 30 (or 60 !!) amps across a standard 110V 3-prong, no matter where the power is coming from. That kind of wallup needs 10 gauge, if not 8 gauge wire... and you won't find that with a 15amp "house" plug molded on the end.
Check the motor plate for horsepower, and there are several charts online that tell you the necessary wire gauge. After that, you'll also know the minumum NEMA plug/socket type that will handle the load. If it's just a "startup" problem, you might get away with smaller wire... but too small a wire will ruin your starting load capacity anyway.
If it were me (I have only one Honda 2000eu) I would gang the 30amp RV plugs into a single 50amp "clothesdryer" type outlet. Then use the bigest gauge flex stranded 3-conducter flex SOW I could fit - hopefully 8 gauge. All of this stuff is available at Home Depot.
Best to do it safe and right.
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
'02 F350 Lariat CC Dually Longbed PSD 4x4 6spd
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
Foglights on with High Beams '02-'08 Superdutys
SteveRacer is offline
Old 08-18-2005, 08:24 AM   #3 (permalink)
Yes, I use one similar to the atchd link when I'm only running lights or the microwave from the 30 amp supply.
http://doityourself.com/store/6446520.htm
2001 F350 CC Lariat LWB SRW 4x4 auto True Blue, DR kit,3 pillar gauges,Warn M12000, Hallmark 9.5, PIAA960s,AIC,detroit lkr,Sony xpld 880 watts,Bilsteins,PMT1,Ramair,3.5 dwn pipe 4 muflr,LCD w/DVD,100watt hi beams,BFG At 285s truck pics
Vulcan800 is offline
Old 08-19-2005, 01:53 PM   #4 (permalink)
My Photos: (28)
That is exactly what I am looking for. Thanks.
RALLY
Roger45 is offline
Old 08-19-2005, 02:01 PM   #5 (permalink)
My Photos: (28)
I am not sure if you understand my question or I don't understand your answer [img]/ubbthreads/images/graemlins/shrug.gif[/img] I made my own 30 amp parallel connector *because* the factory stuff was so cheap and light weight, not to mention expensive. I have them attached with the banana plugs and going to a 30 amp female plug using 10 gauge wire and a weather proof box. I use this on my 5er and I can run my air and microwave and TV all at the same time [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Recently I needed more power than one 2000 would give out, but the incoming cord was a standard 110 3 prong. The 2000EU has two 110 recepticles...If I run the banana plugs so two 2000EU's are in parallel, will the 110 plugs on either unit allow the parallel to kick in, or will they simple be the power in a single 2000? On the other side, instead of plugging my 30 amp 5er male plug into the female parallel box that I have made, will using an adapter like the one also posted in this thread cause any problems? I hope that is clearer [img]/ubbthreads/images/graemlins/confused.gif[/img]
RALLY
Roger45 is offline
Old 08-21-2005, 03:21 PM   #6 (permalink)
I made my parallel cables that plug into the 110 outlets(I know not the safest) that run into the rv female adapter. When I want to put a load on them both at the same time I use an adapter to go from 30 amp female to 110 3 prong outlet with no problems. Is that what you are asking??
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 08-23-2005, 02:06 AM   #7 (permalink)
SteveRacer's Avatar
Sorry, I misunderstood your question.
I thought you had a motor with so much draw it needed both generators. If that was the case, it shouldn't be running off a standard 3-prong "house" plug.
But if it's just a matter of needing to plug in something else, that adapter should work fine.
I'm pretty sure I read that if you parallel Honda generators, you shouldn't load just one generator. Once they are running in parallel, you have to plug in ONLY to the ganged box.
I could be wrong about that, but I think I read it in my owner's manual.
-steve
S.A McChesney
Old 08-26-2005, 06:39 PM   #8 (permalink)
My Photos: (28)
-steve
That is the question...sorry I didn't state it better up front. It was easy to make the 30amp plug...should be easy to make a 15 amp adapter. Again, thanks...
Sorry it has taken so much time to reply....nedded to fly to America (from Alaska) for *family* stuff [img]/ubbthreads/images/graemlins/crazy.gif[/img]
RALLY
Roger45 is offline
