Old 12-31-2005, 11:46 AM   #1 (permalink)
rickson wheels
Has anyone mounted these Rickson wheels on their trucks, we have a 1997 F-350 4x4 crew cab 7.3 P.S.. we haul a 4 horse trailer with 14 foot LQ's the trailer weights about 18,000 lbs or so loaded with hay try to keep 40gallons of water empty while we tow. It puts about 4000 lbs extra bringing the truck rear axle weight to around 7100 lbs, we have over loads an airbags which only squats the truck about 3-4 inches, but want to install the 19.5 inch commercial wheels an tires to get to a load range F,G or H tire. Would like some adive please . thanks to all that reply Bob Wallach
planedoc11 is offline
Old 12-31-2005, 02:57 PM   #2 (permalink)
My Photos: (20)
Re: rickson wheels
See here and with slide on camper it weighs 12,180 lbs with a factory GVWR of 11,500 lbs and 23,000 lb GCWR (CC LB 4x4 SRW PSD F350).
jogiba is offline
Old 12-31-2005, 04:19 PM   #3 (permalink)
Re: rickson wheels
did you have to cut the fenders out to install the 19.5 wheels with tires , or was that just for looks?? how do they drive and ride? what load range are they are the weight rating ? thanks a bunch Bob
Old 12-31-2005, 06:21 PM   #4 (permalink)
Texascadillac42's Avatar
My Photos: (10)
Re: rickson wheels
Im running Rickson's on my truck, and they have worked out great. I cant say enough good things about my dealings with them. Ie got 16 ply tires, but I should have gone with 12 ply. The 16s are just too stiff unloaded. They are weaering like iron though, which is always good.
99 F350 XLT 4x4, Crew Cab, 6spd, DRW 255k and still going strong. DR Edge 2" leveling kit. 5" exhaust. Prodigy TBC. Hideaway Gooseneck Hitch. Rickson LTS 19.5 aluminum rims with 245 70R19.5 Michelin XDE M/S. Cummins 12V powered, with a few mods, SBC DD clutch
2005 F250 XLT, Supercab, V10, 6spd, 4wd, SWB, 4.10 LS
Texascadillac42 is offline
Old 01-02-2006, 03:42 PM   #5 (permalink)
My Photos: (20)
Re: rickson wheels
Contact the owner here .
jogiba is offline
Old 01-02-2006, 06:53 PM   #6 (permalink)
My Photos: (10)
Re: rickson wheels
To answer the question a 19.5 tire is the same distance around as a 16.
the rim is larger and the sidewall is smaller, can hold more air and more wieght. But you get a stiffer ride.
j_apetersen is offline
Old 01-03-2006, 06:29 PM   #7 (permalink)
Re: rickson wheels
Sorry but you would be wrong. The 265/75R/16 is 31.8" tall, while the 245/70R/19.5 is 33.4" tall and the 265/70R/19.5 is 34.4" tall.
I am putting the 245/70R/19.5's on my truck instead of converting to a dually.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103 Pictures
www.CarpathiaHost.com
Wayne B is offline
Old 01-03-2006, 07:20 PM   #8 (permalink)
Re: rickson wheels
Wayne is right, I put 245/70X19.5s on my GMC and had to change the rear from 3.70 to 4.10 to make it pull the same.
Go ahead and put the 19.5s on your truck, it's the best thing I did to mine. Very stable and wear like iron. Towing at speed at max weight puts no heat in the tires at all.
Halfnut is offline
Old 01-03-2006, 08:41 PM   #9 (permalink)
My Photos: (10)
Re: rickson wheels
Well with a F-450 with low profile tires and trailer with 16 inch tires I took a tape measure and measured around the tire and the two tires were about an inch bigger on the 19.5 so dont think that is much difference in milage were did you get your measurements from tires not mounted.
Old 01-04-2006, 10:58 AM   #10 (permalink)
Send a message via ICQ to PSD PAC
Re: rickson wheels
I totally agree with Halfnut - I've pulled some ridiculous stuff and haven't had problems, the tires wear like you wouldn't believe, and the guys at Rickson are pretty good to work with.
One of the best mods I've done on my truck, to be sure. Whatever truck I get next will be getting another set.
PSD PAC
<font color="#FB0202">2000 250 PSD CC LB 3.73 4x4 6spd XLT Bright Red.</font> Rickson 19.5s and Goodyear G124s, Performance Friction rotors and pads, GTP38R turbo, Thomas compressor with 5gal tank and 150/110 switch, Air Horns, Sony MD/6CD-MP3/XM & Components all around, Brown Bread soundproofing, USGear brake on 4" Magnaflow, ScorpionLiner, TransferFlow 30gal box, F350 springs 4" blocks and Firestone air bags rear, Rancho level kit up front, DiamondHitch gooseneck, Isspro, Husky Liners, Weather Tech, aFe ProGuard intake, Donnelley auto dimming mirror w/temp, Zerostart, Fumoto, 203 stat, Stanadyne Blue in every tank, Yaesu FT-857D and ATAS 120 with remote mount kit, 1.25kw Inverter under rear seat, Optima redtops with extra studs, <font color="#FF0000">Luxeon LED</font> interior lights, Jody Tipton's 40/80/120/high idle flip chip WOOHOO!!! <font color="#FF0303"> Greater Prudhoe Bay Fire Department - Ladder One </font>
PSD PAC is offline
Old 01-04-2006, 11:50 AM   #11 (permalink)
Re: rickson wheels
An F450 or F550 has 225/70X19.5 duals, which have a single tire weight weight rating of 3640lbs each, and a diameter very close to that of a 16" F350 tire. At that weight rating there is no point switching tires and wheels. We are discussing the single 245/70X19.5s which have both a higher weight rating and a larger diameter.
Halfnut is offline
Old 01-04-2006, 01:53 PM   #12 (permalink)
BJS
Re: rickson wheels
The original poster has not said what tire size he is looking @ he can get tires that are the same diameter as his factory tires to fit the 19.5" rim. or more specifically tires that are within 2-3% overall diameter.
95 F350 Centurion Conversion Bronco E40D (Crew Cab SRW) 4X4 4.10, Boost, Pyro, & trans temp on the A-pillar, BDP Stage 1 injectors, Open air intake, Dpp Downpipe, TS chip.
BJS is offline
Old 01-04-2006, 06:01 PM   #13 (permalink)
Re: rickson wheels
I was going to change gears, but I think I have decided to go with a US Gear Underdrive. They are about $2,600+ the cost of shortening &amp; lengthening the driveshafts. But then I still have the highway gears for when I am not towing &amp; with it in under drive I will have the equivatent of 4.66 geaing &amp; a total of EIGHT gears to choose from [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
The US Gear unit can be used with an exhaust brake while the Gear Vender can not. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Wayne B
Wayne B is offline
Old 01-04-2006, 06:57 PM   #14 (permalink)
Re: rickson wheels
You are correct. BUT, he wants to increase tire weight rating by more than 300 lbs I am sure. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Stock 265/75/16 has a weight rating 3,420 lbs, Diameter 31.8"
In 19.5 a 225/70 has a weight rating of 3,700 lbs, Diameter 32.6"
a 245/70 has a weight rating of 4,900 lbs, Diameter 33.4"
and a 265/70 has a weight rating of 6,500 lbs, Diameter 34.4"
Wayne B
Wayne B is offline
