RV Plug - Diesel Forum - TheDieselStop.com
Old 04-13-2006, 12:33 PM   #1 (permalink)
RV Plug
Well the RV trailer wire caught on something (bumper maybe) while I was doing some tight manouvering and pulled out of the receptacle breaking the cover(which also holds the plug in). Is there somewhere to get just the cover or will I have to spring $60 for the whole assembly from Ford?
Bama
1999 F350, bought used 1/2001, Crew Cab, DRW, 7.3 PSD, 3.73 gears, lighted running boards, Sony CD w/ two 10's and 1500 watts. Pulling a 32' Enclosed Gooseneck trailer.
BamaPSD is offline
Old 04-13-2006, 02:08 PM   #2 (permalink)
Re: RV Plug
If you are refering to the truck end of the 7 pin RV connector, they can be bought at most auto supplies or RV dealers for around $10-$15. No need to go to dealer. You cannot buy just the plastic spring loaded door.
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline
Old 04-13-2006, 05:49 PM   #3 (permalink)
Re: RV Plug
As twobit says, hit an RV store - they are not expensive. Rewire it yourself. It is easy. Just read the colors molded into the housing and match them up to the 7 wire conductor. The plastic connectors are $4.99 at Snyders in Salem, Va. Metal are about $8.00.
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
Old 04-14-2006, 04:36 PM   #4 (permalink)
Re: RV Plug
Thanks guys, I'll find a replacement locally and rewire.
Bama
BamaPSD is offline
