Old 03-25-2006, 09:41 AM   #1 (permalink)
RV trailer tires
6 years on my tires time to change....any recommendations on best tires for my RV trailer?
2000 F-350 4x4, AIS, SCMT 1705, EGT/Trans/Boost,
KMHEY is offline
Old 03-25-2006, 02:18 PM   #2 (permalink)
Re: RV trailer tires
Need some info on the trailer. weight & # of axels.
OMCUSNR is offline
Old 03-25-2006, 04:07 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Yeah, it depends on the tire size. If you just happen to need ST225/75R15D, then Cooper is the only way to go.
http://www.coopertires.com/us/en/Pro...itle=SUV+Tires
For LT235/75R16E I would go with Michelin XPS. http://www.michelinman.com/catalog/t...ml?source=TCHP
For lesser trailers that use ST205/75R15C, then Cooper makes one, but it's not nearly as good as their 225. http://www.coopertires.com/us/en/Pro...SUV&id=178
If you have 205s on your trailer, then I would change the wheels to 15x6" wheels then go with the Cooper ST225/75R15D. In fact, that's exactly what I did. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is offline
Old 03-25-2006, 05:47 PM   #4 (permalink)
I do need 225/75/15,it's for a Montana two axle mountaineer
I have no idea what's best, but I want the best due to precious young cargo in the tow vehicle in the form of a 2,6 and 8 yr old.
I'll check out cooper sounds like thats hands down advice
KMHEY is offline
Old 03-27-2006, 12:26 PM   #5 (permalink)
My Cougar takes the 225's D range as well and will be getting Coopers when these Mission ones are worn out or 3 years old....I can't say anything bad about the Missions however they are of Chinese origin (Nanking rubber IIRC) and I question their experience and expertise in RV tire manufacturing simply because I am not aware of any sized market for large , heavy RV's in China. Cooper has been around a long time and seems to have maintained a reasonable reputation.....IMHO one tire problem on my RV would quickly outweigh any extra expense involved in putting new tires on. Then again I have generally put on 4 new Michelins if I have a flat [img]/ubbthreads/images/graemlins/eek.gif[/img] on any of my vehicles. Yep...overkilll I know.
Ian
2004 PSD F350 Lariat 4X4 CC long box Arizona Beige , AIC, FX4 heated seats, adjustable pedals, power rear slider, towing pkg/ receiver, power Towing mirrors, camper pkg,reverse sensor, 3.73 LS, torqueshift, bedrug, born on Dec 3 2003. Towing 2005 Cougar 5th wheel 285 EFS with a bell and two whistles.
ikidd49 is offline
Old 03-27-2006, 01:37 PM   #6 (permalink)
Same here, any suggestions LT21585R16, Load Range E. Would like a heavier tire but no extra room.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 03-27-2006, 01:43 PM   #7 (permalink)
KMHEY,
Carlisle makes a 225/75/15E tire. www.carlisletire.com Look under products, trailer tires, radial trail. 2830 # capacity at 80psi versus 2540 # capacity at 65psi. Of course you have to upgrade the rims and valve stems to handle the 2830# and 80psi, but this will be the next purchase I make for my Cougar 314EFS. Carlisle also sells some real nice aluminum wheels in the 15" size with an 2830# certification.
Also, if you look on the right side of Carlise's home page at Resources and then Trailer Reference Guide, you can download a PDF of all Carlisle trailer tires and Wheels. They have aluminum wheels with the round holes that match the Ford Factory Wheels.
A man I go to Church with works for Carlisle and put me onto these. He also has a Cougar and had a blow out of one of his Mission tires that ripped about half the side off his camper. He has now put the Carlisle tires on his trailer.
Just thought you would want to look at all the possibilities.
Firefighter9208
firefighter9208 is offline
Old 03-27-2006, 08:00 PM   #8 (permalink)
Have you ever run carlile tires??? They are JUNK JUNK JUNK.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103 Pictures
www.CarpathiaHost.com
Wayne B is offline
Old 03-27-2006, 09:04 PM   #9 (permalink)
Take it form me, I thought Carlisles were good, I did EVERYTHING right and still had a near blow out!! Switched to BFG Commercial T/A 16" tires and rims. We will see now.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 03-27-2006, 09:28 PM   #10 (permalink)
Thanks for the advice guys....I found some coopers today, have not purchased yet, but think that's the route I'm going to take..not cheap though (110.00) each....but worth the piece of mind and long term investment....thanks for all the advice
KMHEY is offline
Old 03-27-2006, 09:38 PM   #11 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Michelin XPS Rib comes in that size and load range. That's what I'd get. (Not cheap! But worth it.) [img]/ubbthreads/images/graemlins/cool.gif[/img]
http://www.michelinman.com/assets/pdfs/doc_xpsrib.pdf
Old 03-28-2006, 08:23 AM   #12 (permalink)
I have Carlisle Mobile Home tires 8 x 14.5 on a 16 foot utility trailer that I have hauled 7 tons of gravel on. I use this trailer weekly to haul various loads and have never had a problem. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Firefighter9208
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2006 Volkswagen Jetta TDI (wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
1990 Jeep Wrangler
Old 03-28-2006, 08:53 AM   #13 (permalink)
DO NOT get Carlisle tires. They are peices of sheet! Not only my personal experience, but go to RV.net in the toy hauler forum and it is only the Carlisle tires that get the bad press. It appears that the Michelin XPS Ribs are getting the best opinions.
2004 PSD 6.0L XLT Supercab
Longbed, Build Date:July 2003
3.73 Rear Axle
2005 Thor Transport 33WTB toyhauler (5'vr)
Dirt bikes inside
martymart909 is offline
Old 03-28-2006, 09:30 AM   #14 (permalink)
lincster's Avatar
My Photos: (22)
I agree. I run 225/75/16 Ribs on my trailer, 3 years and they still look new. Around 20,000miles on them.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 03-28-2006, 11:25 AM   #15 (permalink)
See my sig for my rig. Montana shows it as a 295RL, but it really 31' 10" overall length. It weighs 10,500# ready to head north.
I regularly replaced the 'D' rated tires which came on it: blowouts seemed fairly common. My own take is that the tires that come are max'd out as to load carrying capacity.
Before I started to Alaska in 2005, I talked to a local tire shop and they ordered Carlisle tires for me. The owner knew I didn't like the Chinese tires that came on the trailer. When the Carlisle's came in, they were "Made in China". The dealer sent them back.
I then found on an RV site a guy who bragged about Denman tires. I ordered at set of them in 15" size with "E" rating. I drove them to Alaska and back and had NOT ONE flat. My brother-in-law, who pulled an identical rig with identical truck and travelled with us to Alaska and back lost 3 tires by the time we got to Anchorage. He then ordered a set of Denman's and had them installed up there. He didn't lose a tire on the way back. We drove every paved road in Alaska and a bunch that were not paved. Not a single "E" rated tire lost.
I'm a beliver in Denman and over-rated tires, now. (Mione were made in Mexico.)
Florida Ed
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 112K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 67K miles headed to 150K (wife's vehicle on the "junk-iron" theory of vehicle safety....most junk iron wins in a crash) stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
