Old 06-26-2006, 11:27 AM   #1 (permalink)
Sloppy receiver!
Why are the receivers so sloppy? I can understand a little clearance so you dont have to fight to remove the hitch bar but i think its a little too generous.
2004/04 F350 Lariat CC LB 4X4 SRW, Dark Toreador/Arizona Beige, 6.0L/Torqshift, 3.73LS, Heated seats, Clearance Lights, TT mirrors, Captian Chairs, Moonroof, ESOF, 12K Receiver
4" MBRP T-409 Cat Back
BlackMax Tonneau
Prodigy Brake Controller
2007 Prowler 3102 BHDS
2000 TERRY EX 27F (Sold)
2001 F250 SC 4X4 5.4L (Sold for '04)
My Pictures.
3gees is offline
Old 06-27-2006, 09:34 AM   #2 (permalink)
Re: Sloppy receiver!
I have an 04 Excursion, my receiver is not sloppy/loose at all. Only thing wrong with mine is I used the pin that has bend at one end. This has enlarged the hole somewhat on that side. Went to straight pin, no more problems.
Don
luckeyd is offline
Old 06-27-2006, 07:42 PM   #3 (permalink)
Had the same problem and went to a local trailer store that sold me the right bar...not sure what class but it's solid steel and fits like a glove. That bar won't fit in other receivers though...it's a hair too big!
2008 Tundra Crew Max Limited 5.7
2004 F-250 CC Lariat FX4 6.0 PSD with 132K miles (traded)
boatingncst8fan is offline
Old 06-28-2006, 10:19 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
If you mean the ball mount/drawbar rattles around in the receiver, there is a relatively simple fix. Weld a small bead about 3 inches long on each side of the drawbar, then grind the new beads down until you get a snug fit in the receiver. If you are really picky, then make that two beads on each side of the drawbar. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is offline
Old 06-28-2006, 08:31 PM   #5 (permalink)
Try one of these, I am going to order one. I've heard of the welding trick but I also heard that once that weld rusts up that it can make getting the darn thing out pretty difficult. For $22.00 I think I'll try this first. If that doesn't work then maybe I'll fire up the ole welder.
http://www.hitchrider.com/nowobble.htm
2004 Ford Excursion 6.0 4wd all stock
xitup4810 is offline
Old 06-28-2006, 11:06 PM   #6 (permalink)
My Photos: (33)
As for the rusting up thing. Simple fix.
1. get yank strap
2. attach end A of yank strap to trailer ball
3. attach end B of yank strap to something solid (telephone pole)
4. Idle off.
5. Marvel at your newly solved once problem.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 06-29-2006, 06:44 AM   #7 (permalink)
1. get yank strap
4. Idle off.
Make sure yank strap or whatever is longer than the object you tie it too!!!!
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 06-29-2006, 08:02 AM   #8 (permalink)
Albin's Avatar
My Photos: (24)
Do what I did and use a 5/8" grade 8 bolt and tighten that sucker down. Also helps prevent someone removing the pin without your knowledge and/or theft.
Al
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 06-30-2006, 12:03 AM   #9 (permalink)
1. get yank strap
4. Idle off.
Alternative to telephone pole. Use mother in law instead.
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
