When I rewired my Carson flatbed I used 16 Gauge wire from JC Whitney. I've also seen what you are looking for at etrailer.com.
I'm like you, but I prefer the terms 'frugal' or 'fiscally responsible'.
[img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/smirk.gif[/img]
07 F350 4X4 XL supercab 6.0 Torqshift Lots 'o options, Line X, Isspro EGT, Trans, Voltage in overhead module, airbags, runningboards,mudguards and coolant filter. My Pictures
Your gonna laugh most likely at this, but I used the orange 50' extension cords with no problems. If I remember corectly they have 3 wires in them, so you might have to double them up. Considering 50'ers are cheap at the big home improvement places, just got to keep track of what wire is doing what, the added bonus is the wiring is well insulated.
I have used them on 16' and 20' trailers with brakes and no problems
I am a fan of the 6.9/7.3 IDI, 5.9 CTD
Definetly not a PSD fan
I won't laugh at you, I've used them more than once. They are stranded 16 or even 14 gauge wires and work very well on trailers.
joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
Glad I aint the only one [img]/ubbthreads/images/graemlins/cool.gif[/img]
I built a 16' tandem trailer a few yrs ago and needed wire for lights and brakes. This was when $ were tight, to buy the normal green/white/yellow/brown wire trailer wire was like 30$. For 8.99 I got a 50'er from the hardware store. Been using the ext. cords ever since. Going to rewire my used Big Tex 16'er this next weekend with an Ext. cord
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
Hah, Haha, i am laughing with you not at you. I have used it as well. in fact thats what I will be using to power my Wvo pump..
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
Douglas Campbell [drcampbell ot engineer dat kahm]
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
Darn! That's the perfect tightazz solution! Already bought a bunch of wire though. Going with 12' of multi-guage (10-1/12-2/14-3)at the hitch,tied in to a junction box, 12/2 stranded to the brakes, and Y-type 4-wire flat on back to the tail-end. I'm going to swap out the taillights and ID bar for LEDs while I'm at it. Putting in the junction box because I plan to later add a break-away brake setup, 12v battery box, cargo lights, and enclosed 10,000lb winch. Any suggestions while I have the solder gun hot?
Thanks!
Tom
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
Napa typcially has spools of the 6 and 7 strand wire. I'm sure some of the other sources are cheaper but this may be more convenient and help someone out.
