Suggestions for towing 18k trailer - Diesel Forum - TheDieselStop.com
Old 10-01-2009, 12:07 AM   #1 (permalink)
I have an '06 F250 with the 6.0 diesel and stock 12k receiver hitch. I'm looking at buying an 18k equipment trailer with a lunette ring. I've been able to find plenty of bolt on 18k+ pintle hitches, but I can't find any 2"x2" pintle mounts that are rated about 10k (or 2.5"x2.5" either). Any suggestions on where to find a pintle mount that is rated for 18k or more? Any suggestions on a new receiver hitch for my truck that can handle 18k? (I assume it will have to be a 2.5"x2.5" receiver hitch). Will my truck have any issues towing around 18k? The MCGWR is 23,400 (I think) and the truck weight around 6,300. Thanks.
-Jason
jmpratt is offline
Old 10-01-2009, 12:21 AM   #2 (permalink)
I believe that your truck actually weighs in the 7600-8000# range, empty. Which when added to 18k puts you over your CGWR.
Your truck is rated for 16,400# fifthwheel/gooseneck trailer. Around 12,500# conventional (ball or pintle)trailer.
I think your biggest problem will be stopping. Not enough truck to stop a 18k trailer with less than perfect brakes.
Good luck
05 F350 Lariet SC 4x4 6.0/auto lgbox Toyo AT's, bilsteins, on board air with airbags & air horns
gmoore is offline
Old 10-01-2009, 01:26 AM   #3 (permalink)
My CGWR is 23,000, so if 16,400 is my max gooseneck, then I guess the truck weighs around 6,600. The factory hitch is rated for 12,500. If I bought an aftermarket hitch that was rated for more weight, could I pull more than 12,500 with a conventional trailer? I think the 2" receiver is what's limiting the factory hitch. I think a 2.5" receiver would let me pull more. Thoughts?
jmpratt is offline
Old 10-01-2009, 07:51 AM   #4 (permalink)
My Photos: (60)
Most likely that 6,600 weight figure is for a base truck (no weight adding options) with the lightest engine and tranny available, with 150 lb driver. You need to weigh your truck to see what the figures are.
Your limiting factor will be GAWR and GVWR most likely. With a tag trailer you can pull more because the tongue weight should be less than the pin weight of a gooseneck or fiver of the same weight. The figures from the towing guide are based on numbers pulled from vehicles that give the highest rating, not real world weights.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 10-01-2009, 01:07 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
You'll be severely overloaded. Not just the receiver, but the overall truck.
Your GCWR is 23,000. Your GVWR is probably 10,000. Ignore the towing guide numbers as others have mentioned, and weigh your wet and loaded truck. Subtract the weight of your wet and loaded truck from the GCWR and that will tell you the max trailer weight you can safely tow. Subtract the weight of the wet and loaded truck from the GVWR and that will tell you the max hitch weight you can have without overloading the suspension and frame of your tow vehicle.
"Wet and loaded" means full of diesel, and including all the tools and passengers and other stuff you will normally have in the truck when you have that trailer tied on. Your rig will probably weigh aat least 8,000 pounds wet and loaded. So that leaves 15,000 pounds max trailer weight and 2,000 pounds max hitch weight.
Here's a pintle hook mounting plate for 18k max trailer weight:
Pintle Hooks & Lunette Rings
Scroll down past the lightweight jobbie and look at the one rated 18k. Notice it requires a a 2.5" receiver.
And yes, you have to have a heavier-duty 2.5" receiver rated for 18k weight carrying. Those are rare too, with a weight-carrying (instead of weight-distributing) capacity of 18k, but I found one. Hidden Hitch Titan has 18k weight carrying max trailer weight and 2000 pounds weight carrying max hitch weight. Click on this, then scroll way down until you see it:
Hitches, Receiver Hitches; Hitches Online
If your wet and loaded truck weighs 8,000 pounds and your trailer weighs 18,000 pounds, that's 26,000 pounds GCW. Your GCWR is 23,000, so yes, you'll be overloaded by 3,000 pounds. No big deal on the flats, but when you get into hills and mountains, you'll be in trouble.
For that load you need a truck with at least 27,000 or 28,000 pounds GCWR. That eliminates the F-350 DRW and calls for an F-450 pickup which has 33,000 GCWR, or an F-450 chassis cab with the high-capacity towing pkg which has 30,000 GCWR.
SmokeyWren is offline
Old 10-01-2009, 07:46 PM   #6 (permalink)
SmokeyWren,
Thanks for the info. One of the hitches you provided a link for is a 2" receiver with a 15k load rating. That's pretty much what I'm looking for, but I can't find a 2" pintle mount that is rated from more than 10k. Has anyone seen one rated for at least 15k?
jmpratt is offline
Old 10-01-2009, 09:27 PM   #7 (permalink)
You'll need to have a hitch custom made. The only ones out there that exist are built for chassis cab trucks. I believe they are rated in the 25k area. Reason why what you are looking for doesn't exist, is because that is way too much weight for SRW pickup truck. Have something custom made if you really want to pull that much weight.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 10-19-2009, 10:28 PM   #8 (permalink)
Doubt if a custom hitch builder would chance the upcoming liability for such a hitch. There would be lots of white knucle moments resulting from such a set up/load. An old OTR commercial driver speaking
Fordpowerstroke350 is offline
Old 10-19-2009, 10:52 PM   #9 (permalink)
carringb's Avatar
I have a Reunel rear bumper with an integrated 2" receiver rated for 6,000 pounds tongue weight and 20,000 pounds pulling weight.
I have pulled 18,000 pounds without issue. But I did use a Reese Dual Cam hitch which you could not do with a pintle hitch.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 10-20-2009, 06:44 PM   #10 (permalink)
olddieseldude's Avatar
My Photos: (16)
I mentioned this in another pintle hitch thread. If you look at trucks around town pulling a large pintle hook trailer they are all larger class trucks, dump, or utility trucks, with the pintle hitch just aft of the rear axle. Very little distance from the axle to the hitch meaning that under braking the load shift of the trailer will not be trying to lift the front end of the tow vehicle off the ground. Your truck will have a huge overhang by comparison and none of the truck weight to offset it. If you are going to pull this much weight you need a weight distribution set up to combat this issue, not a pintle hook.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 10-20-2009, 11:08 PM   #11 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
That's a really nice family hauler.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
Old 10-21-2009, 09:46 PM   #12 (permalink)
Agreed. But I don't know how else he can get a hitch rated for that weight.
NickKent is offline
