I have a 2000 psd and I want to know is it
safe to haul a 1875lb lance t/c and tow a
12ft trailer with 3 quads on it in hi pref
tow I don't have money for the gauges yet?
I do have a k&n intake 4inch turbo back ex.
and a ats compresser housing and shift kit
and the superchip tuner
Thank you
Thank you
Safe is the key word here.
No its not safe to tow with a programmer and no gauges .
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
I wouldn't use a tuner at all without a egt gage (pre turbo is best). I can see way over 1250 in tow safe towing my 5er. It is much heavier than what you are towing, but the principals still apply. Going up a long grade towing anything with a tuner installed could result in very expensive bills (EGT gage is very cheap compared to melted piston crown!) Gages!
Doug
97 F-250 extra cab 2WD. K&N FIPK, 410 gears, Pace Edwards roll-top bed cover, Reese 16K 5th wheel hitch, defender trans cooler, 81K orig! New to me 10/2003. Pyrometer and trans temp pillar, boost gauge, SCMT, exhaust brake & t/c lockup, Hypermax downpipe/tymar out 4", ATS Intercooler (Thanks CaryT)
Unless you got a decent exhaust system I would not tow anything unless it was in stock or tow safe mode. Get some guages. [img]/ubbthreads/images/graemlins/wink.gif[/img]
__________________ 2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Straight Pipe,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer My Pictures
I would not, I had a super chip 1705\downpipe and pulled my camper a couple of times with out gauges [img]/ubbthreads/images/graemlins/eek.gif[/img]the trailer was about 9k. Then I installed gauges, injectors, intake and a chip then pulled a 3k trailer up to the mountains and on a grade the egts would get to 1300 in a blink of an eye and that was in my stock or 40 tow program. I cringe every time I think about towing with the 1705 and no gauges. I did not have a intercooler like you but when it gets cold out and I see a little smoke when at idle it makes me wonder did I do any damage, that was about 3 years ago and I still have not done a compression test, my truck runs great but I will never do that again. Good luck
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
