Old 03-27-2007, 10:48 PM   #1 (permalink)
SuperChips 1705 MAX Micro Tuner 1999-2003 7.3L
What setting is best for towing a 7000lbs. fifth wheel trailer?
Ford owners manual states, maximum towing weight: 10,000lbs for a pull behind / 14,500lbs for a fifth wheel.
Does that mean the settings for towing a fifth wheel would be:
TOW SAFE: 14,500lbs / TOW PERF: 8,700lbs / HIGH PERFORMANCE: 450lbs
***********SUPERCHIPS INFO***************************
TOW SAFE: +80hp and +120 Ft-lb. torque, towing up to the manufacturer's specified maximum weight limit.
TOW PERFORMANCE: +90hp and +175 Ft-lb. torque, towing 6,000 lbs or less.
HIGH PERFORMANCE: +110hp and +200 Ft-lb torque, NO towing.
sw_601 is offline
Old 03-28-2007, 04:35 AM   #2 (permalink)
Re: SuperChips 1705 MAX Micro Tuner 1999-2003 7.3L
If I were you I would not tow anything with a superchips tuner without exhaust upgrades and gauges. I used to tow with a superchips tuner and the exhaust would get very hot. I would end up having to back out of the throttle and put up the hills to keep the EGT's down. I would highly recommend that you Be very careful while towing with the tuner installed even on tow safe.
I say this because I did not see an info in a signature on what you may have done to your truck.
Keep Strokin'
My Truck: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
Old 03-28-2007, 10:20 AM   #3 (permalink)
I had one in my 02 7.3L, Stock exhaust and intake and had No problems towing my 10,000 lb travel trailer on either the TOW SAFE or TOW PERFORMANCE settings.
I had gages and had no problems with high EGTs.
I was 19,200 lbs combined going down the road.
I had the SCMT installed on my truck for over 85K miles, over 20K miles towing my trailer.
07HEMI4ME
Purchased a 2007 Dodge, ThunderRoad Edition, QC, 4x4, 5.7L HEMI on 11/30/07.
Traded in my Travel Trailer for it, so no need for a Diesel.
2003 EB Expedition 5.4L
2006 F350 Lariat, 6.0L PSD, Crew Cab, FX4, 4x4 PURCHASED BACK BY FORD! on 8/28/07.
07HEMI4ME is offline
Old 03-28-2007, 06:59 PM   #4 (permalink)
I have a 2000 psd with the superchip tuner
4inch ex.,K&N intake,banks big head,shift kit,ITP boost regulater,
and ATS compressor housing I don't have the
gauges YET! My ? is would I be safe hauling
a 1900lb lance camper And towing a 12ft trailer(1200lbs trailer weight)
with 3 quads (600lbs each)water and gear( ? lbs) in HiPerf.TOW doing 60 mph
Any of you guys out there with gauges that have towed
about the same weight do you think I would be OK
Thank You
P.S. I forgot the beer weight
redrocker is offline
Old 03-28-2007, 11:00 PM   #5 (permalink)
NO! I don't think so. If you tune it down to tow mode you should be alright as long as you take it easy on the hills.
My .02, Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 03-28-2007, 11:41 PM   #6 (permalink)
get gauges. you will never know the damage you are doing without gauges. i tow constantly. some trucks are ok. some are not. i tow now in the hot setting on my 1700. i have to back out all the time. but the last time i was at the scales i was at 42k pounds.
sgrem is offline
Old 03-31-2008, 12:57 AM   #7 (permalink)
Send a message via AIM to tenikiwon Send a message via MSN to tenikiwon Send a message via Yahoo to tenikiwon
What are the limits for Tranny & exhaust temp and Turbo PSI
Tranny 250 degrees?
Exhaust (pre turbo) 1200 degrees?
PSI 24psi?
tenikiwon is offline
Old 08-02-2008, 11:10 AM   #8 (permalink)
is there any way to unlock this unit. it came with my old truck which i sold. but i kept the tuner. im trying to sell it but nothing pulls up on the screen when i plug it into another truck.
mitchummm is offline
Old 08-02-2008, 11:22 AM   #9 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
You are now the proud owner of a Superchips code reader. You may want to try calling Superchips but they will charge you if they do anything.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 08-02-2008, 11:59 AM   #10 (permalink)
powerdome's Avatar
u spent all that money on those mods before gauging it? the gauges sure are cheaper than a new compressor housing
2001 PSD, CCSB 4x4, 4R100, Precision Industries 1900stall TC,ISSPRO pyro-tranny-boost, Detroil Locker in rear, 35"pro-comp xterrains, 4" turbo-back to 6" stacks, Roll-bar, "Wreckers Special" light-bar, Dual In-Dash DVD, Polk Audio Door Speakers, 1200 watt Rockford Amp, 2 10" JL w1, Midland CB
powerdome is offline
Old 08-02-2008, 07:32 PM   #11 (permalink)
i have the superchips 1805 flashpaq, i never see over 1200 tops pulling a long hill on the economy setting, i leave it there all the time, its the middle setting on mine.if i go over say 20 psi of boost it sets off the ccheck engine light. so i try towing under that, even the biggest hills i never need full throtle though, just tryinn to save up some money for one of jodys sct programers now.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
