Old 03-05-2008, 04:50 PM   #1 (permalink)
Superduty with a box truck on a trailer? Bad Idea? (Video)
YouTube - Truck Somehow Avoids Tipping On Highway
It seems like this guy has a box truck on some sort of trailer being towed conventionally by a Superduty. Bad idea anyone?
Tispho is offline
Old 03-05-2008, 05:35 PM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
That was amazing!!!!
I have had some bad sways like that with a overloaded trailer, but nothing like that high profile rig.
MarkEkberg is offline
Old 03-05-2008, 07:41 PM   #3 (permalink)
olddieseldude's Avatar
My Photos: (15)
Was that from cross winds?
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 03-05-2008, 10:12 PM   #4 (permalink)
That's why you secure a vehicle to a trailer by the frame, not by the axles.
When you secure it by the axles, you have two degrees of freedom (the trailer and vehicle springs, both)
When you secure it by the frame, you have one degree of freedom (the trailer springs only)
I've tried & failed to explain the concept many times, but a video's worth a thousand words. I'm bookmarking that one for eternity.
Douglas Campbell [drcampbell ot engineer dat kahm]
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is online now
Old 03-06-2008, 10:35 AM   #5 (permalink)
I agree that he failed to secure the load properly. Another thing to consider is his speed. Regardless of how well or poorly a item is secured, the towing speed will play into this. In a situation like this, I'd say that he was probably close to the wieght limit on the trailer and didn't have it placed properly due to the size of the load.
He was very lucky, I'm sure he needed a fresh pair of undies, cause i'd be willing to bet his butt grabbing the seat.
Mine :01 F-350 CrewCab Lariat 4x4, 7.3 PowerStroke, auto, ShortBox. Mods: 3-Gauage A-pillar W/ Autometer Lunar Guages<boost,pyro,trans> Galaxy DX-33 Radio W/ MonkeyMade steel whip, and Optima RED TOP batts.
Work: 05 Kenworth T-800 X-tended Daycab, Cat C-15 ACERT 550Hp, 10sp., 4:11 rears, Hiab 144cl Boom, Galaxy 99v w/ Wilson 2000 antennas and XM sat. radio.
Hers: 00 Pontiac Trans Am, (stock)LS1, auto, T-tops.
VCRacing is offline
Old 03-06-2008, 11:24 AM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
By the looks of the video it is secured very well. There is no movement in the load at all.
I am guessing that there was not enough weight up front. That is was caused my problems on a overlaoded trailer, but the weight was only 3' high.
Old 03-06-2008, 12:29 PM   #7 (permalink)
My Photos: (6)
I'd have created a vacuum between me and the seat if I'd of been driving...You would have had to use a crow bar to pry me out...
June 1996 F250HD XLT/SC, LWB, 4x4, 4:10LS, E4OD, White outside, Gray inside, Camper/Tow pack, Factory Aluminum wheels, Factory rear slider, decal free.
Factory AIC, Aux dash switches, Full add-a-leaf, Mile Marker SS Hubs, Upgraded E4OD Tranny, Tymar intake, BD downpipe, Exhaust brake, 203* stat, BriteBox, California Regulator mod, Truck Interiors Winterfront, Ported bug guard, Energy Suspension bushings rolling on 265x75 Bridgestone Revo's.
KD7UBW - PHAR (Public Health Amateur Radio)
My Truck
2008.5 Mazda 3s Touring 5 door in Copper Red Mica w/indash 6 disk Cd changer/MP3 and moonroof: The Wifes
Rookie is offline
Old 03-06-2008, 03:19 PM   #8 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Forgotto mention that that trailer is now bent beyond use. When they take that load off that trailer is going to bounce something terrible.
Old 03-06-2008, 04:37 PM   #9 (permalink)
I agree it looks like they strapped it down by the axles. Turns the whole trailer into a second order mechanical system. Looks like they hit a bump or changed lanes and found the natural frequency of the system.
2002 F250 Crew-Cab Short-Box 4x4 Off-Road 7.3L
283 HP/ 570 Lbs/Ft
BTS Trans
BTS 4-Stage FlipChip
AFE stage 1 Intake System
Silverline 4" T-304 Stainless Turbo-Back Exhaust-Donahoe Racing "Edge 4.5" Plush Ride lift
BFG all terrain 35" tires
Niner1190 is offline
Old 03-06-2008, 07:13 PM   #10 (permalink)
Hook'em Horns!'s Avatar
I see the truck secured only at the front, with the truck rear axle/wheels being airborne. The trailer axle stays on the ground while whipping back and forth as you hear the truck slamming down on the deck. The tongue weight looks heavy, so I’d guess crosswinds and/or abrupt driver movement kicking it off.
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 03-06-2008, 10:21 PM   #11 (permalink)
Holy crap thats scary
2000 F350 2wd DRW 6sp PSD Xcab long bed, AFE Intake, 5" exhaust straight back, no muffler, Edge Juice with Attitude, ATS Ported Turbo Housing
170typhoon is offline
Old 03-06-2008, 10:58 PM   #12 (permalink)
Ok, I'll throw in my 2 cents. The truck on the trailer looks like a Unimog with a box. Pretty heavy truck empty. If the guy bought the truck and also a spare engine, a spare set of axles and put them in the box, you could never get enough hitch weight to prevent sway. I have had this EXACT same thing happen when I hauled a 5 bottom plow a long time ago. I could not get the plow far enough forward on the trailer to make any tongue weight. It seemed OK and I started off down the road. I went several miles before it started whipping, all I did was cross a bridge seam in the road. Things went to hell and I did almost crash the truck. I was able to save the rig by using the overide button on the brake controller and locking the trailer brakes up completely, this straightened the the truck out immediately. I nursed the load the last 3 miles at 15 MPH with my hazards on and 1 finger on the brake controller!
6GEARS is offline
Old 03-06-2008, 11:10 PM   #13 (permalink)
88beast's Avatar
not a unimog same thing but mercedese unimog is boxier mercedes version is smooth lines
but i bet he has the axles and engine in that box too
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 03-06-2008, 11:12 PM   #14 (permalink)
Blue01F250's Avatar
Send a message via MSN to Blue01F250 Send a message via Yahoo to Blue01F250
Holy
that would have scared the shister outta me!
Blue01F250 is offline
Old 03-08-2008, 10:10 AM   #15 (permalink)
Someone needs to learn how to tie down.
2006 Job 2 F-350 Crew cab King Ranch single wheel 4x4 92k
2007 Dodge 3500 6.7 4x4 14k
Former diesels: 91 D250, 93 D350, 95 F350 PSD, 96 Dodge 3500, 2000 F350, 05 D-max: Fire, 2004.5 Dodge 3500, 2005 Dodge 3500
TXGooseneck is offline
