Old 03-05-2005, 07:53 PM   #1 (permalink)
My Photos: (6)
Surge brake roughness.....
A buddy of mine bought a big a$$ mastercraft (xstar?), and he plans to tow it with his 4.8L Tahoe.........(poor guy)
Anyway, in traffic, when he stops and then takes off again, the play in the surge brakes lets loose, and it jolts pretty good. Trailer weighs something around 5000 lbs.......
Is there anything that he can do to solve this?
Trailer and boat are brand stinkin new, so I doubt theres any trouble with the trailer...........
Diesels:
Duramax, ZF-6, CAT 2, B50++
VW TDI 5 speed, 50 MPG
Kubota L4300 DT, custom pintle type hitch on box, avocado hauler
83 Volvo 244 GL, 2.4L NA, Diesel, Manual, 140k+, For sale!
biodiesel from leoco.com
What Would Reagan Do?
mannytranny is offline
Old 03-06-2005, 09:32 AM   #2 (permalink)
Re: Surge brake roughness.....
Are the brakes disc or drum? If they are drum he may need to adjust them even though it is new. he could also try braking slower.
1996 ext. cab, long bed, 4x4, 5spd. PSD, 3.55LS, Ford AIC, drainplugged Dana 50, EBPV brake, tranny cooler and gauge, Tymar intake, Tymar 4" downpipe and 4" exhaust. No kitty.
Nick_Kent is offline
Old 03-06-2005, 09:38 AM   #3 (permalink)
Foy
My money is on low fluid level in the actuator master cylinder. If fluid level checks out OK, then the brake system probably needs to be bled.
Low fluid isn't uncommon on a brand new trailer. Had the same situation upon taking delivery of a new boat in Sept 04.
'02 F350, 4WD, CC, SRW, auto trans, Lariat, Trailer towing/camper/off-road equipped, bone stock.
Foy is offline
Old 03-06-2005, 09:41 AM   #4 (permalink)
There SHOULD be a damper cyclinder ("shock absorber") mounted horizontally on the hitch. That is what keeps the system from doing what you describe. Make sure it has one and it works.
Pat
Pat Dolan is offline
Old 03-07-2005, 09:24 PM   #5 (permalink)
My Photos: (6)
Its got 4 wheel disc hyd. brakes.
I will reccomend to him all of the above! Thanks!!!
Diesels:
Old 03-11-2005, 05:39 PM   #6 (permalink)
I'd recommend bleeding them once more. My boat trailer does the same thing so I just creep ahead a bit after I stop to release the brakes. Then when I go to take off it is a lot smoother.
He needs to ditch the x-star and get a Tige [img]/ubbthreads/images/graemlins/tongue.gif[/img]
97 F-350 4x4, Reg. Cab, "Clapped Out" 5 speed w/ S.B.C. OFE Clutch, DP Tuner Chip (Economy/Extreme), JoeServo IDM, Tymar Intake & HPX, 2002 HPOP, Cali. Regulator, MADDOG Stage 2 Injectors, 6" Exhaust, SD Power Pedal, SD 40/20/40 Seat, Ford AIC w/ C.F. Cover, Auto Meter C.F. Gauges, 2" Lift, Xenon Flares, 305 Good Year MT/Rs on 17x10 Weld Cheyennes
Truck Pics
2000-Tige 2100V Limited
1993-Layton 24' Travel Trailer
AZPowerStroke is offline
