Old 01-01-2008, 11:17 PM   #1 (permalink)
Surgeing trailer brakes
Hope this finds all haveing a safe and good new yrs. so far. Anyway I have a issue with surgeing(?) brakes on a 26' Big Tex G.N. I have a Draw Tite II brake controler that came with the truck and has always worked real nice, anyway Ihave noticed that when just about stoped it seems that the trailer brakes start to "surge?" ;like you are "pumping" the brakes any ideas? Thanks for any help
stay safe out there
Roy
ALL GAVE SOME, SOME GAVE ALL 9-11 WE WILL NOT FORGET YOU BROTHERS!!
96 C.C.XLT, SRW, Short Bed, 3:55, Rebuit E4OD with Transgo shift kit & Tru-Cool Max cooler, Home made Open Air Element, H-Max downpipe, 4" straight piped, Tony's Wildmans 4 position chip, A-Piller with Auto Meter Z-Serries Pryo, EGT, and Trannie gauages, Gooseneck, Ride-Rite Air bags, Nerf Bars, Home built custom headache rack, 60 Gallon Aux. fuel tank, front bumper,and rear bumper....
Member of IAFF Local 2362 (International Association of FireFighters)
My Truck
Work Truck
Firedude is offline
Old 01-02-2008, 12:11 AM   #2 (permalink)
Hook'em Horns!'s Avatar
Re: Surgeing trailer brakes
Yeah, feels like you forgot to push in the clutch.
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 01-02-2008, 08:49 AM   #3 (permalink)
I think it is 2 things. 1 is over gain / 2 ABS brakes. That is just my opinion for now. Mine does it and Ive seen others do the same. \There was a discussion on it a long while back but it didnt last long......I dont remember if any one had a viable answer to it other than it being the ABS brake causing the surging brakes
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 01-02-2008, 04:51 PM   #4 (permalink)
GEARJAMMER's Avatar
My Photos: (9)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Firedude</div><div class="ubbcode-body">Hope this finds all haveing a safe and good new yrs. so far. Anyway I have a issue with surgeing(?) brakes on a 26' Big Tex G.N.<span style="color: #FF0000"> I have a Draw Tite II brake controler </span> that came with the truck and has always worked real nice, anyway Ihave noticed that when just about stoped it seems that the trailer brakes start to "surge?" ;like you are "pumping" the brakes any ideas? Thanks for any help
stay safe out there
Roy </div></div>
First, I would get rid of that controller and get a Jordan. Jordan told me that he originally designed that controller for Draw Tite. It is a very old design and it will wear out as all controllers do.
Shawn
2008 F-450, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viar 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm.
PICTURES
GEARJAMMER is offline
Old 01-02-2008, 05:42 PM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hook_em_Horns</div><div class="ubbcode-body">Yeah, feels like you forgot to push in the clutch. </div></div>
Kinda hard to push in on the clutch when the truck is a Automatic????
stay safe out there
Roy
My Truck
Work Truck
Firedude is offline
Old 01-02-2008, 07:51 PM   #6 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Firedude</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hook_em_Horns</div><div class="ubbcode-body">Yeah, feels like you forgot to push in the clutch. </div></div>
stay safe out there
Roy </div></div>doh! [img]/forums/images/%%GRAEMLIN_URL%%/blush.gif[/img] Read the sigs., just describing the feeling while piloting an automatic.
No constant I can find in the scenario, is it the truck abs, trailer brakes or some weird resonance that sets up with a few bumps approaching the final stop. Only happens during the last 40-50' when loaded heavy, and trying to duplicate it on the same course/same load shows no results.
Seems like a heavier controller output setting eliminates it, so maybe it is an abs reaction. However, no abs-like pulsating feel is felt on the pedal.
Very seldom occurrence so it's hard to define clearly but, It'll sure get your attention and make you wonder, "What the heck was that?" [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
A/T Revos
Old 01-02-2008, 08:37 PM   #7 (permalink)
LOL no problem I have done it too [img]/forums/images/%%GRAEMLIN_URL%%/whistle.gif[/img], but yes it does feel like its to ABS, only thing is it has not done this before, I turned the "setting" down to 2.5 and it is not as bad but still there, also have not seen it do it when pulling the RV (28"G.N. also) I pulled a good load on it about a month ago and it was not doing it then, hooked up to move it in the yard and thats when I noticed it? oh well will see.........
My Truck
Work Truck
Firedude is offline
Old 01-02-2008, 08:53 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: GEARJAMMER</div><div class="ubbcode-body">
Shawn </div></div>Cable mount has issues with GM. So, you think it's an Electric versus Proportional issue? It happens in the final few feet of a stop, can't imagine how a proportional would be any different.
I believe my Digital Draw-tite is a different model than Firedude's but, it may be controller related. They're Lifetime warranted, maybe I'll have it swapped out and see, it's only 5 years old or less and I have noticed a 0.5 variance in the set output occasionally.
A/T Revos
Old 01-03-2008, 12:08 AM   #9 (permalink)
Get a Brakesmart.
CSSJR
cssutto is offline
