Hello, The 2003 Super Duty has a plug under the dash, just to the right of the steering wheel, that the controller plugs in to. You'll need to take that access cover off under your steering wheel to see it. Look to the right in that opening. The Tekonsha Prodigy's I've purchased had instructions on how to connect their connector to the factory ford connector (loose wires to loose wires), however, you can purchase a custom pre-made harness for your truck that is plug-and-play. I've seen them on Ebay and E-trailer for not a lot of $$'s.
Tom
2000 7.3, 4R100, SC/SB F-250 4x4 w/Reese 16K Slider, 119K -- 1986 6.9l, T-19, RC/LB F-250 4x4, 4" Rough Country lift w/ 35" tires on Ford "Camper Special" 10" wide wheels, 230K
