Used a Prodigy on my 01 & towed a 30" Artic fox, 18K CGVW. Was generally disapointed w stock brakes when towing. Much improved braking with powerslot rotors & Hawk pads installed in front around 40 K due to pedal pulse associated with rotor thickness / hardness variation. Did not want OEM quality again. Rear wheel brakes don't contribute as much during stops. I used around 8 as well, & adjusted the boost figure for relative speed, higher @ highway, lower in town. Use the manual max over ride lever to ck trailer braking, or emergency. It should lock em up @ max setting. If it does, your connections & trailer are ok. If not, T/S wiring or trailer brakes. Never figured out why RV mfgrs insist on ele brakes (cheap?) Hyd is way better. Figure it's like most RV stuff in general, not the best, just enough to get by.
O7 F-250 XLT S/C L/B, 4X4, 2" lift, Firestone air bags, o/b compressor, Ranchos, Linex, Diselsite coolant filter, Fumoto oil drain, straight through truck muffler, 5" Flo-Pro s/s tip, Kobalt toolbox, bug shield & ventshades, Steelcraft s/s bull bar, IPC dr & fog lights, Rampage s/s step boards, Line of Fire LED under tailgate, fog lights on class III hitch reverse lights, JVC HDR-1, Infinity Kappas, wheelskins, cover king dash mat, Husky mud flaps.
Artic Fox 21-5R 5ver
Totalled 01 F-350 C/C, L/B (someone ran a stop sign, & ended up as a hood ornament), many xtras, best of which from Rob Riley (Diselsite), Jody Tipton (DP Tuner) & many thanks to Dieselstop contributors.
We stand on the shoulders of giants. If you can read, thank a teacher, if it's english, thank a vet.
