tekonsha prodigy brake controller - Diesel Forum - TheDieselStop.com
Old 08-03-2005, 07:33 PM   #1 (permalink)
Has anyone installed one of these it looks like it comes with a factory type harness, just wondering if someone with limited wireing skills can install one of these units. thanks in advance
1997 cc 73k 4.10 5spd kargomaster lumber rack bone stock
wyojess is offline
Old 08-03-2005, 07:49 PM   #2 (permalink)
Re: tekonsha prodigy brake controller
Buy the pig tail that is made for your truck and you will not have to splice any wires. Plug and Play. The pig tail is about $15.00
2001 7.3L F450 4x4 CC Automatic Fontaine Conversion 4:30 Limited slip Reyco Granning Full Air Ride Supension, Transfer Flow Fuel System, 4" MBRP turbo back, gages, pryo pre turbo.
Build Date 03-12-01 in KY. Towing a 34 foot Thor Tahoe toy hauler 5er.
2004 F250 CC SB XLT 6.0 Automatic Gauges Big Walker Truck Muffler towing a 23 foot American Freedom with a buggy inside
OldmanII is offline
Old 08-03-2005, 07:51 PM   #3 (permalink)
thanks alot I am ordering it tonight as usual diselstop.com has the most knowlegble members!
wyojess is offline
Old 08-03-2005, 10:49 PM   #4 (permalink)
I put one in my 2005 X a couple of weeks ago. As stated above,
if you order the wiring connector for your truck, it's a 5 minute
install. Drop the dash panel, plug the wire connecter in (it's a
PITA, it's a little hard to get to...) put the panel back on, then
figure out where you are going to mount the unit. I drilled 2 small
holes in the dash and mounted it under the cubby hole.
06 F250 Crew Cab LB V-10 4x4
99-122 Bright Atlantic Blue S-281 S/C Convertible
Factory Five Daytona Coupe #139
tfalk is offline
