Thinking about getting a flatbed - Diesel Forum - TheDieselStop.com
Old 11-17-2009, 08:29 PM   #1 (permalink)
lone_star_dsl's Avatar
I have had some peeling of the clearcoat on the passenger side of my bed and stopped by the body shop to get a quote on repairs. They recommended a total re-paint of the entire truck (which it probably does need) for $8,000.
After I picked my chin up off the floor, I decided I would look around for a flatbed.
I need recommendations for a steel bed that will fit a SRW. Pics would be great! Also, does anyone know what the going rate for an 8' bed that needs a little clearcoat work would be? I may have one for sale soon.
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
Intercooler Wrap Removal
4" Straight Pipe Exhaust
Recon Smoked Cab Lights
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
2010 Elite 20' Dovetail Gooseneck GVW 14,000 lbs
2001 Thor Wanderer 24RK Fifth Wheel
180,000 mostly trouble free miles and counting!
lone_star_dsl is online now
Old 11-17-2009, 10:20 PM   #2 (permalink)
My Photos: (27)
A big seller around here is Hillsboro. Check out their website, they are CLASSY looking flatbeds.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 11-18-2009, 12:44 AM   #3 (permalink)
i have had a ton of diff. flat beds, the best one so far hands down has been BRADFORD BUILT. they come with lights and wiring. flip down sides gooseneck, stake pockets. powder coat, reese hitch built in, mudflaps.etc,,,. alot of beds come with some p.o.s tail light assy. that you have to modify the tail light to bolt or weld on. not with bradford they send all the lights and have backup light on there also. as you can tell i like them, hands down best bed. they also have boxes that you can get for the underside in front of the rear tire. when you buy the box it has mounting hardware, under the bed is all the holes needed to add the boxes, so they really have thought the bed over. now i hear if you want a bed with out the gooseneck it cost MORE, the comp. told me that they move the beds with the gooseneck ball, so if there isnt one there they have a hard time moving it. well enought said, i like the bradford built beds.
Bradford Built, Washington, Kansas
a man is only as good as his word
2000 f250, 4x4, PSD, auto, XC, LB bradford built flatbed, edge juice with attitude, 4"BANKS exhaust with BANKS jake brake, BANKS Trans command, BANKS big head wastgate, BANKS turbine housing, BANKS intercooler, k&n air filter kit,ATS ported shroud compressor housing with WW, CFM+ intake manifold,AIH delete,ITP overboost annihilator
1983 f250 6.9, STC, 4X4, 5 speed, LB bradford built flatbed,with BANKS sidewinder turbo kit, BANKS 4" exhaust injectors set at 2150psi
1970 f250 FARM AND RANCH SPECIAL
djbrown is offline
Old 11-18-2009, 09:11 AM   #4 (permalink)
I like my Western Hauler a lot. Pop in brake/back up lights so they are easy to change and available at every truck stop. Plan to upgrade to LED's too. You can get a wedge fuel tank and other options for them. TON OHV, Jeeps, and 4WD Galleries :: Ultimate Tow Rig :: F4503
Mike Strickland
Web Master
BigCountryOff-Road.com
2003 F-450 4x4, 6.0 PSD, 4.30 Gears, Western Hauler, 19.5 Wheels/Tires; EGR Delete, ARP studs, HPOP, bypass fuel system, cold air intake, EGT gage(more to come), SCT tuner
RajinCajun is offline
Old 11-18-2009, 11:01 AM   #5 (permalink)
My Photos: (27)
There's a lot of nice ones out there, Featherlite is another one. Just my opinion, but I'd bite the bullet, go without eating or whatever it took and spend the extra bucks on aluminum rather that steel. At the time I thought I couldn't afford the extra for aluminum when I bought my current horse trailer. Right after I got it paid off I was sorry (and still am) that I didn't spring for the aluminum model.
LMJD is offline
Old 11-18-2009, 07:20 PM   #6 (permalink)
go aluminum. SRW truck has no payload to begin with. And with a steel bed you are at least 500 lbs heavier than with just the stock pickup bed. Might as well throw in a dump cylinder on it too. Unless you have a dump already.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 11-18-2009, 10:36 PM   #7 (permalink)
Thanks for the replies fellas.
I am looking around at some aluminum ones but I am worried about what it would take to repair it if it should get damaged in some way. I am a competent welder but I don't have access to a TIG.
I did find this one: ALUMINUM TRUCK FLATBEDS - lightweight , save fuel, and look great! by Highway Products but the $8,400 price tag scared me away.
I say that I worry about damaged but my current bed doesn't have one single ding in it so far (knock on wood) and it's been almost 8 years.
I really do like the look of the Bradford Built beds. Very classy.
I have pretty much talked myself into getting a flatbed and calling it an early Christmas present to myself. I have a tailgate spreader that I use in the winter when we are plowing snow and it doesn't allow me to open the tailgate. I was thinking with a flatbed, I would have access through the sides to load the snowblower or ATV. Also, it would make loading pallets of ice melt much easier. I don't know why I didn't think of this earlier.
I did some checking around but couldn't nail down a price that I could get for my bed. Any ideas? Long bed, charcoal in color with a 2"X14" section of peeling clearcoat. No dents BTW.
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
Old 11-19-2009, 09:14 PM   #8 (permalink)
you can probably get a couple hundred bucks for your bed.
NickKent is offline
Old 11-21-2009, 05:19 PM   #9 (permalink)
bryrylan's Avatar
My Photos: (11)
check this out, fresh install last week
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
bryrylan is offline
Old 11-21-2009, 05:23 PM   #10 (permalink)
bryrylan's Avatar
My Photos: (11)
Note: I just changed the lights out to clear LEDs and the harness that came with that was AWESOME plugged right into the stock ford connector.
10K winch
All LED lights
bryrylan is offline
Old 11-21-2009, 07:01 PM   #11 (permalink)
I saw pics of your truck on plowsite. You definitely threw a ton of fuel on the fire when I saw how good it looked.
I think I have settled on a Bradford Built but I need to find a buyer for my bed first.
Thanks for all the input guys.
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
Old 11-21-2009, 08:44 PM   #12 (permalink)
bryrylan's Avatar
My Photos: (11)
I wanted a bradford built in the worst way but had no way to get one here with out paying almost as much as the bed to get it to me..
10K winch
All LED lights
bryrylan is offline
Old 11-22-2009, 04:18 PM   #13 (permalink)
I got a price on a TruckCraft Corporation ::: Truck Bodies and Equipment aluminum flatbed with fold down sides. The price on the bed wasn't bad but they wanted like another $2200 for the sides!! I had priced the Highway Pod. also and it was over $8000.
Not sure if the pic works.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 11-23-2009, 01:32 AM   #14 (permalink)
one note, the bradford beds do weigh about 900lbs. i have air bags on my truck and keep just under 30 lbs to keep the truck level.
djbrown is offline
Old 11-23-2009, 11:20 PM   #15 (permalink)
I found a bed locally. It is in great condition and very similar to a Bradford. The only issue I see is that it is only 8' long. Every new bed I have looked at has been 8'6".
I measured the frame of the truck and from the cab it is 8'. The problem is that I would have to relocate my spare tire, fabricate a new hitch and build my own mounts to fit it to the frame. I have all the tools, but is this a major undertaking?
I can pick this bed up for $1,400 less than a new one. Is it worth the trouble?
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
