Old 07-02-2008, 04:04 PM   #1 (permalink)
ticketed for illegal mirrors
Hi Gang,
I just received a repair ticket because my mirrors are substandard. I have an 01 f250 with the trailer towing mirrors. IE; the big boxy ones that slide out an additional four inches on each side for towing. The AZ state trooper measured my trailer and the mirrors. According to him the mirrors are three inches short on each side. I have to believe what he said. The trailer is 8.5 feet wide. The mirrors are good only for trailers up to 8 feet wide.
So, the question is where can I find extenders for the optional trailer towing mirrors?
So far all I have been able to find is extenders for the standard mirrors.
T I A for any input.
Dale
'01 F250 Lariat, AT, AC, ext cab, short bed, shell, bedrug, towing, and camper pkg. BD: engine brake, autoloc, tranny. Banks: EGT, Boost, & Tranny Temp guages. K&N air flter. Brake Guard. Tow a 30ft Airstream 8500 lbs max.
strommer is offline
Old 07-02-2008, 06:30 PM   #2 (permalink)
These will
crack you up, but may get you past the law:
Tow-N-See Towing Mirrors
I would look in your States Vehicle Code, that trooper may not be correct.
So0me review mirror laws, state something like, you must be able to see 200 feet etc behind the trailer on each side.
Check it out.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 07-02-2008, 07:16 PM   #3 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
I would also check into Arizona's laws a little before I started buying things and if that is so then there are going to be a lot of mirror extensions sold. I found out a few years ago that at times they look for any little problem that they can find. I was pulled over with a 16' trailer loaded with 4 wheelers, the trooper told me it was because I had no license light or tail lights. He was right but he didn't even let me get out of the truck to check but wrote the "fix it ticket" and told me to get off the freeway until the next morning and take it to a licensed shop to have it repaired. The next exit I pulled off and checked the plug. After 400 or so miles it had vibrated out enough that it didn't make a connection, I filled out the ticket and said that I repaired it myself and what it was along with a couple of comments on the trooper.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 07-02-2008, 08:38 PM   #4 (permalink)
fulltimer50's Avatar
My Photos: (13)
Bet he had fun measuring an Airstream.
George
99(9-98)F250XLT/SC/LB/4x2/3.73LS/A-Pillar mounted Tranny tempgauge,PreturboPyro,Boost gauge/JNB BypassReg/ Ford AIS/ Airlifts/Rancho 9000s/PFP mod/HD Heater shutoff/DS Predator Tuner/HX/Spin-on tranny filter/203*TS/Ford Gold Coolant/Coolant filter/Jimmyjammers/Cyclops antistart/Oilguard/MBRP 4"turbobackSSexhaust/Suncoast Extreme tranny/BD exhaust brake/08 Diff Cover/Ford02-04 Headlights/Wrangler 265x75x16 ProGrade.
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS,Kodiac Disc Brakes.
fulltimer50 is offline
Old 07-03-2008, 10:17 AM   #5 (permalink)
DecreasingDave's Avatar
Hahahahaha....I didn't even notice that!!!!
That's funny.....
Dave
2003 F-250, 4x4, CC, SB, 6.0 PSD w/Torqshift, Lariat, Toreadore Red/Arizona Beige
- Airaid intake
- MBRP Turbo-Back Exhaust
- Cross Over Fuel Line and 1/2 Banjo Bolt Mod
- Quadzilla Commander
- Zoodad Mod.
- Doorseal Mod.
- X-Springs and F-350 Blocks
- Full Traction 4.5" Hanger lift
- ProComp Add-A-Leaf and Velvet-Ride shackles
- BFG 35" All Terrains on Ultra predator 17x10s (Hub-centric)
- Timbrens
- Extang R/T Tonneau Cover
- EZ Down Tailgate Strut
- C.R. Laurence PowerSlider Rear Window
- Sirius Sat. Radio
- Polk Ex3 5x7s and 2 JL Audio 10w0s
driven by a 6 channel amp
- SCT from Innovative (WOW!!)
DecreasingDave is offline
Old 07-03-2008, 10:34 AM   #6 (permalink)
Strokin' 6.0's Avatar
Dale,
Recheck that trooper's measurements and compare them with Airstream's figures. We own a fully restored 1971 31' Sovereign, and I can guarantee you that our trailer is no wider than 8'. I've seen some of the newer Airstreams that looked wider than ours, but I think it's an optical illusion.
I'm bettin' the trooper just wanted to take a closer look at your tin can.
SSG Fred Lynes
2004 F-350 CC DRW
Oxford White/Arizona Beige Metallic
King Ranch Interior
Herrin Hauler Package
Reman'd 6.0L @ 43,956 miles
Remand'd turbo @54,814 miles
5R110 Torqshift
4.10 LSD
Strokin' 6.0 is offline
Old 07-03-2008, 10:44 AM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
There is many things wrong with this.
1. Most trailers are only 8' wide. If you measured 8'6" I will be very surprised.
2. To my knowledge there is nothing that says the need for specific mirrors unless you are commercial moving houses. They have the mirrors on a rack they extend.
3. In all my miles hauling overwide boats I have never been inspected for mirror size or width. Our y2k dually has the same mirros as you and we haul boats up 14' wide with nothing additional.
I call a serious BS job on the cop. Did he fine you? If so get the statute in writing where it applies to the recreational rig. I am thinking he found out his wife was cheating on him and needed to ruin someone elses day.
MarkEkberg is offline
Old 07-03-2008, 10:52 AM   #8 (permalink)
If it was in Pinal county, there is a cop around there in the area of the rest area right by Casa Grande that does not know his head from a hole in the ground. He thinks that he has it all figured out about vehicle laws, and trucks and commercial vehicles, and has cost me about $5000 fighting his stupid fixit tickets and out of service tags. I had to send a guy there from Mesa that had a Class A CDL to pull an f-250 with a gooseneck trailer because this nitwit decided it needed a class A CDL. Fight it, take it to cout and move on. There is no helping this idiot.
New addition:
2006 f-550 service body with a 20 foot stellar crane.
Arrest me red 2006 F-250 6.0 Even more loaded
Black 2000 F-250 4X4 PSD Lariat, loaded.
Green 2001 4x4 Excursion Limited with PSD, loaded
White 2004 F-250XL, it is loaded with just a LS. I can't find the other options.:P
Just how many superduty's does a guy need?
The-washer is offline
Old 07-03-2008, 01:45 PM   #9 (permalink)
Ahhhh Law Enforcement at it's FINEST.... To Protect And SERVE......
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Dr.Evil is offline
Old 07-03-2008, 03:19 PM   #10 (permalink)
My Photos: (6)
Maybe he should be looking for the S10's and Rangers pulling trailers with the stock, car type mirrors. How do they see around them?
June 1996 F250HD XLT/SC, LWB, 4x4, 4:10LS, E4OD, White outside, Gray inside, Camper/Tow pack, Factory Aluminum wheels, Factory rear slider, decal free.
Factory AIC, Aux dash switches, Full add-a-leaf, Mile Marker SS Hubs, Upgraded E4OD Tranny, Tymar intake, BD downpipe, Exhaust brake, 203* stat, BriteBox, California Regulator mod, Truck Interiors Winterfront, Ported bug guard, Energy Suspension bushings rolling on 265x75 Bridgestone Revo's.
KD7UBW - PHAR (Public Health Amateur Radio)
My Truck
2008.5 Mazda 3s Touring 5 door in Copper Red Mica w/indash 6 disk Cd changer/MP3 and moonroof: The Wifes
Rookie is offline
Old 07-03-2008, 03:20 PM   #11 (permalink)
Hensley Ron's Avatar
Airstream does make an 8.5' wide body. Our company president had one. Every state is different on the mirror regs, that's why too much is your best bet. If you don't mind strap on mirrors, our McKesh Mirrors have a good reputaion. You can see 'em at McKesh Mirrors.
CIPA makes a decent slip on, but they'll vibrate some.
Ron Estrada
Hensley Mfg., Inc.
Home of the Hensley Arrow and TrailerSaver
800-410-6580
Hensley Ron is offline
Old 07-03-2008, 04:03 PM   #12 (permalink)
Thanks to all who replied. Airstream started making 8.5 footers late last century. The trooper told me 8.5 is a maximum for interstates, and 8 feet is the law on non-IS highways. He stated further that AZ made an exception for RVs and 8.5 footers are allowed.
Thanks for the links to mirror sites. I do not think any of those would be satisfactory with Ford's big boxy mirror and would like to find a local distributor so I could test drive first. I will try Camping World as they have some extensions.
Thanks also for the tip on checking the statute. I believe I can do that on line and will try as soon as I can.
Dale
strommer is offline
Old 07-03-2008, 05:30 PM   #13 (permalink)
olddieseldude's Avatar
My Photos: (15)
Look what I found...
AZ Rules General
AZ Rules
AZ Mirrors
28-956. Mirrors
A motor vehicle that is constructed or loaded in a manner that obstructs the driver's view to the rear of the vehicle from the driver's position shall be equipped with a mirror located in a manner to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of the vehicle.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 07-04-2008, 01:46 PM   #14 (permalink)
GOT14U's Avatar
WOW......where was this ticket given to you at. I have had a run in with a very wise character who is the all knbowing towards Gila Bend just south of Buckeye.
I would also like to know if you fight it. what the out come is. I have a 8.5 foot trailer and only use the stock mirrors.
02 EXCURSION (4" EXHUAST,DI CHIP, FS2500 FILTER, 4 GAUGE PILLAR, AUTOMETER PHANTOMSII,ALPINE DECK,BOSTON ACOUSTIC 12",1000 WATT AMP,COOLANT FILTER SYSTEM,TRANNY BYPASS FILTER,AMSOIL FLUIDS ALL AROUND, V10 TRANNY COOLER, CAI, 200AMP ALTERNATOR, DIESELSITE BILLET THERM HOUSING, DIESELSITE OVER BOOST RELEASE VALVE, BTS VALVE BODY)and still more coming
04.5 GMC DURAMAX.....i know...i know !!
07 28' WEEKEND WARRIOR(12,385 lbs gvwr)
07 DUCKS UNLIMITED RHINO
5 KIDS
1 WIFE
3 DOGS
THANKS TO SHAWN @ RAGIN FOR ALL HIS ADVICE AND HELP!! U NEED SOMETHIN GIVE THIS MAN A CALL.(NO BS, AND NO UP SALES)
GOT14U is offline
Old 07-05-2008, 12:44 PM   #15 (permalink)
Crazy Ivan
Remember "The Hunt for the Red October",??
A Crazy Ivan is when they make a sudden turn in either direction so that they can get a view of who may be behind them.
I have to admit, I've had to do them before I bought my truck (I had an Expedition).
Dave
- Airaid intake
- Zoodad Mod.
- Doorseal Mod.
- Timbrens
- Sirius Sat. Radio
» Site Navigation
» Home
